Question about Panasonic Lumix DMC-FZ20 Digital Camera
Shutter speed I cannot remember the aperture, but when I try to take a picture of the moon with my FZ20, even @ 2.8 aperture, I certainly do not have 1/100s shutter speed, but more like 1/10 or even less (P mode). I wonder if there is a problem with my camera ? How can I check that it is correct ? Can someone with experience of moon shot give me some "standard" shutter/aperture so I can compare ?
    Master:
  • 903 Answers
Rule of thumb I read was f11 and then 1/ISO for shutter speed. This means that if you're using ISO 100, you use 1/100. ISO 80, then 1/80. White balance set to SUN (because moon is reflecting sunlight). Wait! My camera doesn't do f11!!! Mine, the FZ20, can only do f8, which is more open and therefore lets in more light. So you would need to speed up the shutter to compensate. Moronically, I don't know how many full stops there are between 8 and 11, so I cannot tell you how much to compensate for. :) I think the number I worked before was around 1/150 at ISO 100. And use a tripod.
Posted on Sep 07, 2005
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
How to shoot pictures of the moon
About this result
How to photograph the supermoon: an easy way to shoot moon ...
www.techradar.com/.../photography.../how-to-photograph-the-moon-an-easy-way-to-...
  1. Cached
4 days ago - Taking pictures of the moon is one of the more popular subjects in night photography - but it's also quite tricky to get right. Use this tried and ...
How to Photograph the Moon - Photography Life
https://photographylife.com > Photography Tutorials
  1. Cached
  2. Similar
Jun 11, 2015 - Aperture: Set your aperture to f/11. Shutter Speed: Set your shutter speed to 1/125 on cameras with base ISO 100, and to 1/250 on Nikon DSLRs with base ISO 200. Lens Focus: Set your lens to manual focus (either through a switch on the lens or on the camera) and set your focus to infinity.
How To Take Stunning Pictures Of The (Super) Moon :: Digital Photo ...
www.digital-photo-secrets.com/tip/779/how-to-take-stunning-pictures-of-the-moon/
  1. Cached
  2. Similar
Aug 7, 2014 - Start with ISO 200, f11 aperture and 1/125 second. Try a test shot. Then use trial and error by changing the shutter speed until you can find the best exposure that works for your composition without overexposing the moon. Turn off auto focus.
How-To: Photograph The Moon ' Popular Photography
www.popphoto.com/how-to-photography-moon
  1. Cached
  2. Similar
4 days ago - Planning is a big part of all photography, and shooting the moon is no ... that much money on a lens like this to take impressive moon photos.
How to shoot pictures of the moon Google Search
Nov 15, 2016 | Cameras
What is the best setting to take a picture of the moon
Without knowing the make and model of your camera I can't give you a definitive answer, but with most cameras you'll want to set it to manual and pretend you're shooting landscapes under a midday sun.
Camera exposure meters are designed to render the entire scene an average gray. Since most of your picture will likely be a dark sky, the camera will try to expose long enough to bring up the sky to an average gray, making the moon into a featureless white blob. Since you probably want to see the moon and don't care if the sky goes black, you want to expose for the moon.
The moon is just a big rock under a bright sun. There is an old rule for taking pictures under a bright sun called the "Sunny-16 Rule." This rule basically states that the proper exposure under this condition is an aperture of f/16 with a shutter speed of 1/ISO. So, if your camera is set to ISO of 200 then you set the aperture to f/16 and the shutter speed to 1/200 seconds, or any equivalent exposure such as f/11 and 1/400.
Digital cameras make this easier, since you can see the picture and adjust the exposure if it didn't come out right. Take a picture, zoom in on the moon, and see if you can see any details. Use the histogram if available. If the peak is at the right edge of the histogram then you're overexposing---reduce the exposure. You want the peak near the right edge but not touching it.
All this depends on the make and model of your camera. Many point&shoot cameras don't have a manual setting. In that case you're pretty much out of luck and you won't get a good picture of the moon.
May 08, 2014 | Cameras
My husband pulls tractors at night at tractor pulls, everytime I try to get a picture its too dark, the lighting around the pull isn't the greatest but it has some light
There are several solutions to taking pictures in the dark or low light. Night time photography can be difficult without a tripod. There are three ways you can get a brighter photo
1. Larger aperture - Make sure the aperture is set to the lowest f-stop for the largest aperture. f/2.8 or f/5.6 depending on your lenses capabilities. Choose the lowest number
2. Longer shutter speed - A longer shutter speed will allow more light to hit the canera's sensor and create a brighter picture. Unfortunately with a longer shutter speed, you will probably need a tripod because the photo will come out motion-blurred otherwise.
3. Higher ISO - A higher ISO will make the camera's sensor more sensitive to light and therefore creating a brighter picture without having to have a longer shutter speed. High ISO, however, can introduce unpleasant noise/grain to a photo.
If you want to take your picture while holding the camera in your hands, I recommend the largest aperture (small f/stop) and a high ISO.
If you have a tripod, use it! and use a longer shutter speed since the tripod will hold the camera steady for you.
Jul 09, 2011 | Nikon Cameras
I did not get any instructions with my Opteka. Have tried to take photos with it. But they came out all blank. I used a tripod. Would like to know where I can down load instructions. Certainly not as good...
You did not provide enough information to determine what your problem is. For example, were the pictures all light or all dark. Knowing this lens, I will assume that they were all dark. So...
1) This is a very, very slow manual-focus lens. It will not auto focus. It must be manually focused very precisely because it has virtually no depth of field.
2) Depending on your camera, your internal light meter may not work. On my camera (Nikon D-90), it does. If it does not on yours and I suspect that may be your problem, you're going to have to shoot everything manually, i.e. setting the shutter speed and lens opening yourself. You can use your internal light meter to help you get started by taking your light reading before you install the lens...preferably using the aperture only setting where you set the aperture at f8 which I think is the speed of the Opteka and let the camera set the shutter speed. Make a note of the shutter speed then attach the Opteka to the camera and mount the lens on a tripod with the camera attached.
Then set your camera mode to manual and set the aperture to match the lens (f8, I think). Set the shutter speed at the speed you noted earlier. Shoot a picture using a remote shutter release or the self timer. This lens is so slow that unless you're in exceptionally bright conditions you will get fuzzy pictures due to camera movement at full zoom of 1200m and above if you're using the 2X doubler. I would start shooting at minimum zoom of 650 without the 2X doubler. Shoot a picture. and check the result.
You should have an image but it may be too light or too dark.
If its too light you'll need to increase the shutter speed or stop down the aperture to, say, f11...or both. Make the adjustment and shoot another picture. Remember that if you increase the aperture, you increase your depth of field, making focus less critical. If you increase the shutter speed you make camera or subject movement less critical.
If it's too dark, you can only increase the shutter speed because you can't open the lens any wider than f8. Make the adjustment and shoot the picture.
Keep doing this until the pictures are the way you want them.
This is a decent lens for the price and worth the little money they cost if you can't afford $10,000 plus for a high quality telephoto lens of this size. I would forget about the 2X doubler because as others have said, it further reduces the speed of an already very slow lens with such a high rate of magnification that a knat landing on the lens could cause the picture to blur from movement.
Jun 26, 2011 | Opteka 650-2600mm High Definition...
Hi When I try to take pictures of the moon at night, the all I get is bright light without any detail. The sensor seems overloaded and the image seems smudged. I have tried with the intelligent...
All automatic-exposure cameras try to render the scene as a middle gray. The moon is a small portion of the total image, so the camera concentrates on the sky. In trying to get enough light to make the sky go from black to gray, the moon gets completely overexposed. What you want is the moon properly exposed, even if that means the sky goes completely black.
For a full moon, you want the same exposure you would use at noon on a bright day. If you think about it for a moment, it becomes obvious. The full moon is simply a landscape at high noon. Unfortunately, the camera can't know that.
Set the camera to manual. Start with the "Sunny-16 Rule", which tells you to set the aperture to f/16 and the shutter speed to 1/ISO. So for example, set the ISO to 200, the aperture to f/16, and the shutter speed to 1/200. Look at the result on the screen and adjust the exposure as needed.
That was for a full moon. For other phases you may need to add exposure, but the "Sunny-16 Rule" will still give you a starting point.
Jun 18, 2011 | Panasonic Lumix DMC-LX3 Digital Camera
I live in the Florida Keys and going to try and take some photos of the supper moon tonight. What settings do you suggest for a Sony SLT-A55V. I tried to use my longer lens last night without a tripod...
Take you camera off the automatic exposure setting. Left to itself, the camera will try to make the black sky a middle gray. You want to treat the moon as a landscape under noon sun. If you think about it, that's all it is. The moon is simply a large rock or mountain, lit by the same sun you get at noon. This is where the "Sunny-16" rule comes in. The proper exposure for a full moon is an aperture of f/16 and a shutter speed of 1/ISO. For example, if your ISO is set for 200, the shutter speed should be about 1/200 second. Any equivalent exposure will work as well, for example f/11 at 1/400. You can then review the picture on your display and adjust accordingly. The sky will go pure black, but that's okay. You're not taking a picture of the sky, but of the moon.
Mar 20, 2011 | Cameras
Evening My Canon 400D Eos SLR will not take photos in manual mode setting , goes through the motions of shutter open and close but when it comes to viewing the picture on the lcd display ( nothing there)....
Okay lets put some "joy" back into your photo's The reason you aren't getting anything is because your shutter speed is to fast. Your setting I think you are trying to say are F5.6 100 ISO and 1/100 shutter speed "M" manual setting. Actually if you looked closely on your "nothing there" there would be something. Anyway, Moon shots as simple as they look are anything but simple. The earth is moving and you are trying to take a still shot. I don't know where you are on this earth and every star system is different. Starting with a good solid tripod, next the lens needs to have a great enough focal length so the moon covers 2/3rds of the view (first shot) ISO 100 is good. In manual mode look at your light meter try to have your F-stop at F8 or F11 and adjust the shutter speed for proper exposure, you may need to adjust your aperture up or down once you have a "normal" exposure either increase your shutter speed or preferably stop down the lens two stops.
Your camera will meter down to 30 seconds if it goes below this then this is where you take your start (first shot) meter reading and count how many stops of light you require beyond 30 seconds.
For practice though attempt to stay within the 30 seconds by increasing the aperture but not wide open say F8 is as low as you go, need some speed adjust the ISO up to ISO 200 then ISO 400 don't go beyond this because other factors come into play at this point. the thing is you need to establish a metering point then stop down two stops and see what you have as far as exposure.
I know this may all sound really complicated but it's not the most important thing is to have a good tripod use F8 as your widest aperture don't increase beyond ISO 400 and keep your shutter speed at 30 second or above. Another problem that will occur is focus actually the lack of, your camera requires contrast to focus one you have established this shift the lens into manual and recompose your scene. What we aren't done yet don't touch the camera when your release the shutter. Use the 2 second time delay to give the camera time to stop vibrating after the shutter has bee depressed remove your hand DON'T touch it until the picture is finished. If it were me I'd be looking at doing a few landscapes at night to get use to all this stuff then tackle the moon so to speak. In the mean time here is a picture of The Fork Of the Thames in London Ontario Canada.
Picture here
Jan 14, 2011 | Canon EOS 450D Digital Camera
I'm having problems with the settings on my Canon EOS 400D. When I take pictures in AV mode I can get quality pictures but in TV or M modes the pictures always come out so dark even when taking them...
You need to understand the relationship and teractivity of aperture, shutter speed and iso. In Av mod, you choose the aperture and the camera makes thw shutter speed agjustment, In Tv mode, you set the shutter speed and the camera makes the aperture adjustment, In manual, you have to set both shutter speed and aperture manually. If the ISO mode is set to AUTO, the camera chooses the sensors sensitivity to light automatically. Change to specific ISO
(200-400 for daylight and 799-1600 for night). Take a picture in AV mode and note what shutter speed the camera chose. Then switch to TC mode choose the same shutter speed and see if camera chose the same aperture(f-stop) you chose in first shot. Change to Manual and choose same f-stop and shutter speed the camera chose for you in the other modes. Compare all three photos. They should be almost if not exactly the same exposure wise.
In Tv mode choose a dlowers shutter speed, In Manual choose a combo of slower shuuter and wider f-stop(smaller number). Read your manual.
Jan 02, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Aperture Priority Mode - an undocumented feature
In addition to the "quirks" of the Landscape and Aperture Priority Modes (neither mode works as documented!)..... The camera also behaves differently in full Manual Mode (it changes the settings, whether you want it to or not to compensate for available light)... At lower Zoom Levels, the camera will adjust the Shutter Speed Only, to try and compensate for available light... For example: with the Camera preset to F5.6 Aperture, and 1/48 sec. shutter speed, the camera will adjust the shutter speed between a range of 1/30 to 1/291 sec, to try and "auto expose" the shot for lower or higher light levels, even though you're in manual mode. At an Aperture Setting of 2.8 and 1/48 of a second, the number of internal steps in shutter speed the camera is willing to take, increases dramatially - for example: shutter speeds up to 1/600 of a second, even though you have the shutter set to 1/48 in manual mode. The camera WILL NOT attempt to adjust the Aperture to compensate for proper exposure in available light (OR WILL IT??).... It depends on your Zoom settings! It won't if your're near to full wide angle, but IT WILL if you are using the Zoom. Once you cross some unknown zoom threshold (it doesn't have to be at full zoom), then the camera begins to change both the Aperture and Shutter speed to compensate for available light, even though you are in "Full Manual", versus Auto Exposure Mode. In Manual Mode, (as in Aperture Priority Mode), the amount of change the camera is willing to make to your settings, appears to be related to a preset number of internal steps, with the number of steps dependent on both Aperture and Zoom Settings, before it gives an EV Warning for Over or Under Exposure conditions.... The type (shutter speed only for wide angle, shutter and aperture for zoom) and amount (number of internal "steps" it takes to increase/decrease shutter speed and increase or decrease aperture), is dependent on the amount of zoom you are using for the current shot.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Double-exposures
DMC-FZ10 and an external flash with a manual trigger can do it. Just set a high aperture number, slow shutter speed, take the pictures...change camera direction a little..then as soon as you can, re-trigger the flash manually.
Sep 07, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic Lumix DMC-FZ20 Digital Camera Logo
149 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Jay Plesset
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
