Question about HP PSC 2175 All-In-One InkJet Printer
Error : right cartridge incorrect.
I printed two sheets and then copy, scan and photo card started flashing and it says error " right cartridge incorrect". I removed and reinstalled and also turned it off. It just continues to flash and say error " right cartridge incorrect".
  • Anonymous Oct 12, 2008
  • Anonymous Oct 15, 2008
    tried three cartridges, still says remove and check cartridge. Last HP I buy.
  • 57 Answers
SOURCE: scanner failure
I understand that you are receiving Scanner failure error.
Please follow the below given instructions to get the issue resolved.
Please remove the All-in-One Printer from the Power Surge Protector and plug it directly into a wall Power outlet, as the surge protector may not provide enough power to printer.
Let us power cycle your All-in-one to remove any static electricity in your All-in-one.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
Please try installing the below patch and check for the result:
Just copy and paste the entire link into the Internet browser's address bar and press enter
If the issue persists, try resetting the All-in-one to factory defaults by following the below given instructions:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold Cancel and the Right Arrow while plugging in the power cord.
Continue holding until it displays S Full Reset message in the front panel of the All-in-One.
This should resolve the issue.
Posted on Feb 14, 2008
SOURCE: machine does not recognize refilled office max cartridge (black)
try to clean the cartridge on the copper side with tissue with and alcohol maybe the contact points doesnt meet or the cartidge itself is already defective. try also use an empty good cartridge just to to determine wich cartridge is defective.
Posted on Apr 23, 2008
SOURCE: 2175 printer
I had the same problem- printer alignment cancelled in the middle and couldn't print or get rid of 'align cartridges' message. Went to HP website page
and discovered that you can bypass alignment. For my psc2175 I just had to hold Setup key and then press Options. Problem solved!
Posted on Jun 09, 2008
  • 8637 Answers
SOURCE: My Lexmax X4530 gives ink cartridge error message
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
  • 2306 Answers
SOURCE: When turning power ON, a clicking noise coming
Sounds like the scan assembly is worn out. If you lift the cover where you lay a copy and watch the scanner after youpower up, you might see the scanner just clicking back and forth, which means the lamp is worn out or dirty. Repairs in that case are more than the machine is worth.
Posted on Jul 02, 2009
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
Apr 28, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
My lexmark 7170 printer has error message : right cartridge incorrect. I pulled the brick. Waited a few minutes, replaced but error still appears. Turned off and on etc. Lexmark quide was not helpful. any...
You are trying to put the wrong catridge into right hand side,. the catridge you have put is incorrect. try removing the catridge and put the right catridge back
Jan 09, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Apr 28, 2009 | Office Equipment & Supplies
Incorrect right cartridge
Ive tried removing the right cartridge so I can print in black, but now , once I refilled the black one, it wont even let me print black!! this is desperate; can anyone help?
Aug 09, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Hp psc 950ink cartridge alignment
In my experience, the <align cartridge> happens when you change ink, has a [don't do {HP chat would be a help}] and wouldn't let you print or scan either unless completed.
normally prints a [2] sheet, then asks to scan it.
for photo quality, override isn't reccommended.
does copy work at all?
scan, save, print might work
Jun 09, 2008 | HP PSC 950 All-In-One InkJet Printer
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Printer cartridge
try a new cartridge, or try cleaning the contact inside where the cartridge sits.
Jun 04, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
HP PSC 2175 All-In-One InkJet Printer Logo
194 people viewed this question
Ben Johnson
