Question about Belkin Computers & Internet
Belkin n router with cox cable modem. just installed a wireless g belkin usb network adapter. when i go to set it up there is limited or no connectivity even though the signal is all lit up like a christmas tree. i have had 25 years computer experience and can't figure this out.
  • Belkin Master
  • 6,487 Answers
Double check the wireless settings of your belkin router, its should match with the wireelss settings of the computer most important is the wireless security key called a WEP or a WPA key...if you're not sure about that access the router setup page and there you can check all the wireless settings of the router..
Hope that helps..........
Posted on Aug 27, 2008
Laptop died and now I cant connect my desktop with the belkin usb adapter. It just keeps saying aquiring network address.
Use the Ethernet cable to verify the router or modem is working and connects to the Internet. If so, then check your wireless adapter in the desk top through device manager - it should detect the Belkin. Also, verify you are entering the correct WEP keys to access the wireless connection to the router or modem - sometimes it gets typed in wrong.
Feb 19, 2011 | Belkin (F5D7050) 802.11a/g/b Wireless...
Cant get connected with my belkin router...all i can get is "connected with limited access
HI
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router
1. Step 1 Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2 Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3 Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4 Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
Step 5 Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure ?other settings
Oct 18, 2010 | Belkin N1 Wireless-N Wireless Router
The wireless network is being picked up by the laptops in the house, but there is no internet connection between the modem and the router. MY router is a Belkin G Wireless
if you connect the computer directly to the modem, does it work?
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 06, 2010 | Belkin Wireless-G Plus MIMO Router with...
I have an older model belkin f5d7050 and have the 4xxx drivers installed on windows vista 64 (which belkin says is compatible) and I get limited or no connectivity when attempting network access... I'm...
Some network adapters have problems with wireless encryption, try turning it off at the router and connect again. If it works, you wont be able to use that usb adapter with your routers encryption on.
Nov 04, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
REPLACED F5D7050 WITH F6D4050, NOW LIMITED CONNECTIVITY
You need to make sure the new belkin adaptor has the same settings as the router you are using. If you set a password on your router then you need to set a password the same on your new adaptor.
Jun 24, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Help. I have a Belkin Wireless G Router safely installed and functioning with a laptop running XP. However, I also have a Belkin Wireless G USB Network adapter that was safely running a desktop with...
is the wireless network adapter driver installed on your pc? if its properly installed you have to reconfigure the wireless network adapter to your belkin router.
wireless usb adapter should obtain the ip address from your belkin router
Apr 17, 2008 | Computers & Internet
Belkin n1 wireless usb adapter
Dear Friend,
1. Connect your ISP modem to your PC and configure as Bridge mode.
2. Remove your ISP modem and connect your wireless router to your PC and configure as PPPOE mode. (refer http://www.wi-fiplanet.com/reviews/article.php/3645166 if any doubt on configuration)
3. Now connect your ISP modem to wireless router, The modem should connect to your WAN cable.
4. And Give the wireless router's IP in your laptop as Gateway (In TCPIP settings of your Laptop wireless adapter / or configure DHCP)
5. Now you can access internet on both systems.
Feb 02, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
How to set up network on belkin G+ wireless usb adapter
do you have a Wireless Router + Broadband modem?
This is like a base station to which your remote wireless node communicates (to get connected to your home network and internet.
something like this http://catalog.belkin.com/IWCatProductPage.process?Product_Id=187337 for an ADSL connection.
If you are on cable, you can either get a Router similar to the one above (but for cable) http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1138056788757&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=8875739789B01
or if your Cable modem has LAN ports you may just be able to use an "Access Point" to add Wireless capabilities. http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1126536803676&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=0367639789B22
Oct 14, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Computers & Internet Logo
416 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
