Question about Olympus Camedia C-3030 Zoom Digital Camera
Are there any custom settings that *should* be changed initially
I am, however, not all that interested in changing and rechanging any of the camera's options. I pretty much just want to set it up at the SHQ setting initially and then always be ready to go (most of my shots are indoors, with some daytime outdoor shots). With that in mind, are there any custom settings that *should* be changed initially (I guess I'm thinking in regard to white balance, etc.) and then I can forget about it?
    Master:
  • 852 Answers
I have the C3000Z,so it should be the same. I don't have my camera or manual here at work with me today, but, there IS a setting that you enable in the menus that basically tell the camera NOT to reset all your settings back to defaul when you turn the camera off. Then, the settings you change will be "permanent" when you turn the camera off. I do the same thing with my camera.
Posted on Sep 07, 2005
Reset factory setting
Not sure this is enough, but here they come:
Delete settings:
Choose the wrench tab (top of the menu page) then choose delete settings. then press the (set) button.
Delete camera settings:
In the same menu tab, you also find delete the camera settings.
There press the (set) button. This will change everything you ever changed in the camera, back to the initial settings. I could not find e general reset.
Nov 17, 2013 | Canon EOS 600D Rebel T3i Digital Camera
I have sony DSC-W190,i want correct menu setting ,bcos if i take a picture its not clear,i think may be menu setting changed,idnt any idea about menu setting pls help.....
If the Menu settings in the camera is changed, then I suggest you to reset the Camera back to factory default. Initializing the Camera back to factory default will set all the settings in the Camera back to factory default.
To initialize the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
You can also try a manual reset;
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
The blurry image capturing can also adjusted by changing the ISO Settings or the Scene Selection modes.
Thanks for using FixYa!
Apr 07, 2011 | Sony Cyber-shot DSC-W190 Digital Camera
How to calculate interest rate based on original balance and payment amount using BA II Plus
Work with the simple formula: Interest = Initial * rate * time
To find the total amount, add the Initial plus the Interest, then subtract what has been paid. This will change the amount of money that will be accruing interest, though, so if there is a payment schedule you will need to repeat this calculation to get an exact number.
Find more information on wikipedia: http://en.wikipedia.org/wiki/Interest#Simple_interest
Mar 07, 2011 | Texas Instruments BA-II Plus Calculator
How to change the color mode on nikon d50
here is where to find the settings
press MENU button
select Shooting Menu (camera icon)
select Optimize Image
select Custom
the color mode is here. mode 1 is standard RGB
mode 11 is Adobe RGB
mode 111 is for custom color settings, it allows you to increase/decrease a number of settings relative to color.
once you make a change be sure to press the "done" button or your changes will be lost...
Jan 12, 2011 | Nikon D50 Digital Camera with 18-55mm Lens
Camera only takes one or two pictures then message tells me to change batteries. Batteries are new and camera turns off.
After surveying the web, I see that this problem has been around for at around 3 years. I use fully charged NiMh batteries and get the “change batteries” message after only a few shots or immediately.
In my case, changing to alkaline 1.5V batteries solves the problem (versus ~1.3V for NiMh or other rechargeables.) Cleaning the contacts (stainless steel) makes no difference.
Interestingly, I can operate the camera in the playback mode and view pictures and movies with no problem. This involves driving the display on the camera back, probably the most power hungry part of the instrument. This suggests the problem is record mode specific.
My guess is that there is a voltage reference problem. References can drift over time, and depending on the initial value, cause problems any time during a camera's life. The reference isn't necessarily needed in playback but is critical for recording should the image sensor voltage be too low.
Jul 28, 2010 | Canon PowerShot S5 IS Digital Camera
How can I increase the memory for this computer
In Windows XP
1.Click Start, and then click Control Panel.
2.Click Performance and Maintenance, and then click System.
3.On the Advanced tab, under Performance, click Settings.
4.On the Advanced tab, under Virtual memory, click Change.
5.Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
6.Under Paging file size for selected drive, click to Custom size check box. You can enter the amount of memory you would like to reserve for Virtual memory by entering the initial and maximum size.
7.Click Set
When you are prompted to restart the computer, click Yes.
Special Note: You should choose the same amount for the initial size and maximum size. This will Stop your CPU from constantly changing the paging file.
In Vista
1. Click Start button Picture of the Start button
2. Click Control Panel
3. Choose System and Maintenance and then click System.
4. In the left pane, click Advanced system settings.
5.On the Advanced tab, under Performance, click Settings.
6. Click the Advanced tab, and then, under Virtual memory, choose Change.
7. Click Custom to change the Initial size (MB) and Maximum size. See the hot tip above.
Remember to choose the drive you would like to use to increase the virtual memory. In most cases it usually your C: Drive. You can set the initial size and maximum size after clicking the Custom size check box.Remember its better to keep the Virtual memory values the same.
Also having enough available space is absolutely necessary for your virtual memory and RAM to function properly.
Jun 11, 2010 | Compaq Presario 700 470024-192 Notebook
Can't run Brain Play Jumpstart Spanish from Scholastic
How to increase Virtual Memory?
In Windows XP
7.Click Set
HOT TIP: To stop your CPU from constantly changing the paging file, set the initial and maximum size to the same value. For example, 500 and 500. The value should be at least 1.5 times more than your physical RAM. If your computer has 512MB of RAM increase the virtual memory paging file to 1.5*512= 768
In Vista
May 13, 2009 | Vivendi Jumpstart Spanish (72019) for PC,...
My Sony DSC-H2 image size setting have changed.
RESET camera through Initialize option in Menu. Camera will go to factory default settings and picture size will be OK.
Jan 15, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
Samsung nv 24 set wrong language on initial setup, how do i fix this please?
Hey herculep,
A graphic example of how to change your language is on page 70 of you camera manual. This is done under the setup menu. I have included a link to a PDF download of your user manual in case you need it. I hope this helps!
http://www.samsungcamera.com/customer/cus_main.asp?cat_uid=75
Sincerely,
Allan
Go Ahead. Use Us.
Jul 24, 2008 | Cameras
Memory stick pro duo pc connection
To change the size of the virtual memory paging file
You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings may also prevent you from completing this procedure.
  1. Open System in Control Panel.
  2. On the Advanced tab, under Performance, click Settings.
  3. On the Advanced tab, under Virtual memory, click Change.
  4. Under Drive [Volume Label], click the drive that contains the paging file you want to change.
  5. Under Paging file size for selected drive, click Custom size, and type a new paging file size in megabytes in the Initial size (MB) or Maximum size (MB) box, and then click Set. If you decrease the size of either the initial or maximum page file settings, you must restart your computer to see the effects of those changes. Increases typically do not require a restart.
Note:
  • To open System, click Start, point to Settings, click Control Panel, and then double-click System.
  • To have Windows choose the best paging file size, click System managed size.
  • For best performance, do not set the initial size to less than the minimum recommended size under Total paging file size for all drives. The recommended size is equivalent to 1.5 times the amount of Ram on your system. Usually, you should leave the paging file at its recommended size, although you might increase its size if you routinely use programs that require a lot of memory
  • To delete a paging file, set both initial size and maximum size to zero, or click No paging file. Microsoft strongly recommends that you do not disable or delete the paging file.
Feb 10, 2008 | Computers & Internet
Olympus Camedia C-3030 Zoom Digital Camera Logo
29 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
