Question about Toshiba e740 Pocket PC
Only turns on with hw-reset
One of the e740s suddenly started to not turn on after turning off. The only way it works is doing a hardware reset to get it back on and then never turning it off! It has the latest rom (1.0623.0409) and I have tried it with batteries from the other PDAs with the same results. Any suggestions?
    Master:
  • 903 Answers
I assume that there is some serious hardware problem. In my opinion the best solution is to contact service partner in your country and let them check the unit.
Posted on Sep 07, 2005
SOURCE:
Good mornin i jst wanne knw hw i can reset my lg front loader washine machine wd_80130fu itts malfunctioning plz help me
How to reset the washing machine:
  • Press POWER to turn the washer off.
  • Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
  • With the power disabled, press and hold the START/PAUSE button for 5 seconds.
  • Plug the washer back in, or turn the circuit breaker back on.
but most likely there is some other problem with the machine are you getting any error codes
Feb 16, 2018 | LG Cell Phones
Hw many turns do i need to do to reset the hi and low tuning screws on a husqvarna 265 scrubbar
You start at 1-1/2 turns from seating and adjust from there for best mixtures.
Nov 09, 2014 | Garden
Cannot play any movies
A couple of procedures you can try:
1. Do a soft reset. Press on the power button for about 15 seconds;
2. Do a full/hard reset by removing the batteries and pressing the master reset button;
3. Do a Systems Recovery by powering on and immediately press/hold the TV button till Recovery Mode is displayed. Follow on screen instruction of Forcing Touch Screen Calibration. You may need also to format the internal HD but that would mean you loose whatever data is inside.
If the above is not corrective, it is possible that as you posted it may be a hardware issue. Some users have reported serious hardware or firmware problems with the 704 that would require replacement by the manufacturer.
Hope that this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Jan 15, 2008 | Archos 704 WiFi Digital Media Player
My hp ipaq hw 6515
Try soft resetting your ipaq. If that didnt work then try hard resetting it, note that you will lose all the data in your ipaq
Oct 23, 2007 | HP iPAQ hw6515 Pocket PC
Toshiba E740 Power Problem
Hi, I noticed that the firmware that you have is not the latest, the last provided was 1.0623.049 which was released a few years ago. I would install this, in addition to the other patches from the Toshiba web site. Hopefully this will overwrite any software quirks for you. regards, Keith
Nov 24, 2006 | Toshiba e740 Pocket PC
E740 won't turn on
Is there a freezing problem if the PDA is on cradle? I am not sure but it can be battery problem. I don’t know how old is your PDA but you should contact service partner and let them check the unit.
Sep 08, 2005 | Toshiba e740 Pocket PC
Power fault
In y opinion there must be some problem with battery power supply. In my opinion you should contact service partner. I hope that your unit has still valid warranty.
Initialize my Pocket PC
When you initialize your Pocket PC, the factory default values are reset to the status as when you originally purchased the Pocket PC e740. NOTE: When you initialise your Pocket PC, all data stored in the memory is deleted. Your Pocket PC's initially installed programs are not deleted. Before initialization your Pocket PC, remove all storage cards. To initialize your Pocket PC, please follow the steps: Turn off the power Press the power button while pressing and holding the reset switch with the stylus. Then release the power button When a screen appears, release the reset switch When initialization is completed, the Welcome screen appears. Set up the system according to the screen as in the case of startup procedure.
My PC not turn on
The Toshiba Pocket PC e740 is shipped with an Enabled security feature, which switches off the batteries. In order to be able to turn on the unit, the Battery Switch must be in a battery "Supply" position. Please check if the Battery Switch is in a Stop position or Supply position. The Battery Switch can be found on the lower right edge of the unit, next to the "Cradle Connection Port". Please see the below diagram The Battery Switch supplies or stops power to the Pocket PC. When using the Pocket PC for the first time, slide this switch to the left with the stylus pen. If you have further questions, please refer to the Instruction Manual page 2-4 (21 of 182).
Backup and restore data
Section A - How to use a Toshiba Pocket PC e740 without loss of data: Never let the battery fully discharge. Never disconnect the battery from the e740. Regularly backup your stored data. Always connect the product to an external power source before changing the battery. Section B – How to backup your data: B1 – Using Activesync You can make a backup of the Toshiba Pocket PC e740 data to your notebook or desktop computer. If you have backed up your data to your notebook or desktop you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data please DO NOT remove the Pocket PC e740 from the USB cradle and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instructions: Insert the Toshiba Pocket PC e740 into the USB cradle. A connection between the e740 and your notebook or desktop will be established. Please close all active applications on the e740. On your notebook or desktop start Activesync and select Tools and then Backup/Restore. Select Full Backup. Select Back Up Now to start the backup process. B2 – Using a Compact Flash (CF) or Secure Digital (SD) Memory Card: a) How to insert a Compact Flash Memory Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Confirm the direction of the Compact Flash memory card by lining up the side grooves of the card and groove edge of the card slot. Insert the card smoothly and completely. b) How to insert a Secure Digital Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Insert the Secure Digital card with it’s contact surface (the metal contacts) facing the back of Toshiba Pocket PC e740. Press the card down until it clicks. You can make a backup of the Toshiba Pocket PC e740 data to your Compact Flash or Secure Digital memory card. If you have backed up your data to your Compact Flash or Secure Digital memory card you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data using the DataBackup program please DO NOT remove the Compact Flash or Secure Digital card from the Pocket PC e740 and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instr
Sep 07, 2005 | Toshiba e740 Pocket PC
Toshiba e740 Pocket PC Logo
48 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
