Question about Gateway Computers & Internet
How do you replace a harddrive - Gateway Computers & Internet
  • Gateway Master
  • 3,051 Answers
Power off the computer and remove the power cord from the power supply
remove the both side covers off the computer
inside you will see the harddrive towards the front probably under the cd rom or a drive take off the cords attached to it i recomend labeling them for identififcation purposes then get a phillips screwdriver and remove the screws that are holding the harddrive in place ow just slide the harddrive out and install the new one put all the screws back and the cables back the way they came off then put the side covers onn and you are done
Posted on Aug 27, 2008
Replaced harddrive
Which version (including service pack) of Windows are you installing?
Dec 10, 2013 | Computers & Internet
Reset the BIOS due to drive error message
No, I do not concur.........
BIOS has sent a message that your harddrive is about to go south for the winter, and isn't taking you along.
In otherwords the harddrive is about to fail, and you are about to lose all your personal important information.
The message is for you to get as much of your personal stuff off of the computer. Copy to disk/s, flashdrives, or external harddrive.
Get ready to replace the Harddrive.
No? I have it all wrong? You already replaced the harddrive, and the message still comes up?
Post back in a Comment.
Regards,
joecoolvette
Apr 23, 2013 | HEWLETT-PACKARD Hewlett Packard Pavilion...
My acer chromebook AC710 SCREEN IS CRAZY CANT SEE ANYTHING BUT COLORS AN LINES WHAT TO DO?
The reason your monitor is in screensaver mode, (Read your other problem too), is there is no video signal coming to it.
No Signal
This is because the Netbook isn't sending one.
It isn't sending one because apparently you have graphics problems. Problems with graphics hardware.
So no, there is no Sync, or settings to change on the monitor.
(It is Not a video/graphics card. Your laptop uses Integrated Graphics. Intel HD 3000 Graphics )
However the point is moot now. Netbook is being sent in.
Point now is getting the info off the Harddrive, before some geek looses it.
(I'm a computer geek too, so that was no slam)
Remove the Harddrive. Then install it in an external enclosure.
You've seen an external enclosure, if you have seen an external harddrive.
You can buy just that 'outside case', too.
The external enclosure has a USB cable going to it.
The USB cable goes inside the enclosure, and connects to a small circuit board, with an interface on it.
The harddrive plugs into the interface.
The external enclosure comes apart VERY easily. Manufacturers make it easy to open the external enclosure, and install the Harddrive.
Usually a 2 piece case. One screw to open. Remove cover, plug Harddrive in, replace cover.
Plug USB cable into a USB port, on a working computer.
This is one example that will work with your Harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
[Harddrives are measured across their width.
A laptop harddrive is 2.5 inches across in Width. 2-1/2 inches.
A desktop harddrive is 3.5 inches across in Width.
Three technology styles of Harddrive, are presently being used;
1) IDE (PATA),
http://en.wikipedia.org/wiki/Parallel_ATA
2) SATA,
http://en.wikipedia.org/wiki/Serial_ATA
These two types of Harddrives use mechanical parts. For example a Spindle, Spindle Motor, and Platters,
http://computer.howstuffworks.com/hard-disk.htm
3) SSD,
http://en.wikipedia.org/wiki/SSD
No mechanical parts. Just electronic components. (Solid State)
Your laptop uses a 2.5 SATA harddrive ]
Going on..................
I haven't had any direct dealings with this laptop. Or the Aspire V5-171 version.
I see no Service Manual listed.
Searching the internet for Harddrive replacement info though, I ran into that there is a large panel on the Bottom of the Netbook; which has a single Philips head screw in the middle.
Remove the screw, remove the large panel.
This is supposed to be in the User's Guide, but cannot seem to download it right now to see.
It will be in replace the Memory. Ram Memory.
The Harddrive should sit in a compartment area all it's own.
The Harddrive itself will be in a sheet metal Caddy. Harddrive Caddy.
Remove a screw, or screws; to remove Harddrive, and Harddrive Caddy.
Once screw/s are removed, L@@K at the Harddrive.
There should be a piece of 'silk strap', to pull on.
Keeping Harddrive flat, and down in Netbook, pull on the strap; and pull the Harddrive across towards the OUTSIDE of the Netbook.
You are unplugging it.
You DO NOT want to lift straight up on the strap, as you will bend contact pins.
Once the Harddrive is slid over, then lift at an angle; and remove.
Lift up on the Back of the Harddrive.
This is the opposite side of the one that plugs in.
Open the external enclosure case, slide the harddrive in; then close the external enclosure case. (Referring to Tigerdirect example. Other external enclosures will be different)
Plug the USB cable into any working computer's open USB port.
Look in My Computer/Computer. (WinXP/WinVista - Win 7)
The external harddrive will be shown.
DOUBLE-click on the drive letter it is next to.
Have problems with that post back in a Comment.
Your Netbook, is supposed to be just an ACER Aspire V5-171 series of Notebook PC; with a Chrome logo on it.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 05, 2013 | Acer Computers & Internet
How to replace harddrive
Typically, most laptops require a full disassembly, but some have ejectable harddrive bays in the sides. Since you gave me no specific information, I cannot truly help you.
Dec 09, 2012 | Computers & Internet
How do I replace the harddrive in my sony VGC-LV150J all in one pc. I don't want to replace the harddrive that you can add to the computer by installing it into the harddrive bay but I want to...
you will need to disassemble the all in one, which is not the easiest thing if you dont know what you are doing, i would recommend bringing it to a repair shop to have it swapped.
Aug 15, 2011 | Sony VAIO VGC-LT32E 22? All in One Desktop...
If I replace my hard drive, will I lose all my pictures and documents? Thanks Paul
If you replace your Harddrive, you will want ot keep your old one to be able to pull that information off of it. As long as you aren't reloading the software on your initial harddrive, you will not lose that information. It will be kept safe on the old harddrive.
Mar 30, 2011 | Computers & Internet
Why does my computer always reboot ... sometimes over and over
Have you replaced the RAM? Try removing one at a time and turn on the computer - one maybe bad. Or your Harddrive may be bad - disconnect the Harddrive and see if you can go into the BIOS - it should without a Harddrive. If you can go into the BIOS your harddrive is bad.
Oct 25, 2010 | Computers & Internet
Need jumper settings for both hard drives. PCb board has been replaced. Cannot rememebr the orgional settings.
Master (M) on the harddrive that came with the computer, Slave, (S, or SL), on the 2nd harddrive.
Don't see M, S, and CS, on the label of the harddrive? (CS is Cable Select)
Sometimes it's right on the edge, where the 40 pin flat ribbon cable plugs in. It will be letters raised in the plastic, of the harddrive body.
To find where to set the jumpers for these harddrives, I suggest you look at the label. Since you had the Printed Circuit board replaced, I'm guessing you know who made it, and what the model number is.
Some harddrive manufacturers,
1.Western Digital
2.Maxtor, (Maxtor is owned by Seagate now)
3.Seagate
4.Hitachi
5.NEC (No longer in business)
6.Quantum, (sold out to Maxtor)
Here are three links that are videos, and may help with setting jumpers, and setting up those IDE harddrives. (IDE is also referred to as EIDE, ATA, and PATA)
(If you have SATA harddrives, do not touch the jumpers, if any are present! These are for the factory. With a SATA harddrive, you can plug it/them, into ANY available SATA header, {Connector}, on the motherboard. Doesn't matter!)
1.http://www.youtube.com/watch?v=WwbboeMO7b8&feature=related
2.http://www.youtube.com/watch?v=4inX3nC6M1E&feature=related
3.http://www.youtube.com/watch?v=KtEcwRqzeVo&feature=related
May 22, 2009 | Computers & Internet
How to replace a harddrive in an Acer Aspire 4520
open the back cover by unscrewing ..there u can see a small hard drive replace with a new one...
Dec 02, 2008 | Acer Aspire 4520-5582 Notebook
Computer not reading the hard drive
i have formatted the hard drive and put in all three recovery discs and it still won't load windows xp home edition.. i thought that was what the recovery discs were for.. maybe the hard drive is bad i don't know but if someone is having the same problem i could sure use some help here..
May 10, 2008 | Balance CN6555 Notebook
Computers & Internet Logo
125 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
