Question about Philips Magnavox Learning Universal Remote
Philips universal remote codes for zenith t.v.
I need codes for philips universal remote control for a zenith t.v.
  • 1 more comment
  • cystaldavis1 Aug 31, 2008
    I am looking for the remote code for a zenith health view series Tv.
  • Anonymous Sep 02, 2008
    need programming code
  • Anonymous Jan 15, 2009
    i need codes for rca tv
  • 2,071 Answers
Http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): philips universal remote codes for zenith t.v. - clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
4 Suggested Answers
drumbanger
  • 1199 Answers
SOURCE: philips pm 335 universal control
Go to www.remotes.com If they dont have it no one will!
Please rate this response and help keep this area FREE!
Posted on Jan 23, 2009
aprmaejun
  • 97 Answers
I found the manual for your remote control at:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/philips/pm335-manual.zip&area=other
I looked for the code for a zenith tv and it looks like they're all 3 digit codes. It lists: 002, 008, 115, 215, 405, 407, 601, 701, 713, 903, and 916. If none of these work, I would suggest programming with the code search.
1. Press and hold "Code Search" button until the red indicator stays on. Release the "Code Search" button.
2. Press and release the desired mode button (TV, DVD, etc.) The red indicator will blink, then stay lit.
3. Press and release the "Code Search" button. The indicator light blinks off.
4. To find the first digit for the code stored under the mode key pressed in step 2, press each numeric key from 0-9 in turn. When the indicator light blinks off the number you pressed is the first digit for the code you are searching for.
5. To find the second digit, repeat step 4, this time when the indicator light blinks off this is the second digit.
6. Repeat step 4 again to find the third digit.
Posted on Jun 21, 2008
SOURCE: Need code to program Philips Universal remote control for Zenith
i need codes for ca sanyo tv
Posted on Mar 22, 2009
Need codes for a zenith tv please help. the controler. is a philips universal
Hello
Setup code for Zenith TV with Philips Universal Remote control SRU-5130-86 is: 3356. OK.
Mar 18, 2011 | Philips Televison & Video
I have lost the book to code a Zenith TV Could you help me find the code Please? I had it coded to another TV which died so now have a Zenith & now I cant find the book on how to code the Universal...
I couldn't find the manual for the remote you specified, however, as long as it is a Philips remote, you should be able to use any manual to find the code. If you know how to program the remote but just need the codes, you can get the codes here:
http://www.p4c.philips.com/cgi-bin/dcbint/get?url=/sca/sca/091116/091116160956_30167.pdf&ofn="H15022.pdf"
Dec 20, 2010 | Philips 313923812851 Remote Control
Need codes for a universal Philips Magnavox control for my insignia tv.
A variety of remote control codes can be found at InsigniaProducts.com; just search for your TV model number and click Support. Also, try codes for the following brands: Orion, Emerson, Memorex, Sansui, Sylvania, Zenith.
May 12, 2010 | Philips Magnavox Learning Universal Remote
I need the codes for my phillips universal remote controll the television i am trying to program it to is a zenith
According to the Philips site, these are the codes:
ZENITH .. 0713 0502 0606 0409 0710
....... 0415 0507 0714 0405 0712 0015
....... 0916 0008 0002 0115 0224 0324
....... 0126 0326 0826 0228 0430 0632
....... 0435 0437 0903 0407 0505 0701
http://www.p4c.philips.com/cgi-bin/dcbint/faqview.pl?ctn=SRU5107WM%2F17&dct=QAC&new_tmpl=1&refdisplay=QAC_76964&refnr=0076964&scy=US&slg=AEN
Jan 31, 2010 | Philips Universal PH301S Remote Control
Need universal code for philips sru3004 universal remote
here are some sites with your code.
www.remote-codes.com
www.tvcodes.com
www.universal-remote.net/philipsmagnavox.html
Apr 15, 2009 | Zenith TVBR1342 13 in. Combo
Philips pm 335 universal control
Jan 23, 2009 | Televison & Video
Philips universal remote control. I need TV zeneth code
zenith remote codes 10017, 10463, 11265, 10178, 10092,
does these help?
Dec 01, 2008 | Televison & Video
Need all codes for the universal remote zenith zn bb5
I used the code provided by Philips Universal remote. It works great. One thing you have to ignore the first digit. Just use the last 3 digits only.
Mar 02, 2008 | Zenith ZN-BB5 Remote Control
Universal remote
need a code for a philips remote to control a zenith tz
Dec 25, 2007 | Philips Magnavox Learning Universal Remote
Philips Magnavox Learning Universal Remote Logo
2,873 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
