Question about Canon NP 7130 Black and White Copier
Double ptinting I have one epson 1845,whenever i want to print, it print double image on one surface.what can i do
    Problem Solver:
  • 16 Answers
Try to clean the upper roller on heating section the final stage of the machines if the image is seen to be of the first objected copy this solution is only if you observed that the image of the previus object (source paper) is printed on the next copy or it repeats printing the lines.
and if it so replace or fix the new oil roler in heater unit.good luck vote me pls
Posted on Oct 02, 2008
Sharp mx-2310u printing double vesion of an image, the copy and the lighter to the right. how can i fix this?
Double print usually happens when Drum completed its life and Cleaning Blade unable to clean the drum surface properly, Replacing of Drum and Cleaning blade will gave you good copy quality, Don't forget to clean Charger unit
Aug 27, 2014 | Sharp MX-2310U Color Printer : 2310U
My epson px660 is photocopying and printing double images
Try to print with disabling high speed option. Check the linear encoder. Clean it if dirty.
Jan 20, 2013 | Epson Stylus Photo Px660
New catridges but now not ptinting. Makes same
double check and make sure that the chips part of the ink is not covers and that the plastic cap is off too. Is the printer saying it has ink in it now or still saying it is empty?
Jan 10, 2010 | Epson Stylus CX4200 All-In-One InkJet...
Printing double sided with epson stylus 1400
The printer does not automatically print on both sides.  You will have to print one side then reload the paper.
Dec 15, 2008 | Epson Stylus C86 InkJet Printer
EPSON 1800 PROBLEMS WITH NEW IMAC
While you may have installed it, the generic driver may be selected. Here are all the steps to get you back up.
To remove any previous Epson printer driver files and get a good working install of the latest download for the Intel Duo Core, do the following:
REMOVE FILES
1. Double click on the MAC HARD DRIVE.
2. Double click on the LIBRARY folder.
3. Double click on the PRINTERS folder.
4. Drag the EPSON folder to the trash can.
5. Close any open windows.
6. Double click on the MAC HARD DRIVE.
7. Double click on the LIBRARY folder.
8. Double click on the RECEIPTS folder.
9. Delete any "Epson" receipts. Close back to desktop.
10. Open the OS X "Printer Setup Utility".
11. Select the "Printer Setup Utility" menu at the top of your screen and click "Reset Printing System...". Confirm resetting.
12. Close all open windows and restart your computer.
DOWNLOAD
If you have not done so already, use the following steps to obtain the download for the new Intel Duo Core driver:
1. Go to http://support.epson.com
2. Select Printers then Inkjet then your printer model.
3. Under "Drivers and Downloads" select Macintosh.
4. Download only the driver marked for the Intel Duo Core system.
Printer Driver v3.0aAs
Intel-based Macs with OS X (v10.4.4 or later)
epson11769.dmg - 12.4MB - posted on 02/06/06
Installation instructions:
1. Double-click on the "epson11769.dmg" file and follow prompts to create an "epson11769_r1800_printer_driver_30aas" disk image on your desktop.
2. Open the disk image. Double-click the "SPR1800Series 30a" installer icon to begin the installation.
3. Follow prompts to complete installation. Restart Mac once the install is complete.
Do the following to add the printer once the new downloadable Intel Duo Core driver has been downloaded and installed properly:
1. Connect printer.
2. Open Printer Setup Utility.
3. Click ADD.
4. Ensure you are on the Default Browser window.
5. Highlight printer as it appears under Printer Name.
6. For "Print Using" select "Epson Stylus R1800" if this automatically appears on the list. If this does not appear, select OTHER (not "Epson" - which links you to GIMP drivers, which we don't recommend or support). NOTE: if you are using a firewire connection, the printer name may appear as a letter only - ie "E" for "Epson". This is normal.
7. A new window opens where you can Browse to the hard drive location of:
HD > Library > Printers > Epson > Inkjet Printers
(This location contains all the Intel Duo Core Epson driver plugins, be they resident or downloaded.)
8. Highlight/Select the plugin for your printer model in the Inkjet Printers folder, then click OPEN.
9. Use the up/down arrows at the end of "Print Using" again to (re)select the printer's name, which will now appear at the TOP of the "Print Using" list.
10. Click ADD. The new downloaded driver will now be added on the list.
11. If there are other printers on the list, ensure the Epson is made default before testing.
When you are working with a printer model which supports borderless and/or roll paper printing options, you will be able to select these options in the program you are printing from as you set up your print job.
1. Once you have an image or file open, go to File > Page Setup.
2. For "Format For" select the Epson printer name (rather than "Any Printer").
3. Select the appropriate Paper Size. If your printer supports different layout features, each paper size will have several different options. For example, the 4x6 paper size will have an arrow pointing right which offers choices of 4x6 Borderless, 4x6 Standard-Minimize Margins, etc. Pick the paper type plus layout/margin option you want to use here.
4. Click OK on Page Setup. You are now ready to print.
Aug 17, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson printer that can print at art glossy paper
Epson's ink uses a dift technology so far better result you need to check what brand of glossy or photo paper you can use. You can purchase an epson photo or glossy paper for best results.
Your printer would work best using the list below:
Paper Types
  • Supports a variety of Epson plain and photo papers. Supports plain, bond, air mail, Epson Premium Bright White, Glossy Photo Paper, Premium Glossy Photo Paper, Premium Semigloss Paper, Premium Luster Paper, ColorLife paper, Matte Paper Heavyweight, Double-sided Matte, Inkjet Transparencies, Self-adhesive Sheets, Photo Quality Ink Jet Paper, Greeting Cards, High Quality Banner paper; labels; envelopes, Iron-on Transfers and Photo Stickers; Printable CD-R/DVD-R; Panoramic 8.3" x 23.4" Photo Paper
If you may have other questions pls feel free to ask.
Just rate me Fixya if your issue has been resolved.
Cheers.
Jun 17, 2008 | Epson Stylus Photo R300 InkJet Printer
Printed lines shift to left and double images
Are the lines vertical? Have you tried to align the printheads? This can be done using your printer's installed maintenance software.
Mar 28, 2008 | Office Equipment & Supplies
Double Image
It's may be the video cable from the PC. I had the exact same problem with my Epson projector today. Treat y
Oct 06, 2006 | Epson PowerLite 5000 Multimedia Projector
Canon NP 7130 Black and White Copier Logo
190 people viewed this question
old marine
old marine
