Question about Toshiba e740 Pocket PC
WiFi causes system freeze
When I switch on the WiFi using the slide switch at the bottom my system will freeze. I may get one 'tap' before it does but that's all. When I switch it off again all is well and some of the 'taps' made during the frozen period are then acted on. Everything else seems to work, just no WiFi. This also happens right after a hard reset. I am running 1.0623.409. Any suggestions?
    Master:
  • 903 Answers
I have really no idea what the problem can be. Check if there is some WIFi driver update available.
Posted on Sep 07, 2005
How do i get a signal on my galaxy prime core I cannot get internet
Hi Christopher, If no Wi-Fi and you're trying to connect to your home Wi-Fi The password is on the back of the modem in the house, Write it down then go into your phone and tap "SETTINGS" and tap "CONNECTIONS", Then tap on "Wi-Fi" and make sure it's switched on(should be a slide switch there), Once switched on it should start scanning automatically for networks, but if not then there's a scan button there somewhere. When it finds the modem just tap on that WiFi setting and a small window opens for the password, Type in the pass word tap "OK" and you're connected... Below is a link to a short YouTube video explaining pretty much the same thing I said..... I hope this helps..., CHEERS..
How to Connect My Phone to My Internet Using Wi Fi Wireless Keeping Up...
May 08, 2016 | Samsung Galaxy Cell Phones
How do I delete music from my ipad
It's very easy. Tap "Songs" to see all of the songs on the device. Tap an album, artist or playlist name, then tap on the song you want to remove. Slide your finger to the left across the song title to pull up a "Delete" option. Tap "Delete" to remove the song from the iPad.
Mar 25, 2016 | Apple Ipad2 32GB Wifi
How do I remove the switch on the Bosch model 11316 to replace the cord?
The switch slide snaps in - use a screwdriver and gently pry up on the bottom of the switch slide, there is a tab on either side that will release and it will come out - you will find 2 more housing screws behind it to remove the handle and replace the cord.
The switch will go back in top first and give the bottom a tap to snap it back in place.
Jun 04, 2014 | Bosch Hammering
How to save battery power on kyocera hydro
Cell phones are drained by running background apps, LCD brightness etc. Here are a few tips to help you. Most importantly, batteries do loose their strength (even when fully charged). I would possibly replace the battery every 2-3 years with a name brand battery, not a generic. Also keep in mind, when your phone is charged at 100%..unplug it. Tips to save battery life To save and extend battery life, follow these steps:
Lower screen brightness and timeout duration
  1. From any home screen, tap the All Appsall+apps.pngicon.
  2. Tap Settings.
  3. Scroll to 'DEVICE,' and then tap Battery.
  4. Tap Brightness.
  5. Touch and slide the Brightness slider left to decrease the brightness setting.
  6. Tap OK.
  7. Tap Screen timeout.
  8. Select one of the following options:
  9. 15 seconds
  10. 30 seconds
Turn off Wi-Fi, Bluetooth, GPS, Portable Wi-Fi Hotspot
  2. Tap Settings.
  3. Tap Tethering & Networks.
  4. Tap Mobile HotSpot.
  5. Clear the Mobile HotSpot check box.
  6. Tap the Back key.
  7. Tap the Back key again to return to the 'Settings' menu.
  8. Scroll down to 'PERSONAL,' and then tap Location access.
  9. Clear the GPS satellites check box.
  10. Touch the Status bar and slide it down.
  11. Tap Wi-Fi to turn off.
  12. Tap Bluetoothto turn off.
Change application sync settings
  1. From any Home screen, tap the All Appsall+apps.pngicon.
  2. Tap Settings.
  3. Scroll to 'PERSONAL,' and then tap Accounts & sync.
  4. Clear the Auto-sync data check box.
  5. To reduce sync settings for individual applications, select the desired application.
Turn off background data
  2. Tap Settings.
  3. Tap Mobile data.
  4. Tap the Menu key.
  5. Select the Restrict background data check box.
Minimize use of third party applications
  2. Tap Settings.
  3. Scroll to 'DEVICE,' and then tap Apps.
  4. Select the application you want to edit.
  5. Tap Disable to turn off the application.
    Note: You can tap Uninstall instead to completely remove the application.
Toggle from 4G to 2G
  2. Tap Settings.
  4. Under 'NETWORK SETTINGS,' tap Mobile networks.
  5. Select or clear the Use only 2G networks check box.
Update to the latest software
  2. Tap Settings.
  3. Scroll down to 'SYSTEM,' and then tap About phone.
  4. Tap System updates.
  5. Tap Check now.
  6. Follow any additional prompts.
Set device to sleep when unused
  1. Press and then quickly release the Power key to set the screen to sleep mode.
  2. To activate the screen, press and then quickly release the Power key again.
Apr 24, 2014 | Boost Mobile Kyocera Hydro Smartphone
My samsung galaxy poket turning off if i use wifi?
  • Tap the Menu key and then tap Settings.
  • Tap the Wifi switch to On.
  • Tap Wifi (to the left of the Off/On switch).
  • A list of available networks will appear, tap the network you wish to connect to.
  • If prompted, enter the selected WiFi network's password, then tap Connect.
  • Your chosen network will now show Connected to let you know its all setup, also you will see the WiFi signal bar in the notifications panel at the top of your screen.
  • If it still turns off try different hot spots. That modle only gets G2 and G3 connections.
  • Terry
  • Mar 21, 2014 | Samsung Computers & Internet
    I phone 5
    What Type/Brand of router ?????
    Apple's iPhone is a multimedia connectivity tool.
    As such, the iPhone employs a sophisticated system to keep you connected to the web via WiFi signals so that you can stay up to date with email, mapping and media.
    To use the iPhone's WiFi feature just follow these steps.
    Tap a network.
    If you have not yet used your iPhone's WiFi or if you're in a new WiFi area, the iPhone will show you a list of available networks.
    Tap the network that you want to connect to in order to connect.
    If there is a password required a little lock icon appears.
    Enter the password to connect to locked networks and continue to surf the web.
    Monitor your signal.
    As you use your iPhone, especially if you're moving around, you should take a look at the signal strength of the connection.
    The strength is indicated by a small, black broadcast symbol that stacks arches, or rounded bars, on top of one another.
    The more bars there are the better the signal.
    Make connecting to WiFi automatic or manual.
    The iPhone is equipped to automatically search for available networks and connect you to one.
    If you do not want the phone to search for networks, select the "WiFi" option on the phone's menu.
    Then select either the on or off option of the "Ask To Join Networks."
    Turning this option off requires that you find networks manually.
    Forget a network.
    Once you connect to a WiFi network once the iPhone automatically remembers the network and connects you to it at a later opportunity.
    To forget a network so you don't get automatically connected choose the "WiFi" option on the menu.
    Then tap the right arrow button next to one of the networks that the iPhone already remembers. Then tap "Forget This Network" to erase the phone's memory of the network.
    Troubleshoot Wi-Fi Connection Problems on an iPhone
    If you experience Wi-Fi connectivity issues on your iPhone, you may need to reset the Wi-Fi connection.
    Your connectivity issues could be caused by the wrong password if you are having trouble logging into the Wi-Fi network or from a problem in your iPhone's settings.
    By resetting the Wi-Fi connection, you are clearing out the previous settings created when you first connected to the network.
    Tap the Settings icon on the iPhone's home screen, and tap the Wi-Fi tab.
    Swipe the switch on the Wi-Fi tab to ensure Wi-Fi is enabled on your iPhone.
    Tap the blue arrow button on the network tab you are connected to in the network list, and tap "Forget this Network."
    Tap the "Forget Network" button that appears on the pop-up menu to confirm the action.
    Tap the Wi-Fi Networks tab in the upper-left corner to return to the previous screen, and tap the network's tab in the network list to re-join it.
    Press the Home button on the iPhone, and tap the Safari icon on the home screen to test the Wi-Fi connection.
    Tap the blue arrow icon on the network's tab if the connectivity problem persists, and tap the "Renew Lease" button at the bottom of the network's window.
    Tap the "Renew Lease" button on the pop-up box to confirm the action.
    Tap the Home button on the iPhone, and tap the Safari icon on the home screen to test the network connection.
    Nov 11, 2013 | Computers & Internet
    Hey... how do i get connected to internet and wifi on my samsung corby2 (touch screen)
    Hi cusack_janet,
    You can follow this steps. Make sure that before you open you Wi-Fi settings, you are in the Wi-Fi Zone.
    1. Click on the wi-fi icon in the menu [mostly in middle screen if you havent customised the menu items].
    2. On the next screen it wud say 'Tap here to turn Wi-Fi on' and there wud be round button saying Wi-Fi.
    3. Tap on that to switch on wifi.
    4. Now on the bottom menu bar Click on Search
    5. It will show u a list of wifi network available.
    6. Click on the one u want to connect to [A menu pops up]
    7. Click on Add in the menu
    8. In the form enter the network key [password u need to connect to ur wifi]
    9. Depending on ur other settings of you Wi-fi router, you may need to enter some details in the form
    10. Once done, click Save
    11. Now u r ready to connect.
    12. Click on the network u want to connect to and click on connect.
    Hope this helps.
    Thank you for using Fixya
    Sep 24, 2011 | Computers & Internet
    I think there is a sliding button to switch on wifi on my Lenovo 3000 N100 but it doesn't seem to be working.
    Hi supriyamahta,
    That's right, there's a physical wifi switch for your Lenovo 3000 N100. It's located on the front panel of your machine. It should be toggled on the right side if you wanted to turn it on. If it's not working you might need to turn on it's wifi soft switch. All you have to do is to press the Fn + F5 button. In any case and still you will be encountering the same issue that wifi switch can't be turned on I will ask you to contact Lenovo so they can give you proper recommendation on how the wifi switch can be replaced.
    Hope it helps.
    Thank you for using Fixya.
    Apr 02, 2011 | Computers & Internet
    I don't know how to activate Wifi in my pc aspire 5720Z.. Would you please help me
    There is usually either a button or a slide switch that controls if the wifi is on or not. It is marked with an icon that looks like a tower with two curved bars coming out of each side. Be sure that switch is set to "on". Secondly, you will see a small icon in your system tray (bottom right hand side of your screen) that looks like two little computer monitors. You need to click on that and have it search for wireless networks. Once you find your wireless router simply click on that router and click connect.
    Dec 18, 2008 | Acer TravelMate 272XC Notebook
    Toshiba e740 Pocket PC Logo
    70 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Alun Cox
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
