Question about Sampo SME-34WHD5 34" TV
Shrunk picture????? My Picture in the tv has overlapped.Picutre hight is normal but length is13 inches.When I switch to YPrPa the picture does not fit ,it seems to be magnified.
  • 25 Answers
Enter the service menu mode and adjust the v.line adjustments
Posted on Aug 27, 2008
Picture over hight
Wide button given in remote for adjust screen
Mar 23, 2014 | Sharp AQUOS LC19DV28UT 19-Inch LCD TV/ DVD...
Pictuer hight
Use the zoom function on the remote. Be advised that all programs you see on TV will not fill the screen completely because they are a different resolution. The TV handles it by putting black areas around the picture so the aspect ratio isn't changed.
It has shrunk to about 6 inches all the way around the screen so the total picture sizr is 36 inches instead of the 42 inches otherwise clear picture little fuzzy when turning on but becomes a clear
Don't know what wires your using to connect to tv. It does matter, sometimes the connections go bad, either at the tv or cable box. Have you tryed to stretch picture in settings?
Feb 10, 2012 | Toshiba 42H82 42" Rear Projection...
My tv antena is broken and i ma trying to assembe the cable to the thing that goes into tv. Any instraction please? The tvcable is not conected to the conector which goes into tv. I peeled the placstic...
Hello
If your TVs internal telescopic antenna has broken, you can us an external antenna from connecting to the rear antenna socket. For that you have to buy some extend of antenna cable, and a yagi antenna; as it is better for reception. If your TV screen size is 14" or below, a small wire of length 2 mteres or so is enough. Buy one Balun coil assembly fro electronic sparepart shop, and connect this wire to it, connect it to the antenna socket at the back of the TV, and with picutre just wave it to some side where you get the maximum picutre clarity.
If you TV screen size is more than 14 inches, external yagi antenna shoud be used for claear transmission reception, and it must be directed well towards the tranmitter also. Alaingning it is a trial and error process, at which position you gets the clearest picture, without any Ghosts. OK.
Dec 29, 2010 | Philips Televison & Video
The picture on my new 55" lcd hdtv overlaps the
Find a buttons on ur tv remote control that said like VIEWMODE,P.size or a Zoom.Push one of these buttons to find the wright picture mode to fit in ur tv picture screen frame.
Nov 22, 2010 | Vizio VF550M 55 in. LCD HDTV
The tv seems really dark.57in theatrewide hd toshiba
Go into the tv menu and select the Preferences menu and set your picutre preference from Theater to Normal. The TV is currently in Theater mode, wich is for viewing with no lights on in the room. Switching it to normal lightens the pictue a lot.
May 27, 2009 | Toshiba 57H81 57" Rear Projection...
My ilo tv picture is 1 1/2 inches. How can I fix this??
its a vertical problem could be bad cap or possible vertical i.c. okay take to tv shop is their still a warrany on this set sounds pretty new shad
May 14, 2009 | iLO IWT3206 TV
Toshiba 36a43 no picture
reset the settings using the user manual then the problem will be solved
May 13, 2008 | Toshiba 36A43 36" TV
Sylvania 27 in tv picture
It sounds like your vertical has shrunk, causing the picture to look squashed. Most likely a bad component in the vertical output stage.
Dec 19, 2007 | Sylvania 6413TC 13" TV
Sampo SME-34WHD5 34" TV Logo
81 people viewed this question
Top Sampo Televison & Video Experts
Lyle Siemens
Lyle Siemens
Starnley Johnwells
Starnley Johnwells
Are you a Sampo Televison and Video Expert? Answer questions, earn points and help others
