Question about Tricity Bendix AW1400W Front Load Washer
Wds1043m When put on spin cycle, water pump runs, motor that turns drum doesn't work, had motor checked out, it's good. What next ? This is model wds1043m, thanks, can't find it in your index
(x-a)(x-b)(x-c)....................(x-z)=?
Posted on Aug 27, 2008
My nec nwtl456 washing machine wont empty all water when spin complete anoying is it the pump or?
Can you hear the pump motor running when you first turn the program on, or during the spin cycle? a sort of glug glug noise when the drum is NOT turning. If you can, but the water is not draining, you have a blockage somewhere. If no glug glug then the pump is seized with a coin or pin etc and must be removed and freed or replaced.
Check any filters fitted first; remove and clean them. Lower the grey drain hose onto the floor - does water run out? if not, blockage maye be in sump hose or pump chamber (sock, etc)
If it does run out, blockage will be in connection to sink / waste pipe on your domestic plumbing.
Feb 03, 2018 | Washing Machines
Frigidaire washing machine (FTW3011KW0) runs through all cycles, agitates, pumps out water, but doesn't spin, nor does the motor attempt to spin during the spin cycle
Your main switch needs replaced. The motor that drives the switch operates because it goes through the other cycles, so the switch must be bad.
murf427
Jul 31, 2012 | Frigidaire Washing Machines
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
Maytag washing machine, model LAT2600AAE, stopped draining water in spin cycle. The motor agitates cycle but will not drain water. What can I do? I'm not a pro at fixing these things.
On the underside of the machine, you'll see the belts from the motor to both the drum and the water pump. If the belt to the pump is intact, check to see if it is loose. If so, you'll see 3 screws holding the pump housing in place. Try to readjust the pump so the belt is a little more snug. This worked for mine that was having the same problem. You may need to remove the front panel to reach the drain hose to drain your drum 1st - have a couple buckets and towels handy as well as someone else to run and dump your full buckets. Good luck.
Mar 30, 2010 | Maytag Washing Machines
Machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
Mar 30, 2010 | Tricity Bendix AW1400W Front Load Washer
Maytag washer, buring rubber smell, drum won't turn
the drum should run free if not the bearing have gone and seized they will need to be replaced. hear is a video there are others you can find the bearing kit on line using the model number https://youtu.be/WGolkFlgl3Y
Jun 22, 2017 | Maytag Washing Machines
Drum will not spin
I am the new owner of a used Asko Cylinda 10504.
The last owner briefly demonstrated the washer starting a wash cycle and entering the agitation cycle of the wash before stopping and pumping the water out and spinning in a final end cycle. I bought it. I had the machine installed turned it on and cannot get it to go through the wash cycle. After starting at #1 it goes through a perpetual spin cycle of sorts--water and soap soaking the drum and laundry but not enough water to fill up half way or less. It stops at number 4 on the program knob sits on a red dot (next to the #4) and does nothing. I then manually move it to the next cycle and it repeats the spin cycle again until I have advanced the program to the end. No wash cycle no rinse cycle. Nothing. When it advances to the red dot I wait for at least 5 minutes before manually advancing the knob. The instructions say that I should get the water pumped out by turning the program knob to #7 or #9 but in both cases it just spins and does no empty or finish in the end spin cycle of several (9?) minutes. Nothing but banging and spinning. The water seems to get into the drum as well as the detergent but nothing else is happening.
No mater where I start the program it spins and sloshes soapy water, pumping almost nothing out.
Any suggestions short of putting it on the curb or paying a kings ransom to fly a tech out to look at it?
MY GUESS.
It seems that it is repeating the same brief cycle over and over. During the move to my house the electronics re set(??!?!?) and now need to be set to the normal mode after being re connected?
Can you help?
Blessings,
Douglas
May 20, 2009 | Asko Washing Machines
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details you need to observe if machine is draining and pumping water inside during cycle, see: It doesn't spin
Jan 06, 2009 | Hotpoint WMA54 Front Load Washer
GE Top load washing machine stop and stars during spin cycle
I had the same problem. The machine will do the washing cycle. At the start of the spin cycle it would start turning with a lot of clicking sounds and then would stop spinning. The water pump would continue working without problem. The motor tries to start again in about three minutes, however, repeats the same behavior. I have a reasonable mechanical and electrical knowledge. I was sure that the overload protection switch of the motor was tripping. I opened up my machine---a GE super capacity top loading machine. Took off the belt and turned the transmission pulley. It turned easily in both directions (washing and spinning). Hence, the transmission was good. Next, I checked any water accumulation in the spin tub. If the water is not drained properly before the spin cycle, it would overload the motor. There was no water clogged in the spin tub. Finally, I dismantled the electric motor. There was a clutch assembly underneath the motor pulley. I dismantled it and found the clutch very dirty with some grease that had turned sticky. I cleaned the assembly thoroughly with alcohol and assembled back the machine. The machine is running perfect after that. Conclusion: The clutch assembly was mis-functioning. Reason: When the spin cycle starts, the spin tub is very heavy and cannot achieve the full speed quickly. On the other hand, electric motors must get to their running speed fairly quickly or else overheating of motor would happen. A proper functioning clutch allows the motor to run at their optimal speed while transferring enough torque to the spin tub to slowly speed up the tub to its fullest. In my case, the clutch was sticky, thus overloading the motor which would trip as it overheats.
Mar 31, 2008 | GE WDSR2080D Top Load Washer
Tricity Bendix AW1400W Front Load Washer Logo
96 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
