Want to make copy's of 81/2 x 14, but cant figure out the setting, it only prints half the page.
  • 114 Answers
You have to set the printers paper settings to legal size.
Lou
Posted on Aug 27, 2008
Canon ir2520 copy only half page
it is normal, just mixing, continue printing, it will slowly cover the page till the entire page is printed or copied, dont worry, just reuse the half printed paper till when the pages print complete.
May 27, 2012 | Office Equipment & Supplies
I can't make a copy using the operator's mode. the copy that does print is so light and such small print thatit can hnardlyh be read. Also, the copy that comes oujt is only half of a page. Most of the
It sounds like the settings on your printer in the menu area have been set to reduce the image you want to print? Click on menu and then scroll the features with the up and down arrows and check on the size of the image to print and change it if necessary.
Please clairfy what you mean by "using the operators mode".
Oct 21, 2011 | Dell V305 All-In-One InkJet Printer
I NEED TO PRINT DOUBLE-SIDED ON AN hp3150 LASERJET. hOW DO i DO THAT?
Follow these steps to change print settings, and then print in Mac OS X 10.6. Step one: Select your product
  1. In the program from which you want to print, click File , and then click Print . Figure 11: Click File, and then click Printc02458420.jpg
  2. Select your product from the Printer: drop-down list.
Step two: Change print settings
  1. Type the number of copies to print in the Copies text box.
  2. If you want to print multiple copies, select the Collated check box to print the pages of each copy in order.
  3. Select the pages of the print job that you want to print. To print all pages, select All. To print a specific range of pages only, type the page number that begins the page range in the From text box. Then, type the page number that ends the page range in the To text box.
  4. Select the size and type of paper loaded in the product from the Paper Size drop-down list.
  5. Select the orientation for your print job. To print in portrait orientation, click the icon on the left. To print in landscape orientation, click the icon on the right.
Step three: Change the paper type and quality settings
  1. After the Orientation section, click the drop-down, and then select Paper Type/Quality . NOTE: This drop-down usually defaults to the program specific drop-down. In this example, the drop-down is the TextEdit drop-down. Figure 12: Select Paper Type/Qualityc02458421.jpg
  2. Adjust the Paper Type setting to match the paper loaded in the product.
  3. Adjust the Quality setting to change the print quality of the printed page.
  4. Select Print Borderless to print photos without a white border.
  5. To change the color profile or to turn on Photo Fix, click the arrow next to Color Options to display the Color Options menu. Figure 13: Color Options menuc02458422.jpg 1 - Paper Type/Quality menu options 2 - Color Options menu (only available if you click Color Options)
Step five: Print the print job After all the settings match the needs of the print job, click Print on the Print window to print the document or print job.
Dec 26, 2010 | HP Photosmart C3150 Printer
Only copies half a page. Right margin cuts off
check paper trays to make shure paper is tight in guides. registration settings off
Jan 09, 2010 | Sharp Office Equipment & Supplies
Half page printing
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | HP LaserJet 2840 Printer
Problem printing full screen
sounds like your printers settings have accidentally been set to print a smaller area. When you print, look into the area that says page settings or properties before you print, you may find the settings altered. If the settings are set to print full page, then post back as we will need to explore other issues. Cheers lilacgerry
Sep 15, 2008 | Lexmark X6170 All-In-One InkJet Printer
When I scan a good copy of a document, it prints very light and the second page is cut in half horizontally. The first page is always okay, but the ones after that are all cut in half and are very, very...
make sure ur paper settings is ok from ur computer, i mean if u are using an A4 make sure it is well set and always try to preview ur work before printing for readjustment
Sep 08, 2008 | Office Equipment & Supplies
Epson V200 scanner
Epson V200 Copy Utility Problem with Incorrect Margin Output
I had the same problem forever and i just sat down today to fix it.
I have a Konica Minolta PagePro 1350w for my printer. The resolution
is set default at 600x1200 when in the Output Paper - Paper setting.
Change the resolution for your printer if you can to 1200x 1200 in the output paper - paper setting in the copy utility software, and
that should solve your problem with this half page copies. It might
still cut off some margins at the very edge, but most of the time they're just
plain paper margin. Hope this helps you out.
Jul 04, 2008 | Epson Perfection V200 Flatbed Scanner
Cant figure out how to enlarge a copy on fax machine?
To select the resolution Select the desired resolution according to the type of document.
“STANDARD”: For printed or typewritten originals with normal-sized characters.
“FINE”: For originals with small printing.
“SUPER FINE”: For originals with very small printing. This setting only works with other compatible fax machines.
“PHOTO”: For originals containing photographs, shaded drawings, etc.
Using the “FINE”, “SUPER FINE” or “PHOTO” setting will increase transmission time. If the resolution setting is changed during feeding, it will be effective
If you go to:
http://service.us.panasonic.com/OPERMANPDF/KXFHD331.PDF
You will find the online manual for this machine.
Hope this will help you...
Apr 28, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Hp Officejet 7210 all-in-one
Random Extremely slow printing !! same !! changed cartridges . i cant figure out the problem !
Nov 21, 2007 | HP Officejet 7210 All-In-One InkJet...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
