Question about Stanley 100 ft. Tape Measure, FatMax
Measuring Accuracy Problem
How can i know if my measuring tool accuracy is correct, I think it has a problem.
    Problem Solver:
  • 9 Answers
Hello, I would say that kksalm gave the easy way to confirm. I say the same , if the level the reading will be the same 180 deg. rotated Good luck, Jack
Posted on Aug 21, 2009
If you're using a laser, note the result at the distance you need it and then spin the laser 180 degrees and check to see if results match.
What is 1 1/4 on a measuring tape
Posted on Oct 08, 2008
  • 30 Answers
Use a second measuring tool and compare the results, or you can measure a known size or length (floor tiles for example)and check the reading you get.
Posted on Aug 27, 2008
Will tread depth of tires affect accuracy of nitestar dmi?
it will be absolute minimal and would be within the accuracy of the unit
as tread depth is around 3/8" on new tyres and is around 1/8 (legal) on worn tyres as you can see the difference is hardly worth mentioning
if the unit is measuring distance travelled then the shallower the tread depth the greater the chance of tyre slip when driving and that will affect accuracy
Jun 29, 2015 | Cars & Trucks
Nowhere in the little operations manual that came with my watch does it give the accuracy of the timepiece. Where can I get that information? I have a movado ESQ bracer chronograph.
Interesting question. I know little about watches but, as you would know, your watch does have a quartz movement, so, from Wikipedia, 'Quartz clock':
Standard-quality resonators of this type are warranted to have a long-term accuracy of about 6 parts per million at 31 degrees C (87.8 F): that is, a typical quartz wristwatch will gain or lose 15 seconds per 30 days (within a normal temperature range of 5 deg C / 41 F to 35 deg C / 95 F) or less than a half second clock drift per day when worn near the body.
If a quartz wristwatch is "rated" by measuring its timekeeping characteristics against an atomic clock's time broadcast, to determine how much time the watch gains or loses per day, and adjustments are made to the circuitry to "regulate" the timekeeping, then the corrected time will easily be accurate within 10 seconds per year. This is more than adequate to perform celestial navigation.
Assuming that you have a computer with internet-synced time and good internet, meaning around 1/100 second accuracy, why not compare the watch to the computer over the space of a week?
Sep 04, 2012 | Movado ESQ by Movado BRACER stainless...
How do you ensure the vernier scale is accurate on a pi tape?
Hello. Ensuring accuracy with a new unit should not be necessary. All Pi-Tape pruducts are:
"delivered with a Calibration Report traceable to the National Institute of Standards and Technology and all calibrations are performed in accordance with ANSI/NCSL Z540-1-1994, ISO/IEC 17025, ISO 10012-1, MIL-STD 45662A and 10CFR, part 21."
If the unit is second hand, the only real way to ensure accuracy is to verify the unit with a second calibrated vernier, or actually have it calibrated. Pi-Tape has a calibration lab. The link to contact them is: http://www.pitape.com/contactus.htm
Lots of other good info here as well. Hope this helps out.
Richard
Mar 22, 2011 | Enco 72"84" RANGE PI TAPE PRC DIAMETER...
How do you change the battery?
take the positive and negative off the old battery put in new battery replace cables
Jan 12, 2011 | Hanna Instruments Waterproof pH Tester...
I NEED AC GRILL TEMP MEASURING METER IN HI ACCURACY WITH OUT ANY LOSS WHILE MEASURING THE TEMP , PLS SHOW ME THE EQUIP DEVICE AND ITS FEATURES WITH COST
Please visit with this site and it will help you.
www.directindustry.com/.../digital-thermometer-61241.html - United States -
Jan 11, 2011 | Soleus KFS-12GW Air Conditioner
I need to know about the degree in precision for when using an ac and dc voltage for a multimeter
I dont think This particular model is a True Rms Type . So you will not get accurate reading as of a True RMS Multimeter in AC . But in DC you Should atlest get an accuracy of 0.015
Please Rate My answer well and Support me !!!
Nov 22, 2010 | Mastech Feature Digital Multimeter BuiltIn...
The probe won't measure the temperature, but it measures conductivity, pH and TDS accurately. 0.0 °C keeps flashing on the screen.
Is this probe in Robinair AC machine ? if so,the you neet to replase new one.because it seems to be broken ( probe tip sensor)
Jun 26, 2009 | Hanna Instruments Waterproof pH Tester...
Pls5 Accuracy problem
I will double check but pretty certain it was just out of adjustment in some way.
Aug 30, 2008 | Pacific Laser Systems PLS5 Automatic Laser...
Stanley 100 ft. Tape Measure, FatMax Logo
448 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Lawrence Oravetz
Vernon Taylor
Steve
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
