Question about Sony Handycam DCR-HC30 Mini DV Digital Camcorder
I have all the drivers, all the hookups and yes my computer does show that I have a CD-R installed in my drive "D". I do what the instructions say. I go to the menu to burn a VCD. Then when I hit "EXEC" on the camcorder LCD screen an error message come up that states: "Insert a recordable CD-R disc." As stated earlier there is a blank CD-R in my drive "D". In the Sony Picture Package VCD Maker if I click "Start", I also get a similar error message that states: "There is no disc in the destination drive. Please insert a blank disc in the destination drive". OK now it gets more confusing. In the Picture Package VCD Maker if i click options there is nothing in the area shown as "Target Drive" and then if I click on adjust and confirm USB stream I get the USB Streaming Tool. This is the only way I can get to the USB Streaming Tool. I go through all the steps, click done and it takes me back to the options page. I click OK and then I am back to the picture package page. I can't even figure out how to copy to the computer becasue I am not getting the proper options. The only other option I can see for myself is to hookup my old analog capture device and then make a DVD through another method. Don't I want to be able to make a VCD or DVD digitally? Can anyone please help me??
3 Suggested Answers
SOURCE:
welcomejee
  • 10594 Answers
SOURCE: Can't Detect Camera DCR-HC19E
Check properties of Picture Package or reinstall software to clear any bugg in it.
Posted on Jun 21, 2008
ripleymojica
  • 643 Answers
SOURCE: Copy problem with Sony DCR-HC30 camcorder
go to esupport.sony.com to upload a patch that will help with this prob.
Posted on Jul 02, 2009
When i connect my wd 500 gb external hard disk to my pc windows notifies me with an error reporting "problem occurred during hardware installation.your new hardware might not work...
  1. Restart the computer in Safe Mode.
  2. Rename the Driver.cab file that is in the following folder:
    C:\Windows\Driver cache\i386
    For example, rename the Driver.cab file as
    Driver.old.
  3. Insert the Windows XP CD-ROM into the CD-ROM or DVD-ROM drive.
  4. When the Welcome screen appears, click
    Perform additional tasks.
  5. Click Browse this CD, and then double-click the I386 folder.
  6. Click the Driver.cab file, and then on the
    Edit menu, click Copy.
  7. In Windows Explorer, open the following folder: C:\Windows\Driver cache\I386
  8. On the Edit menu, click
    Paste to paste the Driver.cab file in the C:\Windows\Driver cache\I386 folder.
  9. Remove the device that you tried to install.
    For example, if you received the error when you tried to install a printer, follow these steps to remove the printer:
    1. Click Start, click Control Panel, and then click Printers and Other Hardware.
    2. Click Printers and Faxes (or the icon representing the type of device that you want to remove).
    3. Right-click the printer that you want to remove, click
      Delete, and then click Yes to confirm deletion of that printer.
    -or-
    Use Device Manager to remove the device. For example, if you received the error when you tried to install a modem, follow these steps to remove the modem:
    1. Click Start, right-click My Computer, click Manage, and then click Device Manager.
    2. Expand Modems, select your modem, and then press DELETE. Click Yes to confirm.
  10. Restart the computer. Your new device should be detected and automatically installed.
Nov 12, 2017 | Western Digital WD HDD 500GB SATA 25"...
Acer Notebook was getting slow then i try to reset then after the process it restarted then said "Setup is starting services". It shows a error message "The computer restarted unexpectedly...
A scratched cd/dvd can have errors causing the install to fail. Use a clean cd/dvd install disc to fix it.
If you are trying to install directly from the hard drive then a malware infection could have corrupted or damaged that part of your hard drive. Install windows from the cd/dvd disc for your computer.
Aug 28, 2011 | Acer Computers & Internet
Installing DVD-RW LiteOn iHAs124-04 b AL0L with Windows 7 64bit but getting "Device driver software was not successfully installed." General Device Properties show:" Windows cannot load...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Apr 26, 2011 | Lite On LiteOn IHAS124-04 Black 24X SATA...
Gateway gp7-750 >both of my
Do this:
http://support.microsoft.com/kb/982116
Apr 04, 2011 | Gateway Computers & Internet
Hi, I've just bought a Sumvision Cyclone Primus 2TB and after connecting it to my laptop it installs the drivers. Once this is complete a Microsoft Windows pop-up comes up saying "you need to format...
Try putting the unit back on your laptop and using the windows disk management utility. The directions are below. Windows Vista is a bit differenct than either windows 7 or XP.
Right click on you "Computer" Icon in your start menu
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive that is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
See if this helps you manage the external disk and get it formatted so you can use it on your laptop.
If you found this answer helpful, please remember to leave positive feedback.
Thank You,
Brian
Mar 02, 2011 | Office Equipment & Supplies
I was trying to copy a CD, and my system failed to the job. I think there was a window that said "retry", "skip", "cancel". I accidentally click the skip button instead of...
Hello Jean1042, I can give you a video that will help you solve this problem and I will do it, but in my particular opinion you can achieve the same task with other applications that actually work better and have more options, I also leave a link to the that I use (does not have to change, it's just an opinion)
2) Official download of VLC media player the best Open Source player VideoLAN
3) http://www.burnaware.com/download.html
Feb 28, 2018 | ASUS VIA Apollo Pro133 Chipset P3V133...
Cd and dvd do not work
  1. what OS? XP? if yes, is SP3 installed? XP has big troubles with dc/dvd or BRD drives. so, say what OS first.
  2. driver must match OS, so....
  3. what media are you attempting to read, CD, DVD, Blueray
  4. is said media, (real) or is it record-able , like CD-r or DVD-R
  5. we have idea what you have there , only a620 old.
May 06, 2017 | HP (176135-630) (176135630) Internal 48x...
Sony Handycam DCR-HC30 Mini DV Digital Camcorder Logo
90 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
