Question about Canon imageRUNNER 5000 Copier
IR 5000 No Back illumination for touch panel
Hi
our low copy (< 10k) Canon IR 5000 no longer has touch panel illumination. The panel and its menu system still work but you need to shine a torch onto it to navigate.
The contrast adjust still works but has no effect on the level of brightness.
Does the panel have a separate illumination bulb, or am I looking at replacing a whole board here
  • Geoff West Sep 12, 2008
    thanks Cogz much appreciated
    Geoff
  • chrismd_0919 Oct 01, 2008
    Hi
    Someone in my office shattered the touch screen does anyone know where I can buy the part?
  • Canon Expert
  • 1,326 Answers
Most likely you will have to just replace the LCD display pannel or Touch Screen PCB. It does have a lamp, but I did not see a part number for it. You may be able to find a used or rebiult one on line and have a tech install it for you, to save your self some money..
Posted on Sep 12, 2008
Hello possible to obtain the device reset canon 2202
canon ir 2202 - The Copier Network
www.thecopiernetwork.com > ... > Canon - Black and White
Jul 31, 2014 - 2 posts - ‎2 authors
am facing E0001-000 on new canon ir 2202 ; can any one know how to reset error from this model?
Canon imageRUNNER 2202 - Canon Europe
www.canon-europe.com > For Business > imageRUNNER 2202
The imageRUNNER 2202 is a basic solution to your A3 black and white ... Requestinformation ... Canon's toner and long life drum technology allow users to run theirdevices for longer without the need to often replace consumables. .... We use cookies to provide you with the best possible experience on our website.
Canon iR 2002 2002N 2202N - YouTube
? 1:36
https://www.youtube.com/watch?v=I5ywBlOfwPA
Sep 28, 2014 - Uploaded by Shageesh A
Canon iR 2002 A3 Print, Copy, Scan Canon iR 2002N A3 Print, Copy, Scan, ... How to reset ID and PASSWORD ...
Dec 21, 2015 | Canon Office Equipment & Supplies
PRESSER ROLLER CUT AFTER 20000 COPIES WHY
This is a low number for that roller.Check the bearings make sure they are not seized. If you have experience a noise then most likely you have bad bearings and the roller is not rotating correctly. The guides may have built up of toner and touching. the seperation guide plate not in correct position or knocked off .under the roller dirt and grime needs to be removed. something is touching the roller causing this and you will get better life from a OEM roller.
Mar 21, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
ImageRUNNER 5000 Copier: I own a Ir 5000 and i just started getting "tire t...
Try to clean corona wires, pick up, feed and separation rollers, check drum cleaning blade and fixing assy.If the tracks are white, check also the toner unit
May 17, 2010 | Canon imageRUNNER 5000 Copier
ImageRUNNER 5000 Copier: how to set a password for ir 5000...
under User mode ( round button with * ), choose ID management. The rest is yust the reading from panel.
Pls. rate
May 05, 2010 | Canon imageRUNNER 5000 Copier
Which one is better to buy IR 5075 or IR 5065
The all above models are same with minor change for speed
You need model as your daily output requirement
All models are heavy duty.
you can select any one for upto 10,000 print or copy per day or for 20,000 & up print/copy select ir 5075
Jun 15, 2009 | Canon imageRUNNER 5000 Copier
Saving a copy job
Hi
Try to scan your originals to your mailbox on the IR machine and save it there.If you need copies of the originals again go to the mailbox highlight the job and reprint it again.
Nov 17, 2008 | Canon imageRUNNER 5000 Copier
Canon IR 5000 Printing multiple copies of mutliple copies
Dose it do it when you use it as just a copier? I would have to say that the problem lies with in your network some where. Call your IT person.....
Jul 15, 2008 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Logo
129 people viewed this question
old marine
old marine
