Question about Achiever CCS5000 Shredder
I need a manual for my shredder
I have a CCS5000 Achiever Shredder, 12 sheet, but have no manual. Can you help me?
  • Anonymous Oct 22, 2008
    We have an CCS 5000 shredder - we have no manual - our machine is making grinding type noise - it probably needs to have a part oiled - can you tell me how to oil the machine?
    Thank you for your help.
    Lynda-Grenier
    New Friend:
I need a manual for my shredder Achiever mdl # PS-150
Posted on Oct 10, 2013
The overload beeper want cut off and there no paper in it
Posted on Sep 04, 2008
The shredder has started making a whining sound under heavy load - say 10 sheets. It is 5 years old and has had light home usage.
Do you use shredder oil in your device? Even under "light home use" a shredders life is not easy. Ten sheets is a lot of paper to cut.
I use a cross hatch cutter design and I never put in more than 5 sheets and I use shredder oil. Find this product at a FixYa.com advertiser, Staples, Best Buy, Office Depot or any other fine retail outlet.
Thanks for your interest in FixYa.com
Jan 31, 2011 | Achiever CCS5000 Shredder
Our Achiever CCS5000 worked well until it was
Hi Alan,'
it is not available, you could find the interlock switch and jump them...cut wires off of switch and twist together, then use electrical tape.
Mar 03, 2010 | Achiever CCS5000 Shredder
I need a fuse for my ccs5000 achiever shredder. Do you know where one can be purchased?
Radio shack has a good selection. Make sure you match it exactly. Do not put a larger capacity fuse in there. It can burn the circuit board.
Jun 18, 2009 | Achiever CCS5000 Shredder
Acheiver CCS5000 screaching noise
A piece of metal or coin might have gone into the shredder.
Apr 22, 2009 | Achiever CCS5000 Shredder
I have a ccs5000 shredder that squeals now and then. I have checked all the gears and belts, found no troubles there. I have ran a sheet of lubricant for shredders throuhg the cutters and no change. We...
This a cross cut shredder right? Its job wears out these blades, sooner if not lubricated during its life. Replacing the blade assy. could get costly.
-Carl, please let me know if this helps.
Apr 11, 2009 | Achiever CCS5000 Shredder
Squealing Shredder
you need to spray lubricant down the paper shout. the cutter wheels are dry. They make a shredder oil but you don't need that just a light what oil. wd40 is to heave. If the noise is still there then it is in the gear train and will need to br serviced.
but to much oil will make a build up of dust also it's a catchy 22
Nov 03, 2008 | Achiever CCS5000 Shredder
Shredder won't turn on
Has your problem been solved
Please get back to me
Thanks
Jul 07, 2008 | Achiever CCS5000 Shredder
Achiever Shredder CCS5000
Is it on a 20 amp circuit? Check to make sure that it doesn't have a grounding problem or even the plug could be reverse woired.
Oct 10, 2007 | Achiever CCS5000 Shredder
CCS 5000 Achiever Shredder
You need to purchase a real heavy duty shredder that will handle your work applications. Call 800-342-7362 EG Brennan & Co LLC can help you in this regard!
Apr 12, 2007 | Achiever CCS5000 Shredder
Achiever CCS5000 Shredder Logo
618 people viewed this question
Top Achiever Office Equipment & Supplies Experts
quennie732
ray gallant
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
