Question about NexxTech NSMODX2
Modem issue I bought a pc a few years ago and the modem worked fine. One day it eventually went out and I replaced it with an external usb modem. Couple of months later it began the same problem as the original: no dialtone; despite there being one. Replaced that modem with another and less than a month it developed the same issue. GOT ANOTHER ONE and three days later same thing. I have Windows XP w/ svc pack 2, the current modem is a Nexxtech USB external data/fax modem model NSMODX2. I have removed all other modems in the system. Everytime the modem fails and I replace it it connnects fine. Is there a possibility my motherboard is faulty?
    Problem Solver:
  • 19 Answers
A mother board is a big thing to replace. you may want to just buy another computer if thats the case. it may also be the way it hooks up. is it a card. if it's a card thta slot maybe shorting it out. if so try a diffrent slot. my best advice is move away from dial up all together.
Posted on Feb 12, 2009
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
My acer Aspire 3500 wont turn on. It was fine a few hours ago but now wont boot. I keep getting the acer picture featurning the f2 set up and then the screen turns blank with a white flashing - in the left...
if you activity lights on, try connecting to an external monitor or modern flat screen tv. if the screen is flashing then it is probably a screen issue. eg the invertor r screen has failed.
Jul 23, 2011 | Computers & Internet
Sir/mam my imation external hard disk 320 gb is not detecting in any of my and my friend systems, i tried in windows xp/7, ubuntu. but not working. blue light(power light ) is glowing, while placing...
Unfortunately, external hard drives go bad. A 320 is probably a few years old, I replace mine about every 3 years to be sure. I know it sounds funny, but things work till they don't. Just because it was working yesterday does not mean it will work today. It is possible there is a setting in your XP or 7 to keep from seeing the drive, but doubtful it changed on both systems between yesterday and today.
Oct 30, 2017 | Imation (23780) 320 GB USB 20 Hard Drive
I have a 320gb toshiba external hard drive, i've been using it around 3 years without any trouble. A few days ago i lost the cable connecting it to the PC. I bought a few cables but no use. Doesn't...
This is because there is a connection problem between the external drive and the computer. If you have changed cables to no avail, you can open the casing of the external drive where you will find the hard disk inside. Unplug the two cables connected to the harddisk and replug it after a minute. Then try again. If it still does not work, then you need to buy just a usb enclosure and plug the harddisk there to be able to use it again.
Hope this helps. Thank you for using FixYa.
Jan 13, 2011 | Toshiba 120GB USB 2.0 Portable External...
External Nortel Modem won't connect
DSL uses one wire pair since it runs off a POTS line (plain old telephone service).
The Nortel modems are very old - they were some of the first DSL systems that came out almost 15 years ago. They were designed to work with their own proprietary Nortel back-end (DSLAM) equipment. Since they use proprietary and now way outdated transmission protocols, they will not work with modern DSL connections since they do not support the standard DSL protocols. Unless there was somekind of firmware upgrade I wasn't aware of, its pretty much junk.
Nortel went bankrupt a couple of years ago. I used to work for them and some of the guys who designed their DSL modems worked a few cubicles away from me. I had a couple of them in the early days (we got free DSL as beta testers back in the mid-90's) - the modems are useless now, but I found the power supply worked well with my cordless drill charger.
Sep. 2010, Ottawa
Sep 10, 2009 | Computers & Internet
I just have one small issue/question. I just bought an Acer Aspire 5920 a few days ago, and I can't see the kayboard in the dark. This is a major problem, as i use it to take notes in class. Is there...
actually, there are clip on lights that are handy for this..like the book reading kind. I know of a few illumated external usb keyboards, but the book lights are a safe bet..bookstores carry them
Oct 17, 2008 | Computers & Internet
USB DEvice not recognized
My apologies faizakhatib. I see that you did, indeed, provide the make and model of you laptop. Thank you for that.
Some additional suggestions:
(A) Please, make sure that your laptop's A/C adapter is plugged in while trouble-shooting this issue. We don't want to complicate the matter w/ a possible low-power issue.
(B) Worse case, your laptop's USB interface may have failed (hardware failure). To repair this would necessitate replacing your motherboard. You can work around this issue, however, by using a laptop PC card w/ USB ports.
Please, get back to us w/ your answers and we'll work w/ you to diagnose this issue.
Thank you,
BJ
Apr 02, 2008 | Dell Inspiron B130 Notebook
SimpleTech External Hard Drive 320GB Not turning ON
Don't worry...You have just to buy new external...Hdd is fine...
Feb 19, 2008 | Computers & Internet
NexxTech NSMODX2 Logo
165 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Joe Goldman
Joe Goldman
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
