Question about Samsung Heating & Cooling
Window air conditioner Samsung
Local / manual control provided on machine front is not working but it is working with remote control. What could be the problem and how to resolve
  • 958 Answers
It could either be the switches on the manual controller or the wire that connects the manual controller to your main board.
tnx 4 using fixya,
drcool
Posted on Aug 27, 2008
How do you turn on a 6x06 window unit without remote control
If the air conditioner has no front panel controls, the remote control is required.
Jun 05, 2014 | Fedders X Chassis A6X06F2A Air Conditioner
I have a Samsung Biotech plus air conditioner - Model SC12ZAB. When the system is turned on, all the lights on the control panel light up and it is not possible to select any of the 5 sway options to...
warranty? go that route. Id unplug at least a minute see if it's brain will reset. With these new fangled computerized machines, one needs to be a specialist's specialist. Hopefully you have your owner's manual, it has a troubleshooting section, no help? Call the Customer service they are usually helpful, Or email them too.
Jan 10, 2013 | Samsung Heating & Cooling
Can i turn on the unit without a remote
Almost every window air unit will have manual controls even if it is equiped with a remote, they are usually located on the front under some type of small door which releases simplu by pushing in on same alowing door to spring open.
Aug 22, 2012 | Haier 5,000-BTU Window Air Conditioner...
Remote control signals not being received by Samsung air conditioner
Try a new set of batteries in the remote... If that doesnt work, look on the indoor unit , behind the filter screen or on the side for a "manual start or emergency start button or switch" If that works, it may be the remote is faulty. If not the remote, it will be the recveiver board on the indoor unit.
Jul 16, 2011 | Samsung AQ24 Air Conditioner
I need a remote control part # rcs-4hvpis4u for a sanyo air conditioner
Hi Aldercarima, If you are needing a remote control, any generic remote with multi unit capabilty would suit. The generic remote will search out the AC;s code and adjust itself to the correct settings. Your local refrigeration equipment supplier should be able to provide a unit for you. regards Col www.digitalcontrols.com.au
Feb 23, 2011 | Sanyo Heating & Cooling
Mt timer butoon is stuck on timer so unit wont work
All LG room air conditioners should be able to be operated without using the remote, by just using the controls on the unit. Replacement remotes are available from an LG service provider.
Jun 05, 2010 | LG Electronic Window Air Conditioner
Samsung AS-0914ER split system wall air conditioner
Here are different kind of unit with there manual button location, hope this may help.
Mar 05, 2008 | Samsung AS18A6RB Air Conditioner
Air conditioner
Some some remote control have RST or RESET button, you have to push this every time you change the battery or for malfunction remote control. You can find this either in front of remote control or at the back of the remote in battery compartment.
Jan 01, 2008 | Heating & Cooling
Machine shuts off
your control board assembly is faulty relace with a new one from your local appliance parts store
Sep 09, 2007 | Samsung AW1293L Air Conditioner
Heating & Cooling Logo
101 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
