Question about Frigidaire Heating & Cooling
Frigidaire air conditioner/heater
Gfi trips regularly. After unit is off for a few hours it will usually start up and run a few minutes to a few hours.
  • dfowler688 Sep 16, 2008
    Problem was GFI on power cord. Replacing cord solved problem.
You better clean that back coil quickly before you loose a compessor. Maybe ,G-- is trying to tell you something! Thank-you-very-much!
Posted on Aug 27, 2008
Reset button ac unit
Hello jerrydj1021 - Often when the breaker trips, it is a mainly because there is too much current running on one circuit. Is the unit plug into a GFI outlet? It is not recommended to use GFI outlets or too many appliances plugged into that one circuit. Try plugging the unit into another direct outlet and see if the breaker trips again. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jun 26, 2013 | Frigidaire Heating & Cooling
Not starting
Hello Pete T - From what you have described the air conditioner possibly have a defective power/control board or faulty plug. I would suggest contacting a professional to accurately diagnose and repair the unit.
Oct 02, 2012 | Frigidaire 15,100 BTU Heavy Duty Window...
Frigidaire GLRS264ZA refrigerator keeps blowing GFI circuit
The fan and defrost heater are run off the same relay on the board. When on defrost, the fan stops. when the fan starts, the defrost heater is switched off, Sounds like the neutral to the board may be shorting. If you have the ability, try powering the evaporator fan from the compressor relay, disconnecting from the board entirely. To see if this will work, just take a temporary wire to the fan when disconnected and see if it trips while running.
Aug 07, 2012 | Refrigerators
Air conditioner is tripping after one hour
clean filter and Evap coil and condensing coil. also some units have a gfi breaker at the plug witch some times go bad
Apr 08, 2010 | Samsung AW1203B Air Conditioner
Gfi keeps tripping
do not use a GFI on a A/C unit, it will blow everytime. On start up of the unit the amps spike then quickly come down as long as the unit is clean and running right
Sep 01, 2009 | Heating & Cooling
My LG window ac continues to shut down after 20 or 25 minutes
The button on the plug is a GFI. Ground fault interuppter. Like on your hair dryer. When the unit is running, or has just tripped out, feel the plug and the well receptical. If either feel warm or hot, do not continue to run the A/c unit. Get an electrician to check for a faulty/ worn/improperly wired outlet. The units tripping out for a reason.
Aug 01, 2009 | Samsung AW0603B Air Conditioner
A6414w7b b wall unit gfi plug keep tripping problem: fedders wall unit brand new keep tripping the gfi on its power cord
GFI plugs go bad very often if you had a storm in you area. You need to replace the plug. Go to aplliance parts house and they will sell you the new cord. Feed back please.
Jun 13, 2009 | Fedders A6D24E7D Wall/Window Air...
GFI on cord trips out.
Probable cause is a single pole gfi opposed to a double pole gfi.
* Do not use a single pole GFCI ON A MULTI WIRE CIRCUIT, IT WILL NUISANCE TRIP IMMEDIATELY
Use a two pole GFCI circuit breaker on such circuits.
May 20, 2009 | LG LWHD1800R Wall/Window Air Conditioner
Tripping circuit breaker
You probably have a dirty condenser coil or the con den ser fan motor is bad or the blades are jam that's why it overheat and shut off by overload.
Apr 20, 2009 | Dometic Rooftop RV Air Conditioner
GE XL44 Broiler/Self Clean Trips GFI
This should be a 220 volt appliance so I'm trying to figure how this was connected to a GFI. Does it have a second connection to power the controls?
Most GFI uints I have seen are not rated for large amounts of power consumption. I used to throw the one in my bathroom if I was running the electric heater and the wife fired up the hair dryer.
I'm wondering if this indeed does require the additional 110 connection then it sould be pulling heavy current from it to aid in the cleaning process. I've never seen a stove that needed the extra. My old electric range had only the 220 as well as my elders.
So if that is the case then you should not be running that through the GFI outlet because of the heavy drain will heat the breaker in the GFI and cause it to trip. Breakers actually work very similar to how the old fuses work. Heat causes the switch to throw. GFI units have a lower tolerance (designed to detect shorts quicker to save your life) and trip quicker than breakers do.
Apr 02, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Heating & Cooling Logo
74 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
