Question about Dryers
Dryer wont spin
Kenmore electric, model 6980100
  • Dryers Master
  • 19,396 Answers
If dryer does not spin it is usually a problem with the belt or the motor. Check also door switch.
See also following indications from Repairclinic:
It won't tumble If your dryer doesn't tumble, check these:
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Posted on Aug 27, 2008
I have a kenmore dryer model 8904 and it runs fine but it wont heat up
These are several things that can cause this, I will list them in order of "most common" to "least common."
1) Most common: The heat element has failed, they break in two pieces, and must be replaced.
2) One of the thermostats or a fuse has failed, and must be replaced. If this is the problem, you must also clean the whole inside of the machine's ductwork of lint, or having replaced the part, it will fail again.
3) A wire has burned in two, often near the heating element. Rarely, it can also be near the electrical cord in the back of the machine.
Be blessed.
Feb 12, 2014 | Kenmore Dryers
No heat spins model; 1106497230 kenmore
Oct 25, 2010 | Kenmore 62602 Electric Dryer
My kenmore 80 series starts, and spins, but wont heat... why?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
Sep 18, 2010 | Kenmore 63942 Dryer
My kenmore model 76873100 wont spin and the belt is in place
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Sep 14, 2010 | Kenmore 62802 Electric Dryer
Why wont the drum spin
does the motor spin when you hit start? If so the problem could be with the belt
Apr 27, 2010 | Kenmore 62802 Electric Dryer
The dryer will heat up but will not spin.
ckeck to see if belt has broken.
May 11, 2009 | Dryers
Dryer wont keep spinning without me holding the start button down
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
May 06, 2009 | Kenmore 64902 Electric Dryer
Kenmore electric dryer vibrates loudly
Yes the kenmore uses the roller wheels . dr fixit in the service providers has them. Any way I can help otherwise?
Dec 15, 2008 | Kenmore 659 Electric Dryer
Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Jun 28, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer not heating
is this a gas or electric
Mar 27, 2008 | Dryers
Dryers Logo
447 people viewed this question
Top Dryers Experts
