Question about Lexmark Office Equipment & Supplies
Lexmark W820 980 Service Duplex Comm error code
  • 97 Answers
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
SOURCE: OKI C5900
we have the same problem but with Oki c5500
Posted on Jun 21, 2008
Touch2Heaven
  • 145 Answers
SOURCE: 980-fatal-error
Service call 980:Error
Cause: Error by media clinging to the fuser
Error description: Media has clung to the fuser.
Solution: Power OFF. Replace the fuser unit.
Posted on Nov 19, 2008
SOURCE: SERVICE CALL ? 980 ? Fatal Error
I was able to reset my Fatal Error 980 code on my C5800. There is only two wires coming from that connector and not four at the bottom of the fuser. That is pin 2 and 3. 4 and 5 is still the fuse but there are no wires there, just the 2 pins. What you have to do is make a fuse by connecting pin 4 and 5 together with a piece of wire and break the wire after a few seconds after powering up. This will reset the Fuser counter back to 100%. DO NOT DO THE NVRAM RESET, THAT WILL ERASE YOUR NETWORK FEATURE. Here is the step by step of what I did.
1)Take out the Fuser and lay the two blue levers flat and remove them.
2)remove the two silver screws and separate the casing.
3) Remove the two black screws from the connector at the bottom of the fuser closest to the edge.
4)Unravel and loosen the wires so you can pull that connector out a few inches so you can get a couple of wires in there. You will see what you need to loosen to get the connector out far enough, really easy.
5)Insert a wire into each of the two holes on the back of that connector. Its pretty simple to see where they go, 2 and 3 have wires going in, 4 and 5 dont which is the fuse. After you get the wires in the 2 holes, check for continuity from the end of the wires and the terminals if you can. Make sure the wires are long enough to hang out the case. Use the thinnest wires you can find.
6)Run the wires out of the case and put the case back together and put the fuser in. Twist the two wires together and power up the machine. As soon as you here the first motor,which is about 5 seconds, pull the wires apart and BAM, you just reset the fuser back to 100% and cleared the "980" Fatal Error. You could always put a miniature fastblow fuse in instead of using the wires but that would be tedious to me.Good luck
Posted on Jul 12, 2009
SOURCE: faxman.comm win error
i have a x3450 printer i can't get faxman.comm off my computer. i can't use it please tell me how to remove.it is causing me a promblem.
Posted on Aug 10, 2010
I have a Lexmark T634N printer. I have problem with it recognizing the 2nd tray and the Duplexer. I have replace the motherboard, replace the connector on the printer, updated the software on the printer...
Hi
You need to be sure that you have added the duplex unit and tray unit in the windows driver. The "device" tab will allow you to add the duplex and tray to the printer.Also there is a self-docking connector on the bottom of the printer that connects to a similar connector on the duplex unit. Check that these connectors are not damaged by lifting the printer off the duplexer and inspecting visually . You can try removing the duplex unit altogether and just install tray 2 below the printer with no duplex unit at all to see if the printer sees tray 2. If it does see it then the problem is in the duplex unit. If the printer can't see the duplexer it also wont see tray 2 which is below it. Simply re-plugging the units might fix it too so give that a try.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 04, 2011 | Lexmark T634 Laser Printer
I HAVE GOT AN ERROR 900.00 SERVICE ON MY LEXMARK T640 PRINTER. WHAT DOES IT MEAN?
This link explains error 900 on a Lexmark printer. It includes troubleshooting steps in trying to resolve the issue.
http://www.marketpoint.com/article.cfm?id=100
If problem persists, contact the manufacturer.
I hope this works for you!
Thanks.
Monkey
"Understanding explains better..."
Jan 21, 2011 | Lexmark T640, T642, T644 250-Sheet Duplex...
Lexmark X646e All-In-One Laser Printer Paper jam duplex Out lexmark used to print duplex but after techs took it apart and cleaned it, it doesn't print any more. The paper prints one side and the gets...
Open left door. Remove screw covering the white plastic cover. Observed the white gear that you will now see. Make sure that it is not broken. If this gear is broken, you will not be able to duplex. What is the full code numerical code of the error?
Nov 09, 2010 | Lexmark X646e All-In-One Laser Printer
X945e 980.03 service finisher comm - how to fix the issue
The 980.03 communications error on Lexmark X945e indicates a communication problem with the Finisher Controller Card. This usually requires a service call as it deals with cable connections from the finisher, from the bridge unit, the finisher controller card assembly, or the engine card assembly. But try to unplug the printer from power source, replug after 30 seconds. Plug printer straight to power outlet in the wall. Bypass any surge device, power strips or uninterruptible power supply (UPS). These can cause false error messages. If problem continues, I strongly suggest you contact Lexmark technical support or your authorized service provider for assistance. Thanks.
Aug 26, 2010 | Lexmark X945E Printer
I have a Lexmark E450dn displaying a "935.15 Service Printhead" error message and will not print. Seeing as Laser Printers do not have printheads, instead they have Scanners and Fusers, which should I be...
a 935 printhead error is a fatal error which means the scanner motor has failed to initialize. the term printhead is short for printhead scanner. this error can be caused by either the engine board or the scanner % wise 40%engine board 60% scanner ive done 120 repairs on lexmark laser for the last 7 years trust me one of these is the problem
Jun 16, 2009 | Lexmark E450dn Laser Printer
The duplex option is not working anymore on my Lexmark C760
Check in printer menus if duplex is recognized by the printer, is not try to see if connector between printer and duplex is not damage. I had this same problem and had the replace the connector. damaged it connecting the printer to it.
Mar 27, 2009 | Lexmark C760dn Laser Printer
Rx comm error 200082 on receiving fax Ricoh aficio 222SF
I have Dell Monolaser MFP1125, can not send and receive fax
Aug 04, 2008 | Office Equipment & Supplies
Optra color error code 993
Error Code - 993 Duplex Comm. Failure Communications between the duplex unit and the printer have failed.
Jun 24, 2008 | Lexmark Office Equipment & Supplies
Faxman.comm win error
Apr 15, 2008 | Lexmark X3350 All-In-One InkJet Printer
452 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
