Question about Gateway 506GR PC Desktop
PC Fan Issues
Hi. I have a Gateway 506GR Desktop PC. Lately, the fan has sounded like it was grinding or just making a loud, strange noise. I took the main fan out and cleaned the dust out (And there was a lot) as well as the fan that was mounted to the back of the case. Cleaned that one as well.
I put them back on, and now since yesterday the fans are just running at a high speed constantly. They never seem to slow down.
I'm wondering if I may have put the back fan in backwards. It's blowing air outward from the case. Basically, both fans are blowing outward. Do I want the back fan to be pulling air in, while the main fan blows it out the side?
Thanks
  • 23 Answers
1 fan in and 1 fan out, usually out through the front.
Posted on Jan 24, 2009
Fan making noise
To find out which fan it is, open the side and listen.
If it's a case fan those can be bought at you local computer store for a few bucks.
If it's the CPU Fan, you might be able to replace just the fan, or you might have to install another CPU Heatsink and Fan.
Hope that helps!
Dec 15, 2010 | Gateway 506GR PC Desktop
Loud gateway 5310 desktop
its your power supply that making nosies, change it to a quiet one. or its you processor fan. if so you need to clean it from dust. also clean your power supply and if you are lucky the noises disappears.
Oct 12, 2009 | Gateway 5310S PC Desktop
Gateway 506GR motherboard configuration
Item Description Item Description A Rear Panel I/O Ports M Front Chassis Fan Connector B Auxiliary 12-V ATX Connector N Serial ATA Interfaces C CPU Socket O Front Panel Header D CPU Fan Header P Front USB Connector E Memory Slots Q Front USB Connector F Standby Power Indicator LED R Front Panel IEEE-1394a Connectors G Floppy Disk Drive Connector S Speaker H ATX Power Connector T PCI Express x1 Connector I Parallel ATA IDE Interface U Front Panel Audio Connector J Battery V PCI Slots K Intrusion Switch Header W Rear Chassis Fan Connector L BIOS Configuration Jumper
Aug 21, 2009 | Gateway 506GR PC Desktop
Y Daughter Has a gateway laptop model ML6720 which the fan has been seemingly noisy but I just noticed I don't think it is going on .What should I do and what harm can be done
This is the CPU cooling fan.
Take it to a repair shop. Laptops cannot been worked on easily.
Without the cooling fan, the CPU will eventually die and make take the hard drive with it.
Aug 09, 2009 | Gateway 506GR PC Desktop
I think the fan is making a super loud grinding noise.
I would not recommend this. You could fry your cpu and then you would have no notebook. If you are going to open the notebook make sure there is nothing interfering with the fan. The fan can be replace. Take the fan out and try to replace it, if needed. Do not run the notebook without a fan.
Feb 18, 2009 | HP Pavilion a1620n (882780664494) PC...
Heater making angry noise!
Your heater fan bearing is shot,,time to replace Fan now before you really need it.
Jan 19, 2009 | 2004 Mazda 3
I replacement fan
They sell some things that you can put on the fan so it can run quietly without making any noise.
Oct 28, 2008 | Gateway 506GR PC Desktop
Dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
Sep 26, 2008 | Optoma H30 Multimedia Projector
Loud noise
Typical problem in most computers, the fan is experiencing a "burn out." This means there is either something caught in the fan causing it to create noise, or the motor is going bad. there are two fixes for this problem.
1) open you computer's case according to its manual and remove the system cooling fan and give it a thorough cleaning.
2) you may need to replace the cooling fan with its recommended replacement model.
Hope this helps!
Jul 08, 2008 | Gateway 506GR PC Desktop
No signal, Gateway 506GR
Start by disconnecting the new DVD writer and verify all power supply connections are not shorted.
May 01, 2008 | Gateway 506GR PC Desktop
Gateway 506GR PC Desktop Logo
284 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
