Question about Tricity Bendix AW1400W Front Load Washer
Wont spin The motor is ok, new brushes, pump ok, the spin cycle will do a couple of rotations and then stop.
    Problem Solver:
  • 16 Answers
The pressure switch tube will require a blow through,thats if the pumps ok and clean.or a freak happening would be a blocked waste pipe( i have seen this before after much head scratching!)
Posted on Dec 20, 2008
Kenmore front loader stopped washing, or spinning
Is it induction or electronic motor,,,,if its electronic it may be carbon brushes,,,if its induction it may be capacitor
Jun 13, 2013 | Kenmore Washing Machines
Washing machine stopped spinning & tumbling at any cycle. Have limited knowledge on multimeter use, but door lock/switch appears to be in working order. Belt around motor in excellent condition. ...
Check the condition of brushes. Replace if necessary. Check motor rotation. Not rotating, check if it has a soft starter for motor. If there is soft starter, bypass it. Check the motor rotation. If it does not rotate, then it is quite likely that the motor is burnt.
- sonsunny
Jul 09, 2011 | Washing Machines
Whirlpool washer wont spin during spin cycle everything else appears ok.
Machine not spinning....check]
1..all water gone clean pump trap and check blocked drain
2....somehting stopping drum spin drum freely by hand.
3....too much soap use low suds soap and very little of it.
4....motor brushes wearing out...call for service for this one.
Good luck
T
Aug 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Drum wont turn on the spin cycle, it's ok on a
if its pumped all water out and wont spin sound like your motor brushes are worn.
Oct 16, 2009 | Zanussi ZWF1230W Front Load Washer
Blows 6 amp fuse in top panel. On spin cycle runs the pump but motor wont rotate for spin. If left blows fuse again.
Remove the hoses and check the impeller of the pump for an obstruction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Washing Machines
Frigidaire washer won't wash
fault may well be motor brushes need replacing. check continuity across the brushes - you should be able to do this with motor in situ
Oct 11, 2008 | Frigidaire GLTF2940ES Front Load Washer
Bosch WFL2450 Washing Machine wont spin cycle
Hi there, this problem sounds as though the carbon brushes are needing replaced or infact just needing to be cleaned of dust or dirt. Its very common for the brushes to be covered in dust and fibres. Im not sure where the brushes will be on this model but I hope this helps you in someway.
Sep 23, 2008 | Washing Machines
Intermitant fault
Sometimes the Brushes on the motor can cause intermitten rotation. The brushes are the electrical contacts for the motor to rotate. When they wear down or degrade (and need replacing) under spin conditions the motor may fail to turn as it may have hit a dead spot on the motors commutator.
Best course of action is to see if the Brushes need replacing. The cost of new Brushes is < £20. The labour may be vastly more if you pay someone - but it should be done in less the 0.5 hour.
Brushes usually come in pairs (Pack of two).
If your unit is hotpoint I can offer some instruction on how to fit yourself.
Regards
Mar 06, 2008 | Washing Machines
GE Potscrubber Disshwasher GSD700G, wont cycle
Most washers do not fill they spray the dishes. When enough water has accumulated in the bottom a float switch shuts off the water and turns on the pump to remove the water. If the pump motor does not remove the water the cycle will not continue but the timer will. There may be something clogging the pump and resulting in an overload condition for the motor. This would account for the smell. A pump may turn freely when you spin it by hand because you cannot spin it fast enough by hand to determine if the pump is obstructed. Does the cycle drain the water? If the cycle stops and there is water in the bottom not being pumped out then you should look at the pump and the motor to determine problem.
Jan 19, 2008 | GE 24 in. GSD2230Z Built-in Dishwasher
Tricity Bendix AW1400W Front Load Washer Logo
139 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
