Question about Panasonic Lumix DMC-FZ20 Digital Camera
Double-exposures Anyhow...shooting with a regular film camera I often shot intentional double-exposures to create certain effects. Is this even possible with a digital camera? I would guess the answer is no, but I'm hoping there will be a way I can do this.
    Master:
  • 903 Answers
DMC-FZ10 and an external flash with a manual trigger can do it. Just set a high aperture number, slow shutter speed, take the pictures...change camera direction a little..then as soon as you can, re-trigger the flash manually.
Posted on Sep 07, 2005
No film in but it says there is
needs repairing at a qualified shop
sounds like the film advance motor died
Apr 21, 2013 | Nikon N6006 35mm SLR Camera
My prima cannon camera do not rewind after the film is consumed.
Hi...I just got this similar camera from my dad...I'm wondering can I take multiple exposure shots using this camera.
I'm still a beginner. But I wonder can I take shots like this
http://www.wanderlass.com/others/photography/what-is-film-swapping-in-lomography.html
Feb 01, 2011 | Canon Prima BF-80 35mm Point and Shoot...
Can't roll film for double exposure.
After taking the first shot, hold down the Multi-Exposure button while cocking the film-advance lever. This cocks the shutter without winding the film. You can continue to do this for as many exposures as you want. Just don't hold down the M-E button while cocking after the last exposure.
The Multi-Exposure button is the button on the front of the camera just below the shutter release button.
Apr 11, 2010 | Vivitar V3800N 35mm SLR Camera
How do you take double exposure shots with this camera?
That camera was never designed to take double exposures. You could shoot the whole roll with your first exposure, then carefully and exactly load it again and shoot the second exposure, but everything must line up exactly to even using the same starting sprocket hole to line things up. Not really easy or cost effective, but it can work if you are careful.
Nov 13, 2009 | Canon EOS Rebel X 35mm SLR Camera
Why is the film automatically rewinding around 15 shots instead of the end of the 24 shot roll? The batteries are fresh.
the roll sensor is not reading the silver code on the film roll.
Open the camera when you have no film in it.
Clean the film roll slot where the "fingers" are.
These fingers touch the case of the film roll to determine the film type, which includes the number of exposures. You nmay have to "adjust" the fingers so that they make good contact with the film roll case.
Look at different rolls of film, notice the silver blocks are different. If the roll has a "dent" on it, it can't be sensed correctly.
Hope this helps!
Sep 15, 2009 | Canon Sure Shot Classic 120 35mm Point and...
Pentax SF10 Camera -- double exposure
If you press the film release button like you are going to rewind exposed film you may be able to activate the film advance lever to cock the camera so you can take another picture, and the film should stay on the first exposure allowing you to re - expose it. I would underexpose each image 1 F stop because.you are exposing the same film twice. Double exposures are always an iffy proposition and anything can happen. After the second exposure cocking the film advance should allow the film to advance once again. You might test this on the final pictures on a roll in case the camera won't start advancing the film after you try it. This way you won't blow a whole roll worth of pictures testing it.
Apr 12, 2009 | Pentax PZ-70 QD 35mm SLR Camera
Black & White shots from Nikon D80
You would be better off shooting in regular mode and converting to B&W using photoshop
Jan 03, 2009 | Nikon Speedlight SB-22S TTL Flash
I seem to be getting double exposure on most films, I brought this camera new in Duty Free New Zealand in 2001 it went well until 2003
Hi
Sounds like the continous shooting option has been enabled.
I would check this first.
Hope this helps
Oct 19, 2008 | Cameras
Forget how to take double pictures.
Hey xplaur,
To take a multiexposure photograph you should first expose the film, and then push the multiexposure button which is on the front of the camera on the top left when you are looking at the front of the camera. After you press this button advance the winding lever to set the shutter, and since the multiexposure button was pressed this shouldn't wind the film to the next frame. Now take your second exposure, and if you want to make another exposure on the same frame repeat the process. Keep in mind that every time you expose a single frame after the initial exposure you will be doubling the exposure on the frame. I usually under expose each exposure by one third on a double exposed frame. If you do more than two exposures I would underexpose each exposure by even more. Multi exposures are fun but tricky, and I would suggest you experiment and have fun with it. I will also say that black and white film is much more controllable and forgiving when it comes to this than color film. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 31, 2008 | Vivitar V3800N 35mm SLR Camera
Camera not working-please help
No promises but if you take a roll of film that is already light fogged etc. and load it into the camera. Let it wind as normal. Now we need to work quickly: Press the rewind button. While it is winding OPEN THE BACK. It won't rewind very long because very little film is out of the cartridge so be ready. This will fogged a bit of the film but it does seem to clear the error. You can still shoot the roll if you just skip the first few shots.
Dec 06, 2017 | Fuji Zoom Date 60 35mm Point and Shoot...
Panasonic Lumix DMC-FZ20 Digital Camera Logo
71 people viewed this question
Top Panasonic Cameras Experts
skyblue007
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
