Question about Motorola Mobility H350 Wireless Headset
Constant beeping / connect/ disconnected
While the phone and blue tooth are on but not in use the phone reads connect disconnect & it beeps in & out killing the battry & will only stop if i shut the phone off for a minute & then cut back on.
  • 282 Answers
You need to turn off your bluetooth on your phone,cause as long as its on,its going to try to reconnect to your phone
Posted on Oct 08, 2008
Turn off beeping bosch wfl 2060
All you need to open the control panel and remove the connection to the buzzer unit.
If the washer works fine , the buzzer can be disconnected
Jul 03, 2012 | Bosch Axxis WFL 2060 Front Load Washer
My Plantronics Blue tooth earpiece gives a constant "three beep" sound. I can hear the other person on the phone but the constant beeps at the same time. The beeps happen also when the phone is...
The three beeps usually indicate low talk time. If you have tried turning off and on your headset and still have the annoying beeps, then there is a problem with the device. You'll need to contact your retailer or Plantronics (800-544-4660 x5538) for warranty replacement. If it's out of warranty, check out our website Headsets Direct for the latest in Bluetooth headsets.
Good luck from Headsets Direct!
Jul 28, 2011 | Plantronics Voyager PRO Bluetooth Headset
How do you connect it to a nokia 6300
To connect a jabra 250 to the Nokia 6300: On the Nokia go to menu > settings > connectivity > bleutooth = select and the next line = visible
On the headset when it is off > push the upper button for ± 8 seconds until the lamp is burning constant and release this button.
Choose on your Nokia on the same bleutooth menu > search audio.... It will be pairing in a few seconds . It will ask if it is ok to make the connection. The password is "0000" and push on "yes"
I hope you cann understand my english, I'am dutch.
Nov 17, 2010 | Jabra BT250 Consumer Headset
I cant get my blue tooth to connect to my blackberry
MAKE SURE THE BLUE TOOTH HANDS FREE OR ANY OTHER DEVICE IS IN PAIRING MODE. ( THE PIN TO PAIR A BT HANDSFREE LL BE 0000 )
ALSO FOR INCOMING BT BEEP RECEVING
FROM MEDIA. CLICK MENU AND SELECT. RECEIVE VIA BLUE TOOTH.
Feb 24, 2010 | Cell Phones
Bluetooth will not stay connected on my 2006 BMW z4
Depending how far of a range your getting, between your razr and your blue-tooth is important. Any range of 30ft or over is less likely to connect/search/and or pair with any capable blue-tooth device.
Try pair the two devices again, but remember to save the trusted blue-tooth to your device so that disconnection can be prevented only by your command.
If your blue-tooth has a short, or battery is extremely low then that TOO can cause disconnection.
Hope this information can be of a benefit to you. Thanks.
Mar 16, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Hands free stuck on
Go to your Blue tooth settings and turn it off. Good Luck It might ask or give you a drop down menu to connect or diconnect device. you would want to disconnect device. Good Luck
Feb 15, 2009 | Innovage Touch-Panel Phone 1507102
How do I disconnect my phone from another Blue Tooth device?
Go to active devices menu in the bluetooth menu and delete any devices listed there and start find new device ... it should work fine ...
Oct 08, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Headset no longer working
You need to remove the device from the phone directory. Turn off the phone and the device. Wait about a minute then turn on your phone. After the phone is ready for use, turn on your bluetooth and proceed to pair the device with your phone. The phone should recognize the bluetooth and you'll be able to add it once again to your list of blue tooth devices.
Jan 02, 2007 | Motorola Mobility HS850 Consumer Headset
Why does my camera continuously beep?
The serial cable supplied with the camera (RS232 serial cable) is not securely connected. Disconnect the cable from the camera and reconnect it -- the beeping should stop. Turn the camera on, then power up the computer. You will hear two short beeps, and the characters "PC" will be displayed in the LCD window. This indicates a proper connection with the computer.
Sep 21, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
Motorola Mobility H350 Wireless Headset Logo
171 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
