Canon ir500 doc feed
I need to find a parts catalog for a document feeder on an IR5000 canon copier. don't have a clue how to find. I belive it will be separate from the copier parts catalog. please email me.
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Try these people they can get it and the $ is not bad, I get all my partd from them.
Posted on Aug 27, 2008
Auto doc feed does not activate
two possible problems :
- check the connection of the document feeder
- check the sensor on the document feeder that triggers the pickup
- check the clutch of pickup roller
Jul 27, 2012 | Canon PC-795 Copier
The scan feature, can it scan docs to my computer for easy emailing?
the Ir5000 i belive can't scan to email.... but i believe the ir5020 does. what you need to make it scan to email is a program like E-Copy Desktop. which can scan from the copier to your computer as a pdf.
Jun 15, 2010 | Canon imageRUNNER 5000 Copier
Canon IR 105 Will Print from Network and Fiery but won't copy
So, the feeder will not pull in the paper, If this is the case, check the throat of the document feeder for foreign objects, (staples, paperclips, post it notes, or signature flags). you can clean the rollers with alcohol, and blow out the document feeder with compressed air. (Computer Duster)
Hope this is of some help.
May 06, 2009 | Canon imageRUNNER C3200 Copier
Doc Feed Problem
I would replace the Pick-up roller, Feed Belt, Sepearation roller, and torx Limiter for starters IF you cannot replace them, Clean them with warm water and soap, let them dry, and try the doc feeder, Most Multi feed problems are Torx limiter or clutch problems.
Apr 11, 2009 | Office Equipment & Supplies
NP6050 false paper jam at doc feeder
When you put documents in the feeder and you push start do you see 2 black arms swing out to count the number of orignals? If yes, dose the doc tray begin to go down and then jams? If yes, you can try something.... OK, turn the copier off and move the 2 paper guides of the doc tray toward the middle. You need a #2 philip's head screw driver. Remove the 2 silver screws that will be sunk in a bit on the top of the doc tray. Once you remove the screws, remove the top part of the doc tray and you will have one connector toward the front. Unplug it and replug it back in and see if that works, if so return the 2 screws and you should be OK.
Dec 12, 2008 | Canon NP 6050 Copier
Document Sheet Feeder
hi im jules_09,check the pick up,bottom plate and feedout motor then the rollers,then the fed belt,also try lobricating the gears,check all parts first before replcing it save you time and money.
Nov 08, 2007 | Ricoh Aficio 450 Copier
Auto Document Feeder
has the feeder attempted to feed in the document ? Check to see if there is already a document on the copyboard platen
Apr 27, 2007 | Canon PC-980 Color Copier
120 people viewed this question
