Question about Toshiba e740 Pocket PC
USB connection
Does anybody know why my e740 would drop it's USB connection half way through syncing using active-sync?
    Master:
  • 903 Answers
My 740 had also problems with loosing the USB connection. I gave it to my dealer and he told me that the USB connector was defective...
Posted on Sep 08, 2005
PC Driver
there is no need for drivers for sync u just need active sync installed in WINXP if u dont have active sync install it from www.windowsmobile.com or see if it came with ur mobile in a cd and Windows mobile device centre in WIN VISTA that is bundled in the installation already u just find it by typing in search WMDC or in All programs u can look for it after u launch it just connect ur mobile thru usb cable provided and go in ur mobile pda start>settings>connections>usb connections set ur device for sync not mass storage and then press ok open the active sync software in xp or WMDC in Vista and it will automatically connect ur device then sync ur device as req
pls let me know if i can help u more in this and pls rate fixya if i have fixed ur problem
Feb 25, 2009 | i-mate SP5m Smartphone
Ipaq 4700 active sync problems
i can try to help you , first are you using xp or vista ? and which version of active sync ? i found that after upgrading to active sync v4.5 my ipaq 4700 refused to sync , i have xp home , so by trial and error i learned several things , i tryed my usb cable in every usb slot i had , only to find some usb ports are more friendly to certain devices , for a lack of better terms , i deleted all partnerships in active sync , found that i needed to make sure active sync is not running on ipaq , go to settings / memory / running programs on the ipaq , stop all running programs , turn the ipaq off , then on the pc made sure firewall not locked , plug usb cable into pc , i leave mine in a port permanently , plug into the ipaq , it automatically turns the ipaq on , then i see 2 icons in pc system subtray start blinking , at that point i know sync is going to work , then active sync icon starts turning , lit up in green , and asks do you want to create a partnership , yes , follow prompts , and thats what has been working for me , now if i was to put the usb cable into a different port , no doubt it would give me grief , and the same thing with my phone and active sync , make sure active sync is not running on the device , sometimes i have to reset the unit , ipaq or phone , make sure unit is turned off them make the connection , give it a try .
Jan 02, 2009 | Computers & Internet
IPAQ H5555 connection problems
Hi, This could be due to a few issues, try these soloutions in order below: 1) If you have a jacket connected to the ipaq it could be preventing the ipaq from locating correctly on the connector. Remove jacket and try insering again. 2) Check that active sync is set up to detect the device on the usb port. The cradle for the ipaq may have a serial and usb connector. Ensure that just the usb connector is attached to your laptop. Try connecting again. 3) You may need to uninstall the USB cradle if it was connected before installing active sync. Try the following steps if this was the case: a) unplug the USB cradle b) uninstall active sync c)Click start then click control pannel then click system. Then click on the hardware tab. Look for the device under USB, right click on the device and then select uninstall. d) restart the laptop e) Install active sync f) ONLY after active sync has installed you can now plug the cradle back into the usb socket. g) Now connect the ipaq, it should now detect it.
Aug 09, 2007 | HP iPAQ H5555 Pocket PC
USB connectivity for Jornada 520
This may be a simple case of removing all the entire active sync directory. If you used to connect via serial+com it wont be detected on usb. Remove active sync from your pc via the add remove program feture, then reboot and re install. Then run the make a connection again from active sync. Hope this helps
Sep 12, 2005 | HP Jornada 520
IPAQ 3955 Won't Sync?
Try uninstalling, rebooting and reinstalling ActiveSync on the host. If you haven't yet upgraded to 3.6, maybe upgrading will clear up the problem.
Sep 12, 2005 | Compaq iPAQ H3955 Pocket PC
PDA e310, e330 or e740 together with Windows NT 4.0
The Toshiba Pocket PC's e310, e330 and e740 are designed to work together with Microsoft Windows 98, Windows 98SE, Millennium, Windows 2000 and Windows XP. Microsoft Windows NT4.0 is an older operating system, which does not work together with the Toshiba Pocket PC's e310,e330 and e740. Technical background: The Toshiba Pocket PC's have a USB and a Infrared interface to communicate with a Computer. Unfortunately, Microsoft Windows NT4.0 does not support USB nor Infrared. Windows NT supports a serial connection, but the serial interface is not available for the Pocket PC's e310,e330 and e740. Note: There is the possibility to synchronize a PDA over Network or Modem but the ActiveSync Software, which is responsible for the synchronization, will need a "first sync" to establish a "partnership" with the PDA. This "first sync" can only be done via USB.
Sep 07, 2005 | Toshiba e330 Pocket PC
Sep 07, 2005 | Toshiba e310 Pocket PC
Sep 07, 2005 | Toshiba e740 Pocket PC
"Communications Error 608"
If you put the Toshiba Pocket PC e740 in your USB Cradle you may receive a "Communication Error 608". This is not a serious error, it is just a false setting in the ActiveSync Program. Please follow these steps below to correct this problem: "Tap" on start and choose the ActiveSync program Then "tap" on "Tools" and choose "Options" in the ActiveSync Program Check under "Enable synchronization when cradled using" to see if the setting is on "USB" If it is set on "Bluetooth", please change it to "USB". Now you can close the application window Important: Please remove the Pocket PC from the cradle and then return it to the cradle. This activates the new setting Important to note: This above described issue occurs if you "tap" accidently on the Bluetooth Icon in the Program Group or activate Bluetooth of any other reason, the ActiveSync Option will be set to "Bluetooth" instead of "USB". This setting will cause the "error 608" if you put in the Pocket PC e740 in the Cradle and start to synchronize over USB.
EM-500 sync problem
There have been issues with the cradle PCB on the EM-500. Casio has redesigned the same added an IC & a few additional componentes. I had similar problems & simply could not connect through the USB port. Worked flawlessly with the accessory serial cable (direct connection - no cradle ). This also was on an XP system. See if you can wangle out a free replacement/fix for yout cradle from Casio.
Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
Toshiba e740 Pocket PC Logo
56 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
