Question about Canon PC-425 Color Copier
Making copies I get a black stripe down the side of my paper when I make copies. What should I do to correct this?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Take out the toner unit, I'm pretty sure the drum comes with it, look for a shiny cylinder, does it have a black ring around it? yes replace.
No, it may be coming from the fuser (exit wwhere toner melts to paper) not for the novice to do.
Posted on Aug 27, 2008
Is printing with a large black stripe down the side of the page, getting worse and worse as we copy
Please try cleaning the glasss surface where you place paper for copying
Oct 13, 2010 | Gestetner Copier
Black stripe running down left side of paper when
Open the top of the fax where your documents go in. There will be a thin **** of glass where the document is read. On the end that reads "dirty" is a smudge or some white-out that needs to be cleaned. You may have to clean it with some cloth wrapped on a flat tool. Do not scrap or scratch anything, just clean enough to get the dirt off. Then make a test copy.
Apr 29, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Black lines down the paper when copying
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab31
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
Black line down one side of paper
Lift the auto feeder cover and clean the narrow glass that the originals are scanned across...sounds like you have some dirt there -maybe correction fluid? That's the most common.
Please rate me :)
Jun 23, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
XEROX CopyCentre C20-Blank stripe going down side
Open the cover and put a piece of paper on only half the glass, and make a copy. BLOCK the left side of the glass with the blank paper.
See where it is blank. Most of the times that is a dirty or haved up mirror in the scan head. One of the small mirrors in the black assembly under the lamp. When a digital copier scanner optics become dirty, the image in that area becomes very light .
Mar 18, 2009 | Xerox CopyCentre C20 Black and White...
Black stripe and white stripe on copies
Black stripes can be down to dirty optics, unplug the copier and remove the glass, then clean all mirrors and the glass itself. If this does not resolve the problem, it will be the drum cleaning blade that has worn and will nedd replaceing.
Feb 16, 2009 | Sharp AL 1631 Copier
When making a copy we get an ink stripe down the center
open up the document feeder and clean the scanner glass.
Jan 21, 2009 | HP 1040 Plain Paper Inkjet Fax
PAPER PRINTING OUT WITH BLACK LINES AND MARKS
When coping I have a black line down the left side of the page. This only happens when I'm copying NOT when I'm printing off a document from Word or the Internet on my computer. How can I get rid of this black line?
Aug 14, 2008 | Office Equipment & Supplies
Black strip Mark on paper after print
Ramana is the black stripe just showing up on copies or faxes or does the stripe occur when you are printing from your computer. If the stripe only occurs when copying or faxing then more than likely the scanner glass is dirty. White out liquid on the scanner glass is a common.If it happens when printing fromyour pc, the problem will be in the toner cartridge or the fusing assembly.
Change the cartridge first to see if it goes away. Check the scanner glass, especially the small glass strip on the left side of the scanner or the right side where you place the original paper. These areas should be completely clear and clean of any scratches or smudges.
Last is the fusing assembly. If you tried everything else and theline continues to bother you, the fusing assembly sleve is probably torn. This would have to be replaced. The part number is RM1-0865-040CN.
Jun 23, 2008 | HP LaserJet 3030 All-In-One Printer
Gestetner 9940 Fax machine
okay it sounds like you have something wrong with the scanner which could be one of a few things.start by really looking close at the black stripe you need to make a copy of something with text across the entire black stripe. try both laying a sheet on the glass and throught the document feeder. what you are looking to see is if it's still able to scan the text and just is very dark in that area or if it's solid black with no text being exposed. one means that either your scanner is being blocked in that area due to dirt, white-out, smudges on glass, dust etc. the later being a diffective scanner.. I would clean glass paying close attention to the 1 " **** glass on the left that's what the machine uses to scanning with the document feeder. if you haven't solved it yet and you Must then lift the document feeder open, be sure machine is off. remove 5-6 screws securing the 2 guide plates for the glass, before doing so notice there is a gap between the two peices. the **** glass is for using the document feeder the other is orginal glass, they are two pieces so be careful when lifting the glass and clean both sides, then while you have the glass out, very gently hold the shiny mirrors just below and very gently slide to the left, there are 3 mirrors that may need to be cleaned using glass cleaner on very soft cloth, doing this ever so gently.
I hope this helps.
Thank You,
Mikey
Apr 05, 2008 | Office Equipment & Supplies
Canon PC-425 Color Copier Logo
93 people viewed this question
old marine
old marine
