Question about Craftsman Garden
Deck belt belt comes off
The belt could be worn which will cause it to come off
Posted on Apr 26, 2010
    Problem Solver:
  • 4 Answers
Put it back on.
Posted on Aug 03, 2009
Get a smaller belt?, or call sears!
Posted on Aug 28, 2008
Why does the deck belt on my Craftsman rider SN 917.276863 come off. I purchesed an undersized belt and it comes off. Purchased a OE belt and it comes off.
be sure you dont have a pulley that is bent or loose. are the belt retainers still in place? the deck bearings are not wore out causing a vibration?
Sep 28, 2016 | Craftsman Garden
Black smoke and noise when engaging deck.
Depends on where the black smoke is coming from. If it's coming from the deck then it's a belt issue, if it's coming from the engine then you have a carburetor issue. Most likely the governor isn't set up correctly or the choke isn't all the way off.
Oct 20, 2017 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
John deere lx188 48 deck belt size
Contact John Deere directly to inquire about belt size.
May 26, 2017 | John Deere Starter Tractor Lx188 Kawasaki...
Toro 17-44 can't keep deck belt from coming off
is the deck adjusted level?is it the right belt?
Apr 23, 2012 | Garden
I need a diagram of the drive belt and blade belts. How they run above the deck.
Ok.... I have to guess what mower you have. I am going to pass a deck belt link below. The first pitcures that will come up are for John Deere. At the top of the page you will see brands with links to the belt routing. Click on the brand name for your mower and then locate your deck.
John Deere http://opebycrigby.tripod.com/decks/jddeck.html
MTD http://opebycrigby.tripod.com/decks/mtddeck.html
Murray: http://opebycrigby.tripod.com/decks/murdeck.html
The MTD and JD links have most deck belt routing pictures that can equate to other brands.
Thanks for choosing FixYa,
Kelly
Jun 09, 2011 | Garden
What lubricant can be used on the Horizon T92 Treadmill
Go to www.horizonfitness.com then click on e-store then look for part and accessories the silicon lubricant to purchase. Follow this procedure before applying lubricant.
1. Inspect belt and deck. The deck should be smooth. The belt should have a consistent feel from side to side (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Continued use of your treadmill may damage expensive electrical components.
2. To inspect the belt and deck visually or to clean underneath the belt before applying lubricant, the belt must have the tension reduced. Loosen the tension roller by following the instructions in your owner’s manual. Do not loosen the bolts in the tension roller too far or the bolts will come out of the roller shaft. This step may not be necessary for your treadmill model or belt and deck condition.
3. Contaminants are the worst enemy of your belt and deck. Some treadmills may have an excessive accumulation of dirt and contaminants. If these are trapped during the belt lube process, significant damage will occur. If contaminant removal is necessary, loosen the belt by following step 2, lay the treadmill on its’ side, and use a nylon brush to loosen contaminants that have accumulated on the inside of the belt. Clean the deck with mineral spirits in a well-ventilated area. Allow the deck to dry before lubing or tightening the belt.
Jul 16, 2010 | Horizon T92 - Treadmill
Speed fluctuates up and down on my pro for ekg treadmill. It does not stay at the set speed.
You may have a belt and deck problem. Test by the following procedure: Without the power on stand on the walking belt push the belt in the direction it normally turns, if the belt is very difficult to turn (on most treadmill) this means that you have high belt/deck friction. To inspect the belt and deck visually loosen the tension roller by following the instructions in your owner’s manual Do not loosen the bolts in the tension roller too far or the bolts will come out of the roller shaft. Inspect belt and deck. The deck should be smooth without any grooves, pits. The belt should have a consistent ridged feel from one side of the belt to the other ,a belt can be worn out without any sensory signs of a problem. If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Visually look at the underside of the belt. It should have a consistent look. Black streaks in the belt are a sign of bottom-layer wear through. If your belt and deck is good a simply apply lubricant and this may resolve the problem Most problem are belt and deck issues.
May 15, 2010 | Exercise & Fitness
Deck Belt keeps coming off
I assume you mean the engine pulley by "front pulley"? Is the belt guide still in place? It bolts to the side of the frame and runs out to the engine pulley to hold the belt on when it's disengaged. Sound like your's may be missing/broken off
Jun 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cub cadet model LT1045 belt coming off the pulley for cutting deck?
FINAL SOLUTION TO FIX THE BELT FROM COMING OFF LT1045 WHILE MOWING!
I also had this issue with my LT1045 belt. However, I just figured out how to finally fix / re-engineer my LT1045 Cub Cadet from having issues with the belt coming off of the deck while mowing.
Taking it back into a shop for repairs will not work, the belt will just come off again the first time you mow. I am making a YouTube Video to help others like me with this mower issue and will post a link here soon showing how to fix this design flaw.
It took me about an hour to fix but I've got it working now with no problems, minimum vibrations and belt is running cool now! I've gone for 2 months with no problems now. Check back soon for the link!! I expect I will have the video tutorial finished within a week!!
- Mike
If you for some reason you cant
Jun 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
288 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
