Question about Canon Cameras
I OWN A CANON POWERSHOT SD1000. THE DISPLAY SCREEN IS BLACK WHEN I TRY TO TAKE A PICTURE. HOWEVER PLAYBACK IS CLEARLY VISIBLE. IT IS ONLY WHEN I ENDEAVOUR TO TAKE A NEW PICTURE THAT THE SCREEN IS TOTALLY BLACK.
  • 2,039 Answers
If you take a picture using the optical viewfinder, does the camera actually record the picture? If so, you may have the LCD turned off in the camera mode (there are three options: standard, detailed, and off). With the camera in the shooting mode, press the "DISP" button and see if the LCD turns on.
Posted on Aug 27, 2008
  • thangtran Sep 26, 2011
    I have the same problem I tried to to do the same thing they said but the LCD still did not work . I can take picture thru eye viewwfinder only !
My Canon powershot SD1000 screen isn't working. Iv'e charged the battery but when I turn the camera on, the screent is black. It won't take any pictures
It's very likely the CCD sensor that needs to be replaced. If you need to have it serviced, this place is excellent for the Powershots and not much at all if you need to have one fixed: www.camerasandparts.com
Before having it fixed, press the DISP button first and make sure you just didn't turn the display off. If you end up needing service for the Canon, that place above is really great for these cameras.
Apr 15, 2012 | Canon PowerShot SD1000 Digital Camera
My camera will no longer show the image on the screen when I am taking a picture with my Canon PowerShot SD1000 digital camera. Can this be fixed or is it time for a new camera?
most likely you have turned the dispaly off. find the display key and turn the screen back on.
another option is to go into the menu, then go to display and set it there.
Jul 18, 2010 | Canon PowerShot SD1000 Digital Camera
My camera can play back pics and the zoom moves when I turn it on, but the camera LCD display remains black when I try to take a picture
Look in your menu to check you havnt turned the LCD Screen off as a battery saving option.
If not Take it to be repaired
Oct 06, 2009 | Canon PowerShot SD1000 Digital Camera
My Canon Powershot SD1000 has a fully charged battery but won't turn on at all.
Does your camera turn on when it's in playback mode? I have a similiar problem with mine. It only turns on in playback mode.
Sep 25, 2009 | Canon PowerShot SD1000 Digital Camera
Black screen while shooting, but still taking pictures not black
Nonononooooo fotomohamed, he can review just taken pictures on the LCD. The screen is working.
Actually, it sounds like you just accidentally pressed the DISPLAY button on the back of your camera. This manually turns the screen on and off in picture taking mode to save batteries (you would then use optical viewfinder). Just press it once and it should turn back on.
Jun 19, 2009 | Canon PowerShot SD1000 Digital Camera
Canon SD1000, screen blacked out and takes black pictures
try taking the batteries and memory card out let it set and put everything back in it ang cut it on
Jun 18, 2009 | Canon PowerShot SD1000 Digital Camera
Canon Powershot SD1000: LCD screen display
Hopefully you resolved this already. If not, push the "DISP." button left of the MENU button. Pushing it gives you three options: black (for discreet shooting so your LCD doesn't give garner dirty looks from fellow concert goers), liveview, and liveview with info overlayed (shooting mode, ISO, etc.). Good luck!
May 05, 2009 | Canon PowerShot SD1000 Digital Camera
I have a Canon powershot SD1000 that no longer will show the picture on the viewing screen. The screen is completely black
Hi!
It's possible that you may have accidentally pressed the DISP button to disable the LCD. Please try to press the DISP button after you switch on the camera. If the display does not show up on the first press, try pressing the button twice or until the LCD turns on.
Please let me know if it fixed the problem , or not so that we can try other options.
Good luck and have a nice day!
Oct 03, 2008 | Canon Cameras
Camera will take picture, but the picture is coming out black!!!! Help Please!!!
Dear vera11:
The symptoms you're describing sound like a classic case of having a faiiled CCD image sensor.
First try pressing the display (DISP) button on the back of your camera several times to see if your image returns at any time. One of the three display modes is "off" to preserve battery life. Your problem may be as simple as inadvertently pressing this button into the off mode.
If that doesn't work, try doing a reset and then removing your batteries from the camera for a few minutes, reinstalling them and turning the camera on to test the LCD screen.
If your screen is still black, but you can clearly see pictures taken previous to the problem, and you can clearly see the menu system when you press the MENU button, then you likely have a CCD sensor problem. Contact Canon Tech Support at 1-800-828-4040 to have the camera repaired.
Hope this helps.
Sincerely,
HeavyDLB
Jun 01, 2008 | Canon PowerShot A520 Digital Camera
Taking photos or video works sometimes
Hi, I think this is problem due to LCD Diplay. Sangita
Jul 23, 2007 | Canon PowerShot SD1000 Digital Camera
Cameras Logo
188 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
