Question about Brother GX-6750 Typewriter
Brother typewriter GX6750
My correction ribbon is all twisted and I can't seem to fix it or get this to work. I could change the ribbion but I would be doing that all the time. Thank you. Helen
    Scholar:
  • 183 Answers
When you put the correction tape in make sure it is in the guides on both sides and also between the two metal fingers and the metal cardholder. Also make sure the ribbon goes in the same place.. The dull side of the corr. tape should be towards the platen or it won't correct.
Posted on Oct 28, 2008
How can I fix balnk screen issue with my HTC One X? It seems like a dardware problem since it gets temporary fixed by a little twisting.
Open it and check the ribbon cables to/from the screen is correctly seated. In fact ...Check all ribbon cables.Could be a faulty screen but also poor ribbon connection
Jul 30, 2014 | HTC One X Quad-core 1.5 Ghz 8mp 4.7" Lcd...
The correction mechanism seems to work but the letters do not get corrected.
First be sure the ribbon and L/O tape are fresh (not sitting around for long periods of time) be sure the ribbon is correctable, the manual feed knob should be yellow or orange.
DickyO
Aug 11, 2010 | Brother Office Equipment & Supplies
Changing ribbion
Go to brother.com, click on support you will find a manual there.
DickyO
May 19, 2010 | Brother SX-4000 Typewriter
I want to change out the screen, my screen is beat
becareful..it isnt that diffacult..just dont rip the little ribbion cables..when taking the hinge off is difficult the ribbon cable makes a twist threw the hinge make shure you un plug it under the keyboard first..
Nov 10, 2009 | Motorola Mobility RAZR V3
I have a ribbion out error when there is a ribbion in place it is set to thermal transfer as needed for this type of printing. I have cleaned the lazer. Im not sure what else to do.
Use the Menu system to recalibrate the printer, this should fix your ribbon out issue, if it doesn't you might have a failed sensor.
Sep 29, 2009 | Zebra Z4M Printer
Need to change the printer ribbon on ibm 6400
BY WWW.IBM.COM/SERVICE
GO ON LINE AND TYPE THE FOLLOWING:
HOW TO CHANGE A PRINTER RIBBON IBM 6400
BEFORE YOU DO ALL THAT FIND THE RIBBON BOX AND SEE IF IT HAS ANY TYPE INSTRUCTION WHAT TO DO?????????
ROD
May 12, 2009 | IBM 6400 Matrix Printer
Correction ribbon balls up after a short time.
Be sure that you have a dry L/O tape Gen. Ribb. # t355 or equivwlent if you are using a tacky ribbon it will give you fits.
DickyO
Jan 19, 2009 | Smith Corona Office Equipment & Supplies
No print with ribbon
Did you put a ribbon in your printer? The zebra does both direct thermal and thermal transfer, but you need a ribbon to get it to print AND have to change the settings to let the printer know that it needs to use the ribbon instead of direct thermal.
Jan 08, 2009 | Zebra Z4M Printer
Correct key
Two possibilities, one the correction tape is twisted and the wrong side is .facing the paper. The shinny side should be facing you, the dull side facing the paper. Second possibility you must make sure the ribbon is compatible with the correction tape. There are 2 types of ribbons. A correctable one (orange or yellow knob) and a multi strike (blue or purple knob on ribbon cartridge). The lift off correction tape (orange or yellow spools) only works with the correctable ribbon and the cover up correction tape (blue) works with the multistrike ribbon.
Jul 07, 2008 | Brother ML-100 Typewriter
No Boot . Does not recognize any drives ! Thank You cybergeezzer@hotmail.com
Its motherboard problems or drives not plugged in correctly.
It could be that your motherboard is faulty & need to be change or your just not plugging in your ribbion in correctly.
If your ribbions are it correctly & still doesn't work tyhen you need a new motherboard.
Get bac at me then i'll advice you which motherboard is best to get...
KJ
Apr 22, 2008 | Computers & Internet
Brother GX-6750 Typewriter Logo
88 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
