Question about Fujitsu LifeBook E7010 Notebook
LIFEBOOK E7010 Power comes on cd and hard drive show but no picture also i get three beeps one long and 2 short.
    Genius:
  • 1,027 Answers
3 beeps is generally a video card problem. Unsure if your laptop has separate video or if it is imbedded on the board, first make sure ram is fully seated in socket
Posted on Sep 02, 2008
Acer aspire m3640 PC power comes on, give three beeps but no display
One Long and Two Short Beeps
video display circuitry issue
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
Aug 05, 2012 | Acer Aspire M3640 Drivers Recovery Restore...
I have a fujitsu siemens lifebook E7010 laptop and the problem is this : When I switch on power the system goes ON but with a black screen and the small LCD is showing the start logos CD player is working...
This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
Jul 22, 2011 | Fujitsu LifeBook E7010 Notebook
Please i use a fujitsu laptop E lifebook. When i boot the system on but gets a black screen. i tried taking out the hdd and still the problem persisted. Some times when i continually boot for couple of...
I have to tell you that 1 long beep followed by 2 short beeps are generated from bios for vga errors... This means that you have to get your laptor at the technician as sooner as posible in order to check the vga part of the motherboard for ventilation problems (that's the best solution for you) or for motherboard replacement (I don't think that this solution is very comfortable, since it will cost as a new laptop)
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jun 26, 2010 | Fujitsu LifeBook E7010 Notebook
I have a Fujitsu Siemens Lifebook E7010, and smotimes it work great, but somtimes it will not start, there ar just 1 long beep and 2 short beep tones. pleas help
check for updates on fujitsu web.. it seems you have to flash the bios.. (when it beeps in most cases there is hardware problem... proc, ram, hard drive, or even mother board... check with manufacture if he had post some of the new updates for your laptop
Dec 02, 2009 | Fujitsu LifeBook E7010 Notebook
Fujitsu lifebook n5010 notebook won't reboot i let the battery run out while working. next day, turned on three loud beeps, then three loud beeps then fan runs but no display on the screen. power off,...
Okay, sounds bad.
However, take out the battery from the laptop and remove mains lead. Go and make tea! Then, drink it. Once you have complete this task.
Plug in the AC lead ONLY into the laptop and then try to power it on.
You should see lights on the Hard Disk LED or hear a beep. If you see them but nothing on the screen at all when booting then the capacitor pack has probably gone on the screen. This is not an expensive part, but you do need to know what you are doing to replace it. Think it time to give it to the workshop or ask IT bod to look at it for you.
Oct 26, 2017 | Fujitsu Siemens Lifebook N5010 Notebook
My Fujitsu Lifebook E7010 suddenly needs a password to go to setu
This sounds like an administrator password. Generally this p/w is left as password. Try password all lower case and try Password with capital P.
Aug 10, 2009 | Fujitsu LifeBook E7010 Notebook
Laptop won't boot up. Only 3 beeps.
listen to the beep heres some information on beep code errors
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jan 25, 2009 | Toshiba Satellite X200-AA3 Notebook
Keeps freezing during installation of xp
Ok, lets start from scratch.
If you can, connect a different CD/DVD drive and change your Boot Priority to boot from here first.
Insert your XP disc, and using the CD's settings, delete all partitions and reformat the drive (NTFS). Start the installation and see what happens.
If you have already done this, or it doesn't work. Check how scratched the CD is. As long as it's not a manufacturer's revovery disc, you could ask someone if you could borrow their XP installation disc.
A good way to get rid of minor scratches on your CD's, is to spray them lightly with furniture polish (with beeswax). Leave for a minute, then using a very clean dust cloth, gently clean the cd from the middle to the outside. N.B. never clean the cd in a circle motion, i.e rubbing.
Hope this works for you.
Tim
Dec 08, 2008 | Fujitsu Siemens LifeBook S7010 Notebook
Dell dimension E310 crash
  • Bad video card - 1 long and 2 short beeps
  • Bad power supply - 1) continuous beeps, 2) non-stop short beeps
  • Bad memory - 3 short beeps
  • Bad Motherboard - 1 long and 1 short beep
  • Disk drive related problem / Video card problem - 1 short beep then nothing happens
May 02, 2008 | Computers & Internet
My fujitsu lifebook e7010 doesnt always turn on properly
If an external monitor is plugged in an the display is ok then the problem is probably an inverter board or bad/loose flex cable to the lcd screen.
If the external display is distorted then the problem is the video adapter on the laptop.
Mar 31, 2008 | Fujitsu LifeBook E7010 Notebook
Fujitsu LifeBook E7010 Notebook Logo
472 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
