Question about JVC XL-FZ700BK 7-Disc CD Changer
Light streaks to form from stationary light sources
Does anyone know what could cause these light streaks to form from stationary light sources? The FX7 was on a tripod, and I had forgotten to turn the OIS off. Could it be caused by the camera being moved during the taking of the "dark frame" when the shutter is closed? From leaving the OIS on while the camera is mounted on a tripod? The photo has had some noise reduction and sharpening applied and was resized. Here is the EXIF information: (image stabiliser was set to mode 2) Any ideas would be very helpful. I quite like this effect and would like to be able to create it deliberately. The unaltered original file can be found at http://www.pbase.com/viztyger/misc
    Master:
  • 903 Answers
No, the building moved also. It's evident with the blur at the top. The reason it's not as obvious as the lights is because the lights are much brighter than the building. The camera was moved during exposure, but then it was held still for the majority of the exposure, allowing the building to register sharp in the frame. I still don't know how you didn't notice this during the exposure. Did you bump into the tripod during exposure? That would cause this effect.
Posted on Sep 07, 2005
    Master:
  • 903 Answers
No, the camera was stationary on the tripod the whole time. The building is completely sharp. Wouldn't it be somewhat blurry if the camera had been move during the 3 second exposure?
    Master:
  • 903 Answers
Shutter speed longer than 3 seconds. Are you sure you didn't move the camera before the shutter was closed? Maybe the OIS system was fooled and moved the lens downward during the shot (notice the strange movement response when moving the camera in OIS mode)
SOURCE:
Nikon coolpix s710 pictures have a streak
I think your picture has a bright light source in the frame. In digital cameras this phenomenon is common that in some angle these streaks of lines are produced with very bright light sources. be careful not to include bright light source while taking pics. But if u have these streaks and line in all the frames, then better check your camera with the service centre.
Aug 22, 2014 | Nikon COOLPIX Cameras
Keep getting snags on sheer fabric clothes, what is it? Anyone with this problem?
If you are certain that the dryer is causing snags in delicates, check the drum for a foreign object (paper clips, safety pins, etc.,) that might be lodged in the drum. A loose screw or loose drum agitator (paddle) might cause this problem.
Sometimes a bad bearing or drum slide will cause a misalignment between the drum and the stationary part of the dryer's interior. This misalignment will pinch clothes and cause tears or black streaks.
Jan 16, 2011 | Samsung DV218AG Gas Dryer
When I shoot anything that has a light source in the image (interiors with lamps; windows; tubes in show cabinets; computer screens etc) on my 50mm.lens with my Leaf Valeo 22W back, on anything longer than...
You can set up the back light correction feature available on the camera menu , reduce the aperture and increase the shutter speed , Additionally the use of correct filters can also help , try not to focus with a back light flashing, avoid the direct but angle it out.
Sep 28, 2010 | Hasselblad Cameras
COOLPIX S570 Digital Camera: When recording a video, any bright light source in...
Some cameras do that. Most of the time, the streaks don't appear on the picture.
May 07, 2010 | Nikon COOLPIX S570 Digital Camera
Light streaks and gray streaks and little contrast.
Sounds like there are multiple problems on this machine. Dirty optics can cause light images, white streaks can be caused by dirty cortron wires(becareful when cleaning the wire or all the wires 3 usually, Q-tip can help) , not enough toner in the ink hopper, dirty cleaning blade in the drum modual. A bad heat roll can cause streaks also. Background with light images and black spots can be caused by competitive toner not working very good.
Oct 15, 2009 | Canon PC-920 Black and White Copier
White horizontal streaks
This sounds like some kind of lens flair. Make sure there are no bright light sources at about 45 degrees to the lens and it should correct this problem. If it is not that then there may be a problem with the CCD, the part that receives the exposure. Without knowing if this is a point and shoot or digital SLR this is the best answer I can give.
Oct 05, 2009 | Cameras
Xerox phaser 8400 fault
I have the same problem. Xerox says they need to send someone out and can not tell me what this code means.
Prior to the error I have having light streaking on the page. Took everything apart and cleaned and it worked OK for 2 days then returned to streaks.
If anyone knows what to look for please offer assistance.
Jul 24, 2008 | Xerox Phaser 8400 Laser Printer
Blue vertical streaks on the recorded picture.
Is it a lens flare .... I can only confirm after seeing the video....
Feb 12, 2008 | Panasonic NV-MD10000 Camcorder
Hitachi rear proj TV, light blue vertical streak center screen, moves slowly
Sounds like a source problem. What happens when you play
a DVD or some other source??
Need more info? Always give Model # and age----T.
Nov 03, 2007 | Televison & Video
JVC XL-FZ700BK 7-Disc CD Changer Logo
103 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
