Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Pool of water on floor at least once per week
Help> My wife is going to through me out if I can't solve this problem. I was told the problem was a plugged filter in the fridge itself. Where is it located? I have an inline filter for water entering the fridge, it is okay.
  • acrc Sep 16, 2008
    I have a problem with the refrig leaking at least every other day or so. Ice builds up in the bottom of the freezer side also.
  • 76 Answers
See if your door rubbers close properly and if so look at the back,there is or should be a bucket on the compressor,see if its over flowing...
Good luck.....
Posted on Sep 09, 2008
I added salt and am running just the pump for 24 hrs per instructions but when I turn the thing at top of pump to release no water comes out. Is this normal??
i am not completely familliar with this system but i am pretty sure that opening the relief valve should allow water to exit providing all the valves are open. as for green pool, if the water is not moving, you will not be able to clear the water.
Jun 26, 2015 | Intex Automatic Salt Water System for ...
Tip
Three tips for a cleaner pool
Having a pool at home can seem like a really awesome thing, but if its not cared for properly it can turn into a nuisance. There are a few small things that you can do on a weekly basis that will keep your pool clean and fun to play in. But keeping it clean can be very time consuming and physically taxing.
In movies you always see the pool boy skimming the top of the water of a pool with a long pole with a net on the end. What this does is it catches all the leaves and other stuff floating in the water. You will want to do this fairly often because when you leave stuff floating in the pool they will sink and then become close to impossible to get out and wreak havoc on your circulation system.
In addition to build up of leaves or branches from trees around the pool there will also be build up of chemicals that will make the water not be clear. To get rid of the chemical build up you are going to want to vacuum the pool. Whenever you vacuum make sure that your check the filters and clean them if you have to, for a clean pool you should vacuum once a week.
Once you have skimmed and vacuumed you are almost done! To make sure that you don't get algae build up you want to scrub the sides and floor of the pool. What you use to scrub the pool is dependent on what your pool is made out of. If the walls are plaster lined concrete you will want to use a stiff brush while for fiberglass you will want to use a softer brush so you don't ruin the walls.
on Jan 16, 2014 | Pool & Spa
Tip
Basic Swimming Pool Care
<p>Basic Pool Care Tips<br /> <ol> <li>Test chlorine and pH at least 3 times per week. Have a comprehensive water test every 6-8 weeks at your local pool store. There is generally no charge for this test.</li> <li>Operate pool equipment a minimum of 6-8 hours per day during winter months and for 10-12 hours per day during the summer for greatest overall benefit.</li> <li>Brush the pool walls and floor a minimum of once a week.</li> <li>To prevent damage to pool equipment make sure the water level never drops below the opening of the skimmer.</li> <li>Lubricate backwash valve "O" rings on sand and DE filter four times a year. Lubricate pump lid "O" ring periodically with Lube specifically designed for use with swimming pool equipment.<br /><br /><img src="water_1.jpg" /><br /><br /></li> <li>Test pH and add muriatic acid as indicated to maintain pH between 7.4 - 7.8. Never add more than 1 pint of acid at a time and wait at least 1 hour between treatments. Always add muriatic acid by dispersing into pool water opposite the skimmer and disperse as far away from the wall of the pool as you can safely reach. Use care not to drip acid or any chemicals on deck as it will cause deck etching and staining. Do not pour acid over steps, benches, or pool light. Make sure water is circulating.</li> <li>Clean waterline tile with cleaner a minimum of once a month during peak season.</li> <li>One month after initial pool start-up, add stain and scale inhibitor on a regular basis.</li> <li>Always follow manufacturers instructions on product labels.</li> <li><b>NEVER ADD WATER TO CHEMICALS</b> - Add chemicals to water.</li> <li>Always wait one (1) hour between adding different chemicals unless otherwise directed. <ul> <li><b>Filters:</b> <ul> <li><b>Sand Filters:</b> Backwash once per week</li> <li><b>DE Filters:</b> Backwash once filter pressure increases 8-10 psi above your "clean pressure" noted at start-up.</li> <li><b>Cartridge Filters:</b> Need to be taken apart and elements need to be cleaned once filter pressure increases 8-10 psi above your "clean pressure." This cleaning should be done at least a minimum of twice a year.</li></ul></li></ul></li></ol>
on Dec 21, 2010 | Pool & Spa
Pump wont turn on
make sure heat maintain is off if ok new pump
Apr 04, 2014 | Pentair Pool & Spa
My pool is GREEN! What do I need to do?
You can try using shock or liquid chlorine and bring the chlorine level back to 3 ppm.. 1 small bag can treat up to 10,000 gallons.. After that, raise the cycle time on your chlorinator to maintain that level...
If you do not want to use those chemicals, raise your pump cycle time to 12 hrs and your chlorinator to 10 or 11 hrs and should see some results within a few days... The chemical method should yield faster results... Good luck...
Aug 22, 2011 | Intex Automatic Salt Water System for ...
Two weekends ago I came back from a 4 day trip to a green stincky pool. Low flow, we cleaned the filter and scrubbed the algae, by morning a beautiful sight. Yesterday after not look at the pool over the...
You should definitely shock however the best solution for solving an algae problem, which is what you have, is using a product called
Algimycin 2000
this will clear up your pool in about 24 hours
US Parts Center
Aug 18, 2011 | Intex Automatic Salt Water System for ...
The Whirlpool side-by-side refrigerator, model ED2KVEXVQ01 occassionally leaks water onto the floor. There could be a cup or more of water, but the problem has occurred a few times, but may go weeks or...
sometimes we overload our refrigerators and the doors will not close properly, next time you notice the water see if your doors are closed tightly and the seals engaged tightly. My wife has this habit of not checking after she has put away the remains of a big dinner or BBQ and I find drips of condensate water all over the floor as a result. The defrost collection pan overfills and the excess water goes on the floor. once the doors are closed properly the problem goes away.
Aug 03, 2010 | Whirlpool ED2KVEXVQ (217 cu ft) Side by...
Have put 280 lbs of salt in my 9300 gaoole pool and still getting the low salt light. What is the next step? Just set up the pool last week but the chlorine converter is from late last year. It did not...
By my calculations you are about 50 lbs over the requirement. Which code are you getting? I'm guessing code 91. Have you removed and cleaned the electrolytic cell from the chlorinator? I get lots of calcium on mine from hard water from the well requiring a cleaning at least once per week. If you get this working and get a warning that you now have too much salt you'll need to drain off water and re-add to get the salt content correct.
Jun 04, 2010 | Intex Automatic Salt Water System for ...
I want to know how to solve this,,,could you please help me?
j=(72/60) floors upward per second
m=(48/60) floors downward per second
j=m at 20 seconds. At 20 seconds they'll both be at floor 42
Jek will go up 24 floors in 1/3minute and maitress will travel down 16 floors in 1/3minute.
Jan 30, 2010 | Microsoft Troubleshooting Your Web Page...
CLOUDY SALT WATER POOL
salt does not solve your problem.
People do no realize that all the salt does for you is that it eliminates having to pour regular chlorine in.
Everything else stays the same as a normal pool with just plain ole h2o
The dilema is that intex filters are to small for the job that needs done especially in your case now that you have the dreaded green monster
your solution is to first get it cleared up
shock your pool with 2 gallons of liquid chlorine and then filter filter filter
You will need to brush the dead algea and vaccum once or twice a day for a couple of days and you must clean that cartridge 3-4 times a day with the garden hose
you will be surprised how much green it will trap
once pool starts to clear and the chlorine level starts to come back down from Mars you can start using your generator again.
you will need to find the amount of time thatorks for you but 3-4 hours will not cut it in the hot weeks
Chlorine consumption is due to #of bathers, heat ,sun, rain so any given day will dictate a different amount of generation needed keep it high so you do not get algea again about 3.0
you also got algea because you were not stiring up the pool enough you again need to filter filter filter every day
try to find some of my other postings with more specifics
Aug 13, 2009 | Intex Automatic Salt Water System for ...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
41 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
