Question about Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elete LF problem
My machine can't make it through a wash cycle without a LF interruption. It is one of those he washers.
    Novelist:
    Champion:
  • 261 Answers
How full is your basket with water? Two suggestions, either low water pressure or a faulty pressure switch on the ccu. I use w10201186 if so to fix this problem. You can also check the screens on fill valves for debris.
Posted on Sep 07, 2008
Model 11026955690. Why does screen indicate LP?
I am not familiar with any error code referencing "LP". Could you be seeing "LF"?
Below are the error codes listed for your washer:
  • "LF" (Long Fill) Inlet hoses are kinked or clogged or water valve screens are not clear. (Solution: Straighten inlet hoses or clear screens of any foreign material.)
  • "LD" (Long Drain) Drain hose is kinked or clogged. (Solution: Straighten or unclog hose.)
  • "FF" (Fill Failure) Problem with water level sensing system. (Solution: Call for service.)
  • "OL" (Open Lid) Lid Is open during drain or spin. (Solution: Close lid.)
  • "PF" (Power Failure) Power to washer went off during cycle. (Solution: Press any pad to clear the display. Restart the washer from the beginning of the cycle.)
Source: Kenmore 11026955690 Manual
Aug 25, 2015 | Kenmore Washing Machines
Why is my washer stopping and saying LF before it even starts?
LF means long fill. Could be caused by low water pressure or a restricted water input. Make sure that hoses are not kinked or crushed. There is usually a fine mesh screen in the water inlet at the back of the machine. Turn off the water supply valves, remove the hoses from the machine and check to be sure that the screens are not clogged with dirt.
It is also possible that the fill valves are not opening as they should.
Here are some help videos.
washing machine slow fill YouTube
Oct 08, 2014 | Kenmore Washing Machines
The wash cycle was interrupted by pressing "pause"
first suggestion is to unplug the washer and give it a minute to rest logic. It could just be a glitch.
Plug it back in and see if you csn use the operation panel If no
Let me Know
Jan 11, 2011 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Our washers keep flashing LF after the wash cyle and stops workin, not spining very fast either.
Hello there :
the Dreaded LF code means
LF Long fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
Press STOP/CANCEL to clear the display.
check the water controle inlet valves that are attached to the machine for proper operation and replace if found bad
Jan 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Keeps stopping during wash cycle with LF code
This code is representing a long fill situation, have the pressure switch replaced asap. it has failed.
Aug 13, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Washer Oasis displays letters LF and is unable to complete washing cycle. Also, could you please send a manual via e-mail?
You can find owner's manual for Kenmore Oasis washer at http://www.managemyhome.com by searching for your model number. From the Kenmore owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
"Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it."
Apr 30, 2009 | Washing Machines
I have a Kenmore Elete 45862401 Quiet Pac2 front end washer that stops during the wash cycle. it flashes a f6 error code. The manual says it is a loose wire between the mcu and/or control panel,shipping...
With the front door open, see if you can rotate the basket freely.  If not, most likely the bearing of the rear tub is worn out.  You will have to replace the whole rear tub which is about $300 for the part.  I am having the same issue with my Kenmore Elite Quiet Pak 2.  I'm contemplating with just buy a new top-load washer.
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Loads interrupted
interrupted wash cycles and also give a code of F06. A service tech was supposed to be at my residence today... he did NOT show. This machine is little over a year old. Tried unplugging with no sucess. Any help would be appreciated.
Sep 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore electronic 90 series washer
easy easy you need agitator dogs thats right the official name of the part is agitator dogs! 5 dollar part can chat you through the fix
Mar 25, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
