Question about Apple iPod touch
Ipod touch passcode problem!!!
My ipod touch has been for the pass 2 months by telling me wrong passcode conect ipod to itunes to enable the device.
is there any shorter means how to unlock the device without using itunes which takes hell of a time to restore
  • 2 more comments
  • mehar_zs Aug 30, 2008
    ipod is disabled try again in 4548869 minutes
  • Anonymous Oct 17, 2008
    same problem
  • poppa smurf Oct 31, 2008
    My ipod touch asks to connect to the computer so that i can unlock it, but the computer say to put the pass code and i dont know it?
  • Anonymous Mar 27, 2014
    no way to plug into a computer to access iTunes
  • Apple Master
  • 13,433 Answers
Hey,
here is the solution to solveing your passcode problem
http://www.fixya.com/support/r977231-disabled_or_code_forgotten
Let me know if you need anything else.
Thanks,
Ekse
Posted on Aug 29, 2008
  • Nahjae Blackwell Aug 15, 2013
    this wasnt helpful at all.
Unlocking my iphone5
Try the steps from here
https://support.apple.com/en-us/HT204306 Forgot passcode for your iPhone iPad or iPod touch or your device is...
Jan 06, 2017 | Apple iPhone 5
How do i unlock my iphone 4 when its disabled
Does this copied and pasted advice help you?
iOS: Forgot passcode or device disabled If you set up a passcode on your iPhone, iPad, or iPod touch, and you or someone else then enters the wrong passcode too many times, your device will disable itself temporarily. Learn what to do if you have forgotten your passcode, or if your device displays a message saying it's disabled.If you enter the wrong passcode six times in a row, you'll be locked out and you'll see this message:
  • iPhone is disabled
  • iPad is disabled
  • iPod touch is disabled
If you can't remember your passcode, you'll need to erase your device using iTunes, Find My iPhone, or recovery mode. Then use a backup to put your data and settings back on your device. Here's how. Use iTunes If you have synced your device with iTunes, you can restore your device.
  1. Connect the device to the computer you normally sync with.
  2. Open iTunes. If iTunes asks you to enter the passcode, try another computer that you've synced with. Or try the steps below to use recovery mode.
  3. iTunes will automatically sync your device and create a backup. If it doesn't, sync the device with iTunes.
  4. After the sync is complete, restore your device.
  5. When iOS Setup Assistant asks to set up your device, choose "Restore from iTunes backup."
  6. Select your device in iTunes and choose the most recent backup.
Use Find My iPhone If you enabled Find My iPhone, you can use it to erase your device.
  1. Go to icloud.com/#find to see if you enabled Find My iPhone.
  2. Click All Devices at the top of your browser window.
  3. Select your device and click "Erase [device]" to erase your device and its passcode.
  4. Use the Setup Assistant on your device to restore the most recent backup of your device.
Use restore your device as new or from a backup.
  1. Disconnect all cables from your device.
  2. Turn off your device.
  3. Press and hold the Home button. While holding the Home button, connect your device to iTunes. If your device doesn't turn on automatically, turn it on.
  4. Continue holding the Home button until you see the Connect to iTunes screen.
  5. iTunes will alert you that it has detected a device in recovery mode.
  6. Click OK, then restore the device.
Last Modified: Jul 8, 2014
Aug 04, 2014 | Apple iPhone 4 Black Smartphone
Ipad forgotten password
From the apple support site:
iOS: Forgotten passcode or device disabled after entering wrong passcode When you set up a passcode to secure the use of your iPhone, iPad, or iPod touch and then enter the wrong passcode, you may see a a message saying your device is "disabled". Learn what to do if you have forgotten or can't remember your passcode, or if your device displays a message saying it is disabled.If you enter the wrong passcode six or more times, you'll see a message that says one of the following:
  • iPad is disabled
  1. Connect the device to the computer with which you normally sync and open iTunes.
    Note: If iTunes asks you to enter the passcode, try another computer that you have synced with. Otherwise, go to "If you have never synced your device with iTunes, or you do not have access to a computer" section below.
  2. If the device is still disabled, or if iTunes does not automatically sync your device, sync the device with iTunes.
  3. When the backup and sync is complete, restore your device.
  4. When iOS Setup Assistant asks to set up your device, choose "Restore from iTunes backup".
  5. Select your device in iTunes and choose the most recent backup of your device.
Hope this helps!
http://support.apple.com/kb/ht1212
Feb 05, 2014 | Apple iPhone 3G
Itouch disabled
Unfortunately, the only easy and reliable way to reset the passcode on an iPod touch or other iOS device is to perform a complete restore of the device, which will wipe everything on it. Connecting your iPod touch to your original iTunes library will reset any disabled passcode counter, allowing you to make additional passcode attempts, but it will not bypass the passcode.
The good news, however, is that as long as you have a backup of your iPod touch in iTunes or iCloud, you can restore that backup onto your device after you've erased it, thereby allowing you to basically pick up where you left off. Restoring from backup will recover all of your data and settings except for the device passcode, which you will be prompted to re-enter. You may also need to re-enter some passwords for things like e-mail accounts or Wi-Fi networks as these are secured by the device passcode, and thereby lost if you can't remember your original passcode.
Note that even if you haven't already made a recent backup of your device, you can still make one even with the device locked provided you still have your primary iTunes library available-usually the iTunes library and computer that you originally setup your iPod touch with. To do this, simply plug in your iPod touch, right-click on it in the Devices listing in iTunes, and choose the Back Up option from the context menu that appears.
Dec 06, 2013 | Audio Players & Recorders
Itouch disabled
When your iPod Touch displays a message telling you to connect it to iTunes, it may be in recovery mode, or have been disconnected in the middle of an update.
To get rid of the screen, you must reset your device. If in passcode mode, an iPod Touch must be manually unlocked or fully restored to get back to the home screen.Forcing a Reboot
When your iPod Touch is stuck on a screen that is instructing you to connect with iTunes, a normal restart will probably not work, as the hard drive has become frozen.
You can still, however force the iPod to reboot using a process called resetting.
To reset an iPod Touch, hold down the "Sleep/Wake" and "Home" buttons at the same time until an Apple logo appears, indicating that the device is rebooting.
When an iPod Touch reboots, it always goes back to the lock screen. Passcode mode will still be enabled.
Unlocking With the Passcode
If you know the passcode for your iPod Touch, slide the "Slide to Unlock" arrow and then enter your code on the next screen.
Upon entering your password, you will be directed to the device's home screen. If you enter the wrong password too many times, it will become disabled temporarily.
The iPod Touch can also be set to erase all content after 10 incorrect passcode attempts if you previously enabled this feature, don't attempt more than 9 entries.
Unlocking Without Passcode If you have forgotten the passcode to your iPod Touch, the only way to unlock the device is by restoring it.
Restoring an iPod Touch returns it to the factory settings, meaning that any settings, applications or music you added to the iPod are removed.
Once the device is restored, you can re-add your downloads and other information using the backup copies in your computer iTunes program.
The passcode setting will be disabled unless you manually enable it again.
Consideration
If you don't have a backup of your music and applications in iTunes on your computer, you can also download another copy from the iTunes Store or App Store on your device after a restore.
Any photos that are deleted during restore, however, will be lost forever if a backup does not exist.
Always back up your information via sync on a regular basis to avoid this problem.
Nov 05, 2013 | Audio Players & Recorders
9c93a00208
If you own an iPod touch, you have the option to set a password, which Apple calls a passcode, to protect your data.
Anyone who attempts to access your iPod, after unlocking it or turning it on, will require the passcode to do so.
However, if you forget your passcode or incorrectly enter it, you will eventually see an alert that your iPod touch has become disabled.
To unlock your iPod touch after forgetting the passcode, and still access your content, you must connect it to the computer with which you last synced it.
Connect your iPod touch to the computer with which you last synced the music player.
Launch iTunes if it does not automatically open.
Select your iPod touch under the devices list, and click the "Summary" tab in iTunes.
Click "Restore" and, when prompted, click the "Back Up" button to save a back up of your iPod touch in iTunes.
Click "Restore" when prompted, after the back up saves. After restoring, click "Ok."
Choose the most recent back up from the drop down list on the "Set Up Your iPod" screen.
Click the "Continue" button to restore your iPod touch.
iTunes: Restoring iOS software
http://support.apple.com/kb/HT1414
Jun 10, 2013 | Apple iPod touch
Forgot my ipod pascode lock
If you own an iPod touch, you have the option to set a password, which Apple calls a passcode, to protect your data. Anyone who attempts to access your iPod, after unlocking it or turning it on, will require the passcode to do so. However, if you forget your passcode or incorrectly enter it, you will eventually see an alert that your iPod touch has become disabled. To unlock your iPod touch after forgetting the passcode, and still access your content, you must connect it to the computer with which you last synced it.
Connect your iPod touch to the computer with which you last synced the music player. Launch iTunes if it does not automatically open. Select your iPod touch under the devices list, and click the "Summary" tab in iTunes. Click "Restore" and, when prompted, click the "Back Up" button to save a back up of your iPod touch in iTunes. Click "Restore" when prompted, after the back up saves. After restoring, click "Ok." Choose the most recent back up from the drop down list on the "Set Up Your iPod" screen. Click the "Continue" button to restore your iPod touch.
http://support.apple.com/kb/ht1212 iTunes: Restoring iOS software http://support.apple.com/kb/HT1414
Apr 08, 2013 | Apple iPod touch
How to unlock an ipod
Apple's iPod touch, a portable music player with a touchscreen display, is powered by a built-in rechargeable battery that provides up to 40 hours of audio playback and up to seven hours of video playback when fully charged. To conserve power, the iPod touch locks by default after a minute of not being used. If you want to use your iPod touch after it locks, you will need to unlock it. You might need to type a password, depending on how you've configured the device.
Press the "Home" button, located below the screen, or press the silver "Sleep/Wake" switch located at the top of the device. Swipe a finger across the "Slide to Unlock" slider on the screen. The iPod touch unlocks. Press the "Home" button or press the "Sleep/Wake" switch when you have enabled passcode protection on your iPod, then swipe a finger across the "Slide to Unlock" slider on the screen. The "Enter a Passcode" message appears. Type in your passcode, and then tap "OK." The iPod touch unlocks. Forgot Your Password b> Connect the iPod Touch to your computer using the USB cable. Wait for iTunes to open and sync with your computer. Eject your iPod Touch from the computer by clicking the "Eject" icon beside the iPod's entry in the "Devices" section of iTunes. Disconnect your iPod Touch from the USB cable. Your iPod Touch will be turned on and will be unlocked. Tap the "General" menu on the iPod Touch. Tap "Passcode Lock," and then tap either "Turn Passcode Off" or "Change Passcode." If you tap "Change Passcode," you can then enter a new passcode.
Mar 04, 2013 | Apple iPod touch
How can I unlock a disabled ipod touch?
Step 1:
The iPod Touch is a type of iPod that features a touch screen and can function as both a portable media player and as a pocket computer. It is possible to password protect your iPod Touch so that you will have to enter a password every time you want to unlock the iPod Touch screen. If you repeatedly enter the incorrect passcode, your iPod Touch will become disabled. To unlock a disabled iPod Touch, you need to sync your iPod Touch device with iTunes on your computer.
Attach the iPod Touch data cable to the bottom of your iPod Touch device and attach the other end of the data cable to an available USB port on your computer. Open iTunes on your computer and then select your iPod Touch device from the list of available devices on the left side of the iTouch window. Click the "Restore" button. If you have previously backed up your iPod Touch, you can choose to restore the device to the last back up or any saved backup. If you have never backed up your iPod Touch, this process will restore your iPod Touch's factory settings. Wait while iTunes syncs with your iPod Touch and restores the device. iTunes will prompt you when this process is complete.
Feb 10, 2013 | Apple iPod touch
Apple ipod touch 8GB For got password
1. Hold down Sleep/Wake button and Home button together, until the iPod touch powers off. Once the iPod touch turns on again, let go of the Sleep/Wake button about 1 or 2 seconds later, still holding the Home button. Once plugged in to your computer, iTunes will recognize the device is in Recovery Mode. You can now restore which will set the iPod touch back to factory defaults, thus removing the passcode.
2. Open up iLiberty+ and other the Other Tools tab select Enter DFU Mode. Your iPod touch will be recognized as in Recovery Mode by iTunes once you plug it in, at which point you can restore through iTunes. This will wipe the passcode as you're setting the device back to factory defaults.
3. Open up ZiPhone and select Prepare for Upgrade. You're iPod touch needs to be plugged in to your computer before doing so, and once you select that option iTunes will recognize that your device is in recovery mode. You can now restore through iTunes which sets the device back to factory default thus removing the passcode.
Apr 01, 2011 | Apple iPod touch
Apple iPod touch Logo
2,258 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
