Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Hunter model 44260 keeps chirping
The filter sign was on. I replaced the filter and reset the filter light. The chirping remains. How do I get it to stop?
5 Suggested Answers
  • 52 Answers
SOURCE: Hunter 44260 thermostat
Here is a link to directions on setting up the programming modes on your t-stat. Follow them and you should be fine. Good Luck
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
Posted on Jan 29, 2008
SOURCE: programming
program a thermostat
Posted on Nov 01, 2008
Benimur
  • 6966 Answers
SOURCE: Hunter Thermostat fan won't turn off
Hi and welcome to FixYa,
Initially, I am inclined to suspect 3 possibilities:
  • sticking relay contacts (if used) (a possibility, least likely);
  • dusty thermal sensor/switch for the fan (likely);
  • time delay. design feature, will power down the fan only after a certain period that the heater has turned off. This is to dissipate residual heat not only on the heater but on the immediate surroundings of the heater element (most likely).
Good luck and Thank you for using FixYa.
Posted on Jan 01, 2009
milten1
  • 1304 Answers
SOURCE: Hunter 44260 Thermostat Problem
make sure you have the jumper in place
if you dont have a secondary heat source red should be on r with a jumper to rh
Posted on Oct 17, 2009
Hunter air filter when you turn it on it keeps cycling- on/off,on/off and wont stay on. also hepa filter button not working any more, does not light up blue when pressed. TY for any help : )
Hello, this is Ava with Think Crucial.
If your unit has a reset button, try resetting your unit. Also, replacing the filters and resetting it after putting on the replacement filters usually works. If this fix doesn't work, I suggest you contact Hunter support for assistance and their number is 888-830-1326.
You can purchase a wide variety of high quality Hunter replacement parts for your Hunter Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=hunter
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Oct 01, 2016 | Hunter Air Purifiers
My thermostat displays E What does that mean?
Hi, that is the indication for "Error" and you should first replace the (2) AA batteries in the thermostat, (even if you just replaced them recently) and then using a small paperclip, reset the thermostat, by inserting the unbent end of the paperclip into the reset hole next to the keypad.
Be advised that this will reset the thermostat to the default temperature and time cycle settings, so you'll have to reprogram the unit, once you've reset it. With your unit, you only need to set a weekday setting and one for each of the weekend days.
Here's a copy of the instructions for your use in resetting and reprogramming the thermostat, once you've replaced the batteries.
http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/44260.pdf
You can also contact Hunter tech support, should the above info not get your thermostat back in working order by calling them at 1-888-830-1326, from 8 AM to 5 PM Central Time.
I hope you find this Very Helpful and best regards!
Nov 11, 2009 | Hunter Fan Company 5/1/1 Programmable...
Oct 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
What is the term. y1 used for 0n the hunter thermostat
y is the condensing unit outside trace the wire b is used as a common in most cases but it all depends on what the installer decided to use. Be careful not to burn up your transformer or circuit board.
Aug 11, 2009 | Heating & Cooling
Hunter Fan Model 44260 eats batteries
you have to replace the thermostat . problems like this are common with latest electronic thermostats from china . most are going bad in less than 4 years . it so bad ,i am telling anyone who asks , to please keep there old regular thermostat , or if you have one of the old electronic ones (made over 10 years ago) hold on to it , it will last forever.... somehow when we moved the factory to china they forgot how to make thermostats that last ........ if you plan to rate this answer , please rate it 3 or 4 stars . this will help me stay in the paid answer department
Apr 01, 2009 | Hunter Fan Company 5/1/1 Programmable...
Lights still flashing after i replaced filter
You have to press the reset button on some models. The unit does not have any way of knowing you reset the filter -- you have to tell it.
Mar 22, 2009 | Hunter (30067) Air Purifier
Jan 01, 2009 | Hunter Fan Company 5/1/1 Programmable...
Nov 30, 2007 | Hunter Fan Company 5/1/1 Programmable...
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Hunter Fan Company 5/1/1 Programmable Thermostat Logo
    94 people viewed this question
    Top Hunter Dryers Experts
    Paul Bade
    Thomas Perkins
    Thomas Perkins
    Are you a Hunter Dryer Expert? Answer questions, earn points and help others
