Question about Sharp Viewcam VL-A10U Camcorder
Can a new battery destroy a camcorder?
Hi, I wonder if you can help. The following is the story but first: I'd like to think that the camera was older and IT failed and was not the battery's cause. It was working fine till I put the new one in. I have a Sharp VL AH 150 camcorder. It was working perfectly. I ordered the large BT-H32 battery. When I put it in, the camera instantly went on(switch in off position). As a result. I cannot now turn the camera off. When I put it in VCR mode, it stays there and won't go into camera mode or off even though the switch is in the proper position. The camera will no longer charge a battery via the power supply(red light no longer goes on). Now this is how it works now: Being I cannot turn the camera off I either have to take out the battery (if power supply is not connected) or unplug the power supply if it is connected AND take out the battery. To turn on I can either plug in power supply or put battery in. It will automatically turn on to whatever position the switch is in (but not off). In essence, if i'ts in camera mode I can record fine. If I put it in VCR it will play fine, but it will not go back to camera mode(or turn off). Obviously the battery blew out a certain circuit in the camera and I wondered if this rings any bells. It's pssible the battery is not shorted and simply sent a surge that jumped past the "on-off" circuit and did its damage? The battery is a Powermart 3.6V 5400mAH Package says " replace BT-H32". Tlhe smaller battery I was using before worked fine and held its charge fine. I've finally received my charger in the mail and the new battery and old works just like above. No more camera charging. Also, does the guy who sold me the battery (new at ebay) owe me a new camera?
  • 48 Answers
Never ever use any batterie other than a name brand that is made for your camcorder. Sometimes people thing bigger more juice is better... alot get away with it and then alot don't.
When upgrading and changing or adding make sure it is totally compatible or designed for your device specifically.
Sorry your camcorder blew... i would be a little sad... there is always a HV20 my friend it's the best thing I've tried since my sharp. Quality is 100 times better than anything out there..
Posted on Feb 19, 2008
    Master:
  • 425 Answers
Look at the camcorder maker's site and see if they offer a 5400 mAH battery or larger. Its possible your camcorder doesn't support charging a larger battery.
Posted on Sep 07, 2005
    Master:
  • 425 Answers
It sure looks like it did some damage. At least you've got a work around. If the guy didn't say the battery would work in your camera, it's hard to see how he's at fault. It appears that he did live up to his end of the bargain. Perhaps you should have looked at the battery specs to see what it works with? Even if he's at fault, he probably would owe you only the current value of your camera rather than a new one.
Lost my ac dc adapter need new one for rca small wonder camcorder
You can try www.ebay.com. I found the following AC adapter for the RCA Small Wonder camcorder:
http://cgi.ebay.com/RCA-EZ209HD-Small-Wonder-camera-CHARGER-AC-ADAPTER-/140516900106?pt=Batteries_Chargers&hash=item20b775bd0a#ht_1469wt_723
Mar 01, 2011 | Cameras
My camcorder states Movie recording disabled. It is a sony handy cam dvd108. I am using brand new sony mini-dvds. I have tried so far the following things: cleaning the lens, cleaning the pick up lens,...
Hi! Looks like that the camera has a system crash. I strongly suggest that you have it looked at by a qualified technician to check the circuit board of the camera. Hope this helps and thank you for using FixYa!
Oct 17, 2010 | Cameras
Ihave a view cam made by sharp and the model #vl-ah160 and it does not hold its charge even wih new batteries.i had drop it and i was wondering if this can cause it fo not holding a charge
if it still works ..I dont think this should have cause any problems ....I guess the power issues came from poor quality of the accumulators or better from a not that great formating of them when they were brand new....another cause may be the age ...after all even in mobile phones , those rechargeable ones have a limited life time ...and his is the way they behave .....I mean they begin to last less and less.. a solution might be new ones...or even try to never let them inside the camera even when the power is off...cause all cameras empty them batteries when they aren;t even on ...
Sep 10, 2009 | Sharp Viewcam VL-AH160U Hi-8 Analog...
I have canon zr800 camcorder,its battary not gatting charged.
can you try to used a new battery if it works i think your old battery have a problem.
thanks,
Jun 23, 2009 | Canon Video Cameras
My panasonic NV-DS60 camcorder is not working
as said somewhere else on here, take all the screws out of lighter part of the bottom of the camera, you will then see all the flat cables, push them all in and move left to right slighty. put the battery back on and see if it works. if it doesn't just do it again. did this to mine just now and it works fine again.
Dec 25, 2008 | Panasonic NV-DS60 Mini DV Digital...
Media recovery
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Feb 19, 2008 | Sony Handycam DCR-SR40 Camcorder
NP-FH100
the 'charging' hole is for you to charge the battery. the 'fh' hole is to power the camcorder. no need to put battery on camcorder in either situation but it is convienent to attach the battery to camcorder.
Dec 12, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Samsung VP W95D Hi 8 Camcorder
are you trying to charge the battery while on the camcorder??? does the camcorder work when you plug the camcorder into the charger?? If the battery fails to charge while its on the charger it can only be the charger but most likly the battery. If the camcorders dead it could be the dreaded pana cap think thT HAPPENS TO MOST CAMCORDERS AFTER A LITTLE AGE. good luck
Apr 13, 2006 | Samsung VP-W75 Camcorder
Tape Mechanism
hi see if this matches your problem:(page 200) www.docs.sony.com/release/DCRPC101.pdf hope it helps good luck
Mar 23, 2006 | Sony Handycam DCR-PC101E Mini DV Digital...
Sharp Viewcam VL-A10U Camcorder Logo
73 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
