You should always follow the instructions on the manual .. I have a 18X33X4 oval and had to start with over 350 lbs of salt and ran the pump without the chlorinator for 24 hours to properly disolve the salt. Then, I started with 12 hrs pump cycle with 10 hrs of chlorination in between the 12 hrs. Keep checking the chlorine level and adjust time from there. Currently at temperatures of 85 to 100, I run the system at 10 hrs pump with 8 hrs chrlorinator and water is Crystal Clear... In the 2 years with the intex system, I have not added any chemicals to my pool. I once had an issue when the water level went low while I was on vacation, when I came back, the chrolinator had turned off due to low flow and my pool water was green.. As soon as I re-started the cycle, a few days later, Crystal Clear again... NO CHEMICALS OR SHOCK added.... Hope this helps....
