Question about HP Office Equipment & Supplies
Fax not connecting need to set it up with a new number
    Genius:
  • 2,120 Answers
Need more info!
Posted on Sep 01, 2008
We have the HP office jet pro 7780 I have a new phone number and need help programing a new number in the fax machine to receive fax
1 Click the Set-up button 2 Go to Fax Settings/Fax Set-Up/Basic Fax Set-up (Whatever you get to see first) 3 On Fax Header, press okay 4 And then just enter your name, hit ok 5 And then it will be asking you to enter your Fax NUMBER 6 HIT OKAY again.
I hope this helped.
Feb 08, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
IT WILL RING BUT GOES TO ANSWERING MACHINE DOES NOT RECEIVE FAX
>first run fax test, press set up go to tools menu then select run fax test,all entries should be pass
>then check your connections, do you have one line or number for your fax and phone?or a separate line or another number for fax and another number for phone?
>let me assume you only have one number for fax and phone..
>check connections, this should be downstream connection, the fax machine using the black phone cord provided by hp should be connected directly to the phone jack using line 1 at the back of the fax and the answering machine or the telephone should be connected to ext 2 or line 2 at the back of the fax...there should be no other devices phone or answering machine connected directly to the phone jack.
>next set rings to answer on the fax machine higher than the answering machine...if your rings to answer on answering machine is 4 rings, set the fax to 6 rings...if it is a voice call the answering machine will pick it up at 4 rings then if it detects that it it a fax tone then it will transfer the call to fax.
>also check if auto answer is on in your fax
>you can check auto answer and rings to answer by pressing set up or menu button on your machine look for it in basic fax settings or advance settings
>also check if your voice prompt for your answering machine is not too short there should be like at least 5 seconds after cutting your message to allow the machine to transfer the call to the fax if it is a fax tone.
Sep 14, 2009 | HP 1040 Plain Paper Inkjet Fax
Toshiba estudio16s need to change fax# inside machine
You have to change your OWN ID (fax) number through the menus.
Aug 03, 2009 | Office Equipment & Supplies
I am having problems receiving a fax.
Check the number of rings your fax machine is set to. Chances are, the answering machine is set up for 4 rings and the fax machine is set up for 6. If this is the case, change the number of rings on your fax machine to 2 or 3 rings to ensure an incoming fax will go directily to the fax machine. If the fax doesn't recognize the call as a fax, it will go through to the answering machine.
Jul 17, 2009 | HP 1040 Plain Paper Inkjet Fax
Our 2920 bother fax machine still has our old fax number on all printed paperwork. Could you please advise how we can change this to our current number? Thanks Lucy
You can change the Fax ID in the menu. It should be located in Menu/Set 0,3 (Station ID). Enter your new fax number, menu/set, new phone number, menu/set, your "name", menu/set. And you're set.
Jun 03, 2009 | Brother IntelliFAX 2920 Plain Paper Laser...
Fax connection
To send a fax, you will have to configure the settings. here are the steps you can follow;
Remote Fax Options;
You can only use one remote fax option at a time:
Fax Forwarding—OR—Paging—OR—Fax Storage—OR—PC FAX Receive—OR—Off.
You can change your selection at any time (Menu/Set, 2, 5, 1).
Setting up Fax Forwarding
When you select Fax Forward, your MFC stores the received fax in the memory. The MFC will then dial the fax number you’ve programmed and forwards the fax message.
  1. Press "Menu/Set, 2, 5, 1".
  2. Press ▲ or ▼ to select "Fax Forward". Press "Menu/Set". The LCD will ask you to enter the fax number to which faxes will be forwarded.
  3. Enter the forwarding number (up to 20 digits). Press "Menu/Set".
  4. Press ▲ or ▼ to select "Backup Print:On or Backup Print:Off". Press "Menu/Set".
If you select "Backup Print:On", the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is forwarded.
5. Press "Stop/Exit".
Programming your pager number When Paging is selected, your MFC dials the pager number you’ve
programmed, and then dials your Personal Identification Number (PIN). This activates your pager so you will know that you have a fax
message in the memory.
1. Press Menu/Set, 2, 5, 1.
2. Press ▲ or ▼ to select Paging.
3 . Enter your pager phone number
followed by # # (up to 20 digits). Press Menu/Set.
Do not include the area code if it is the same as that of your MFC. For example, press 1 8 0 0 5 5 5 1 2 3 4 # #.
4. If your pager needs a PIN, enter the PIN, press #, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press 1 2 3 4 5 # Redial/Pause 1 8 0 0 5 5 5
1 2 1 2 # #) —OR— If you do not need a PIN, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press Redial/Pause 1 8 0 0 5 5 5 1 2 1 2 # #)
5. Press Stop/Exit.
■ You cannot change a Paging number or PIN remotely.
■ If you have set Paging, a backup copy of the received fax will
automatically be printed at the MFC.
Setting Fax Storage
If you select Fax Storage, your MFC stores the received fax in the
memory. You will be able to retrieve fax messages from another
location using the Remote Retrieval commands.
1 Press Menu/Set, 2, 5, 1.
2 Press ▲ or ▼ to select
Fax Storage.
Press Menu/Set.
3 Press Stop/Exit.
Setting PC Fax Receive
If you select PC Fax Receive, your MFC will temporarily store your
received fax messages in its memory, and then automatically send
the faxes to the PC. You can then use your PC to view and store
these faxes.
PC Fax Receive.
Press Menu/Set.
3 Press ▲ or ▼ to select
Backup Print:On or
Backup Print:Off.
Press Menu/Set.
4 Press Stop/Exit.
If you have turned on Fax Storage, a backup copy will
  • Before you can set up PC Fax Receive you must install the
MFL-Pro Suite software on your PC, make sure your PC is connected and turned on. (For details, see Using Brother PC-FAX software on page 5-1 in Software User’s Guide on
the CD-ROM.)
  • If you select Backup Print:On, the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is sent to the PC.
■ If you get an error message and the MFC cannot print the faxes in memory, you can use this setting to transfer your faxes to your PC.
Turning off Remote Fax Options If you set the Remote Fax Options to Off and there are faxes in your MFC’s memory, the LCD will give you two options.
  • If you press 1, all unprinted faxes will be printed and erased
before the setting turns off. If a backup copy has already been
printed it will not be printed again.
  • If you press 2, the memory will not be erased and the setting will be unchanged.
Setting your Remote Access Code
The remote access code lets you access the Remote Retrieval features when you are away from your MFC. Before you use the remote access and retrieval features, you have to set up your own code. The default code is inactive code (--- ).
  1. Press Menu/Set, 2, 5, 2.
  2. Enter a three-digit code using numbers 0-9 or . Press Menu/Set. (The preset ‘ ’ cannot be changed.)
  3. Press Stop/Exit. Do not use the same code which is set in your Fax Receive Code ( 51) or Telephone Answer Code (#51). You can change your code at any time by entering a new one.
  4. If you want to make your code inactive, press Stop/Exit in Step 2 to restore the inactive setting (--- *).
May 05, 2009 | Brother MFC 7420 All-In-One Laser Printer
Fax problem
I will assume this is an inbound fax.
Your fax machine has a setting for answering on a number of rings, normally between 1 - 4. Check it's settings and lower the number to meet your needs, so the fax picks-up before the answering machine.
Nov 19, 2008 | HP Photosmart C7280 Laser Printer
HP 4110 OFFICEJET ALL IN ONE
Hi red,
You may need to set the fax as the default answerer of incoming calls. Here's a little tip, most local phone companies offer a distintive ring feature that only the fax will answer. If you get the option your users manual will tell you how to set up this feature and whats neat about is you get a seperate
number for that feature, your own dedicated fax line without add any extra outside lines.
anaanymous
Aug 17, 2008 | HP Officejet 4110 All-In-One InkJet...
Resetting the phone number currently displayed on the top of the page
On your fax control panel, press the MENU button. Choose either INITIAL SET-UP or FAX SET-UP, from the display. You should be able to scroll through the settings until you come to either HEADER, TITLE, NAME, STATION ID., or PHONE NUMBER. You can then use the number and letter keys to change the title and phone number.
Aug 09, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Fax number
Press fuction 7 1 key in date & time press set
May 22, 2007 | Panasonic Panafax UF-560 Plain Paper Laser...
16 people viewed this question
Ben Johnson
