No HDMI detect
Samsung LE46F86BDX/XEU
I’m using all hdmi ones on the xbox 360 ones on the PS3 the other on Yamaha DVD-S1700
On the old loveable scart leads when you turned on an appliance the auto detect would turn the TV to the right station however I don’t get this with the HDMI leads, turn on any one and the TV will sit on the same station I have to use the source button on remote one by one go to the right station depending on which HDMI you want to use, has this TV not got an auto detect HDMI or have I not set-up correctly have tried to sort out but to no use.
Also I have programmed the remote so I can use the DVD player with the TV remote and I want to program the 3 digit remote code for a Sony AV STR DB 780, which I can’t find, any help would be, appreciated many thanks Nigel.
SOURCE: audio via hdmi
I had the same problem with the same configuration. In addition to the HDMI which is (DVD and Audio OUT only by the way) you need to connect the TV to the DVD through a high quality SCART cable as well. Remember to connect the SCART cable only while both the TV and DVD are switched off. To get the TV sound out of the DVD surround sound you need to click the FUNCTION key on the DZ230 remote a couple of times till you get the word TV on its screen, this is when you should hear the TV sound coming out of your surround sound as expected. Good luck.
Posted on Aug 25, 2007
SOURCE: no sound through ps3 hdmi
on ps3 go to settings sound and change sound out put to hdmi you will see 3 different options
Posted on Nov 07, 2008
gymhasafit
  • 31 Answers
SOURCE: Sharp Aquos LC-46d65U HDMI connect
First off a little tip that manufacturers don't tell you is that you HAVE to TURN OFF the POWER to ANY UNITS that you are Connecting to via HDMI!!!!!!! If not you can short out the Inputs!!!!!!!! HDMI is usually Automatic, But sometimes you need to go into the Menus on all Devices to the HDMI section and write down their settings and compare them. Any definition that you are not sure of check the Manual or Google it! Match all the Settings (there won't be Much!) Hopefully the Inputs were not Damaged it only takes one time to short it out and then the Repairman makes a few bucks! Good Luck!
Posted on Apr 29, 2009
gage8405
  • 5 Answers
SOURCE: TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Posted on Jul 03, 2009
SOURCE: ps3 hdmi format not supported
Had the same problem setting up my ps3 with a 32" Vizio. What solved it was when i reversed ends of the HDMI cable
Posted on Nov 06, 2009
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
Jan 10, 2014 | Video Game Consoles & Games
How do I get sound from my Xbox to my monitor via a hdmi lead - DVD lead
As far as I know, the DVI cable can't send sound, so if you could use a only-HDMI cable or SCART cable, that should give you both picture and sound.
Nov 11, 2012 | Microsoft Xbox 360 Console
I have a 27 inch syphonic flat screen tv and I'm trying to get it on an input channel in order to play my Xbox 360
I dont have a 360 so cant be 100% sure this will be helpful. i have a PS3 and to get it to run on HD after using it on SCART, you need to plug both the HDMI and SCART leads in simultaneously and go into the system visual settings and change it to a HDMI port.
after this you need to jsut unplug the SCART.
im hoping its a similar issue but just swapping the PS3 menu's with the 360 one.
Oct 06, 2012 | Televison & Video
Jul 03, 2009 | Televison & Video
TV wont detect HDMI Devices except a pc.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
Jun 18, 2009 | Televison & Video
Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
May 18, 2009 | Yamaha HTR-6130 Receiver
LG 42PC56 ps3 best settings?
Your PS3 should detect when you set up a HDMI connection then just follow the onscreen instructions. If it does'nt unplug the HDMI cable and use the scart cable. Then unplug the scart cable and plug in the HDMI cable your PS3 should detect this HDMI cable and it will notify you on screen.
Hope this helps
Terry
Apr 06, 2009 | LG 42PC5D Television
Trying to connect playstation 3 to my tv having no success
For real try this:
Turn off the tv as well as the ps3 (to where the red ps3 light is on); Then just hold down the power button in the front for like 15 seconds or so, at least until you hear a beep. Then turn the Tv back on, and hopefully once you get the tv back on the correct hdmi input, you'll see that little message offering you to switch to optimum settings.
Hope it works. Did for me.
Feb 17, 2008 | JVC LT-37X776 37 in. LCD HDTV
XBOX with HDMI
hdmi only works on the premium, older ones don't support it, there you should use scart
Dec 01, 2007 | Microsoft Xbox 360 Console
Open Questions:
Televison & Video Logo
206 people viewed this question
Top Televison & Video Experts
Electro Med Services...
