Question about Panasonic Lands Phones
On a kx-ta1232 key system we are trying to run a single line phone for an extenstion to a shop that is 3400 ft away. The line is bridged in the CO. When it is bridged you hear a buzz in the background but if you put dial tone going either way from CO it is quiet. Any ideas?
  • Panasonic Master
  • 2,460 Answers
The loop limit of a single line station is 3700 feet on 24 gauge cable. That would be point to point with no bridges. Viking Electronics makes a loop extender that would increase the loop limit to thousands of feet, or you might try search engines for a Proctor 46222 or 224 loop extender.
It's unlikely that the telco will treat your pairs as the loop is probably within specs.
Carl
Posted on Aug 27, 2008
Unable to receive calls on Panasonic KX T624
There is a reset code for each handset which I believe is 790,
Jul 14, 2012 | Panasonic KX-TA1232/KX-TA624 phone
How can I get the music on hold to work on the Panasonic Advance Hybrid System KX-TA624?
On the cabinet, there is a jack marked EXT MUSIC. You plug in an audio source to the jack and then go into system programming and turn it on in program 111.
Carl
Feb 04, 2011 | Panasonic KX-TA1232/KX-TA624 phone
Display screen shows "Will return soon" Would like
You need to cancel absent message on your phone. The method depends on which Panasonic phone system your phone is connected to. Following are the methods for three different Panasonic phone systems. Once you cancel absent message, your screen should return to date and time, if not then press * until it does.
KX-TA624 Phone System
Press intercom button, dial 750#, lift handset then return handset to cradle to end.
KX-TA1232 Phone System
Press intercom button, dial 7500, lift hanset then return hansdset to cradle to end.
KX-TDA100 or KX-TDA200 Phone Systems
Press intercom button, dial *7500, lift handset then return handset to cradle to end.
Jan 27, 2011 | Panasonic KX-T7633 Corded Phone
Hi i have a panasonic KX-TES824 installed with 2 co lines and 4 extensions. I want the ringtones to be different for internal telephones (ie call between the extensions) and the CO Lines (when call comes...
A Panasonic Analog PTS ring sound is not adjustable, however, the cadence is. An outside call rings with a single ring, an internal call is either voice announce or a double ring. The digital phones from Panasonic have either 8 or 30 different tones, but that's a different system.
Carl
Nov 21, 2010 | Panasonic KX-T7730 Corded Phone
How do I create a line appearance of a co-workers
To program a key for an appearence of an extension, press feature 00, press the key you want to program the extension number to, then press the right intercom and the extension number. press 00 when finished
Dec 21, 2009 | Lucent PARTNER18 Corded Phone
We want to transfer a call to a phone number (external party). System programming is required. Can you help me? Thanks, Gina
Panasonic KX t7730 call forwarding function to external party:
If you are using the Kx-TA624 pbx (TES 824 models) system, program your phone unit (t7730) as follows: lifet handset, press FWD/DND button, press 3, then the outside line access code, then phone number, then #, then return handset.
If you are using the kx-ta1232 (higher models) of pbx system (usually with 9 or more CO lines cabable, use the following command:
lift handset, press FWD/DND button, press 6, then the outside line access code, then telehone number, then # then return handset to cradle.
Jun 11, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic KX-TA1232, Setup and use
You can purchase a manual for about 10 dollars
Email your system/phone model number to sales at aaa-avad.com for further instructions.
Mar 31, 2009 | Panasonic KX-TA1232/KX-TA624 phone
I have a Panasonic KX-T61610 phone switching system. Some of my phone extentions are not working and some are. I have unpluged the unit and also pushed the reset and that didn't help. The extentions that...
Also, are there certain CO lines that can only work with this KX-T61610 system? Typical FXS? or any odd analog settings on CO lines or within the Key controller for the KX-T61610?
May 27, 2008 | Panasonic Lands Phones
CHANGING THE RINGTONE
Depending on your model system, it may or may not be possible. I included the two different methods to change the ring tone below depending on your system. Give it a try.
KX-TDA Systems
KX-TD Systems
Press PROGRAM
Program Press the CO Line key you wish to change
Press the same key again, enter the tone number (01 through 30)
img%20right%20hand.gif You will hear the tone associated with the tone type number. For example, if you press 02, you will hear the tone associated with tone type 22. Press each number (01-30) until you hear the tone you desire.
Press STORE
img%20right%20hand.gif The tone is now stored for that line on that phone only.
Press PROGRAM 99 (or PAUSE 99 if you do not have a PROGRAM button
Press the same key again, enter the tone number (1 through 8)
img%20right%20hand.gif You will hear the tone associated with the tone type number. For example, if you press 2, you will hear the tone associated with tone type 2. Press each number (1-8) until you hear the tone you desire.
Press STORE
Mar 20, 2008 | Panasonic KX-T7730 Corded Phone
Lands Phones Logo
41 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
