Question about Olympus Camedia C-3040 Zoom Digital Camera
3040 Issues I just got a 3040 and had a question about a couple of things I noticed (I've never owned an Olympus digital camera). When the camera is powered up, the noise from the lens coming out sounds awful (like a grinding noise). Is this normal? It zooms in/out without any problems but it just sounds odd. It just doesn't sound smooth... Is a stuck pixel on the LCD enough of a reason to return it for a new one? The pictures do not show the stuck pixel but I am concerned that a new and expensive camera would have such a problem right out of the box...
    Master:
  • 852 Answers
A stuck pixel on the LCD is quite common. I have one on my 2020z; lot of people here would tell you the same thing. Long as it's just one, I wouldn't bother trying to get new camera. Far as the lens extension sound: It is a little loud, but a *grinding noise* doesn't sound normal. Go to a store and pick up another one, see if it makes the same sound. If not, you may have a bad camera.
Posted on Sep 07, 2005
Olympus camedia c-3040 zoom how to delete pic
Judging by your explanation, the photos are on your sd digital memory card rather than the internal memory.
Since you are unable to delete just those 15, it sounds like you might have accidentally enabled the "protect" function.
Get out your manual (or download a new one) and read about how to protect/unprotect photos, and also read about how to format your card in camera - something you should do on a VERY regular basis for the health of your memory card.
While you have the book out, read ALL of it - twice! You'll be amazed how much you'll learn.
Oct 03, 2009 | Olympus Camedia C-3040 Zoom Digital Camera
I can't upload pictures from my Olympus Camedia C-3040 Zoom
Try deleting the problem picture..then attempt to upload again.
Apr 21, 2009 | Olympus Camedia C-3040 Zoom Digital Camera
Left power on
Hey raggedarmi,
Leaving the camera on for an extended period of time should not cause the camera to no longer turn on. Make sure the lens cap is not on the camera when you turn it on, and make sure you are not using manganese batteries because they don't work with this camera. The camera will not operate while connected to a computer so make sure you are not connected to a computer. The camera might be in sleep mode so try pushing the shutter button or hitting the zoom lever. If none of these options work try putting in a brand new set of AA batteries and see if that works and if it does it probably means your rechargeable batteries are bad.
Sincerely,
Allan
Go Ahead. Use Us.
May 14, 2008 | Olympus Camedia C-3040 Zoom Digital Camera
Battery comsumption
yes lithium is only suitable for digital cameras.
please make a one time investment in buying rechargeable LIMH batteries.
its good for u
May 12, 2008 | Olympus FE-210 Digital Camera
Macro lens for the 3040Z
I have very good experience with the original Olympus Macro Conversion lens with the CLA1 adapter. No visible distortion and no loss of contrast. The only problem I can imagine is the lighting of it all. You need to come real close! The internal flash of the camera will not work properly because the "huge" macro lens will cast a shadow. Some kind of external light source will be needed and manual corrections in the white balance have to be made too. The 3040 is a fine camera and I use it at least twice a week, but it still lacks some of the features of my old OM4 camera! Think about the easy focusing (manual) and the use of a ring flash! Because that is what you need.
Sep 11, 2005 | Olympus Camedia C-3040 Zoom Digital Camera
Lens Protection Size!!!
Get a CLA-1 lens tube. It screws into the camera body. The other end accepts 43mm accessories. Put on a 43-49mm step-up ring. Into that screw a 49mm UV filter. (The step-up ring is needed to separate the filter from the extended lens.) Leave the UV filter on at all times. Throw away the lens cap.
Power solutions ?
My backup for my rechargeable batteries is the Maha Powerbank, which is a small portable battery which last four hours. To be honesty I have not fully used it seem have not gone throught my two four sets of rechargeable batteries in a days shooting, yet again it is my backup. It been review on this website.
Sep 07, 2005 | Olympus Camedia C-3040 Zoom Digital Camera
If I take hi-res pictures with the 3040 how much can I manipulate the image on my PC to zoom in while still maintaining quality?
Digital zoom in the camera means nothing. You can't create detail that isn't there. Enlarging and sharpening on the PC can produce much better results than in-camera digital zoom - no more real detail, but a better illusion of detail by enhancing edges. You can print up to about 8x10 with the 2100 or 11x14 with the 3040, but a zoomed in 2100 8x10 will probably be a more spectacular picture than the 3040's 11x14, unless you can get equivalently close to your subject. Also, the more precise viewfinder of the 2100 can make up for the difference in resolution. With the 3040, you are more likely to need to crop to print your desired view (unless you can use the LCD), since you can't see exactly what you are going to get when using the optical viewfinder and will tend to get more periphery than you want.
Battery
I have the Maha c204f charger and two sets of 1600mA Powerex Batteries. Over the past two months I have found that this is a perfect set up for my use of my Oly 2040. The batteries fully charge in under 3 hours, don't have a "memory effect", can be left in the charger without damage, and will take over 100 pictures with liberal use of flash, LCD, reviewing, etc. The whole set-up will cost you about $50 from
Olympus Camedia C-3040 Zoom Digital Camera Logo
82 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
