When I keep my air condition on auto and it has ran then turns off when the temp. is reached it has began leaking
Sound so simple< (dirty Filter) .This unit is trying to find air anywhere it can , even from the drain tube which sucks the water out the drain tube and hold it in the drain pan ,and when the unit shuts off, it dumps it ,. Anouther reason if this is an older unit (over 20 yrs. old) the pans were made of metal and could be rusting thru! (today, they're made of plastics) The a.c. supply house NOW has solvent you can pour in standin water guaranteed to seal leaking pans. Thank-you-very-much!
Posted on Aug 27, 2008
  • 958 Answers
Your unit needs cleaning.
when fan is running, it creates a vacuum that hold the water from spilling from your unit, then at auto, as the temperature is reached, the fan would stop and the vacuum that keeps the water from spilling would disappear and starts to leak water.
have ti clean....
that would eliminate your problem..
tnx 4 using fixya,
When the air condition reaches the set temperature to cut off the blower motor keeps running and i have the thermostat set to auto on the settings.
check the operators manual but you will probably find that the fan will keep running so that the air in the room is circulated past the thermostat so that the temperature can be monitored and the compressor switched on when the temp reaches the upper limit
May 30, 2016 | Heating & Cooling
Automatic air conditioning auto button will not stay on
temps sensor fault what does the temp read ?
Jun 26, 2017 | 2002 Lexus ES 300
Where can I get a manual for my Emerson Quiet Cool Room Air Conditioner? Not sure the model, but these #s were on outside of box: 10DC93 784040B OE21M N14421, is on a little sticker on the right...
Let see if I can help. The numbers don't come up so we'll just try your information.
Exhaust - should be closed when using for Air Conditioning
Energy savings turns the fan off with the compressor when set for Air Conditioning
Fan Only means just that (no Air Conditioning)
Fan speeds Quite same as low, Norm same as medium, Super same as High
Temp settings, what the thermostat senses before cycling compressor.
Jul 04, 2011 | Emerson Quiet Kool 10GV13 Air Conditioner
Have installed a new Honeywell thermostat. The fan does not turn off even when the room has reached the desired temperature. I originally replaced th ethermostat because the old one the fan ran forever and...
Most T-Stats have a On / Auto on a forced air system. On means the fan will run all the time even if it is not calling for heat. Auto only runs when calling for heat. Does the fan turn off in the auto mode at all? To test it...BE SURE THE FAN IS IN THE AUTO MODE ON THE T-STAT... Turn the thermostat all the way down and keep it there for appox 15 mins. If it is wired properly and the fan limit is set properly the fan should turn off. If it doesn't it is not the thermostat were the problem lies.
Most forced air units have a fan / high limit switch. There is a setting on the switch for the fan to turn on and a setting for the fan to turn off or it has a setting and a differental switch for it to turn off/on. Example - the fan comes on when the temp in the heat exchanger reaches 110 degrees F and will shut down at 95 degrees F after the thermostat is satified...this would hav a differental of 15 degrees F. It may be set to low and the fan continues to run long after all of the heat has been removed from the heat exchanger. This in turn will cause cool air to be coming out of the registers.
Mar 09, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
My honeywell Thermostat reaches the heating temp. but the fan will not stop running.And yes the fan is set to auto.It just keeps running and running and running.It stays the same temp but will not shut off...
I want to give a simple explanation before I go any further. On the heating side of a unit even though tthe temp has satisfied the thermostat, the fan will run until it cools down the plenum where the air flows from the air handler. There is a bimetal switch called a fan limit that operates the blower when the plenum reaches the temp set on the fan limit switch. Now if your fan keeps running even after the plenum chamber has cooled down, then you could have a fan limit switch that is stuck in the run position and must be replaced in order to correct the problem.
Dec 07, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
AC turn off before it reaches the desired temp
Hi there. I assume the indoor fan runs continuously until the house has cooled down. Clean the condenser. (outside unit)
Another possibility is that the system is getting low on freon. Check for leaks with soapy water at all joints and fix them.
Jul 13, 2009 | Ruud UAKA060 Air Conditioner
A/C set to "AUTO" but still won't turn off after temp is reached
you have either a bad thermostat or bad controls in the units unplug the furnace make sure the outside unit shuts off turn off the thermostat plug back in if it all starts with the thermostat off you will need service thanks for the high ratting keeps me helping for free.Tom
Jun 27, 2009 | Panasonic CW-XC243HU Air Conditioner
Heating & Cooling Logo
121 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
