Question about Olympus Stylus 410 / ? 410 Digital Camera
Memory card size
I tried to put a 2gb card in and it locked up. It has a 256mb card stock. What other cards available will work? Thanks, Jerry
I don't know the solution but I did the same thing. I knopw it doesn't help, but!
Posted on Sep 02, 2008
Nikkon coolpix L1 After downloading memory card .. then putting back into camera. Reading says "cannot read memory card." Checked card out at store verified that it is good. Why does it not work in my...
A couple things you might try.. remove the card carefully and check the position of the "lock" tab. Make sure it is fully in the unlocked position - not locked or a point between the two positions. Reinsert and try again.
It sounds lie you're using a card reader to download the pictures - try formatting the card while in the card reader via computer. The card should be completely empty when the format is complete. You can even try copying files to and from the card to make sure its ok and format again. When complete, try again in camera.
If the problem persists, check to make sure the card is on Nikon approved memory card list for use with the Coolpix L1 (provided below):
The following is a list of approved memory cards for the Coolpix L1 digital still camera. These cards have been tested and approved for use with the Coolpix L1.
The L1 uses SD (Secure Digital) memory. Sandisk:
  • 64MB, 128 MB, 256MB, 512MB, 1 GB, 256MB*, 512MB*, 1GB*
Toshiba:
  • 64MB, 128MB, 256MB, 512MB, 1 GB, 128 MB*, 256MB*, 512MB
Panasonic:
  • 64MB, 128MB, 256MB, 1 GB, 256MB*, 512MB*, 1GB*
* - Cards rated for 10MB/s (high speed) Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
The list came direct from Nikon Support. Other cards may work, but only those on the list are approved. Successful use of other cards can not be guaranteed.
I hope this helps!
Sep 30, 2010 | Nikon D60 Digital Camera with 18-55mm lens
DEAR SIR, I HAVE C-150 WITH 16MB CARD. I WOULD LIKE TO UPGRADE THE MEMORY CARD. WHAT IS THE LIMIT AND WHICH CARD SHULD I PURCHASE IF SO.
The manual recommends "no more than 256mb"
>> Memory : xD-Picture Card (16 – 256MB)
Here's the manual (free download)
http://safemanuals.com/user-guide-instructions-owner-manual/OLYMPUS/C-150-_E
Whilst Olympus made the xD card in sizes up to 2GB, the very large cards are not worth risking on three counts:
(1) Manual recommends max of 256MB (Although that might just have been the limit of production, when this camera was issued).
(2) Generally, multiple smaller cards give you more flexibility than one bit card (and they attract less of a premium).
(3) A 2GB card, if it worked, would store an infeasibly large amount of pictures on one card - it would be very hard to sort them, and you really would have "all your eggs in one basket" - remember that card, like any other magnetic media, can fail, especially over time.
So 256MB is plenty, and its an xD card (Distinguishable by its curved profile along one on the long sides).
Hope this helps.
Mar 09, 2010 | Olympus Camedia C-150 Digital Camera
When i want to send picture to memory card it comes up and says its not ready
This happens with 2GB cards.
If you are using an SD adapter (where you put the micro SD in the adapter to make it a full size SD card) and you have an built-in card reader, it may be your card reader is a little old and wasn't made to support 2GB cards.
One other thing to check is that the card is not locked. Look for the lock sysmol in the corner and make sure it is unlocked..
Oct 11, 2009 | SanDisk 2GB microSD Memory Card
A 2gb memory card says memory full tried it in
No, that camera works with the 2gb cards just fine. You will want to try to format the card in your computer first, then try it in your camera (format it in the camera before using). If it doesn't format in the computer, it is a bad card.
Jul 19, 2009 | Kodak EasyShare C330 Digital Camera
Nikon coolpix 2100- out of memory- After installing 4gb CF card
4GB requires FAT32. Camera firmware only supports FAT16. 4GB won't work because FAT16 has a 2GB maximum size limitation. 1GB CF card is Nikon's "approved" maximum for this camera.
Catch: 22 1GB -and lesser capacity- CF cards are no longer manufacturered or generally available in 2010. When the current CF card dies, the still working camera also becomes throwaway unless you can source a CF card 1GB or under. 2GB may work, but with 'issues' per caution below.
CAUTION: Anecdotal evidence suggests the final release -& current- firmware for cameras of this generation is also encumbered by with a maximum picture number limitation of 999, realistic at the time of original manufacture when 256MB was a the largest capacity CF card but completely nonsensical now.
Summary: This is my first NIkon Digital camera and also my last.
Apart from the noteriety of the ubiquitous broken Nikon plastic battery latch, a major design flaw Nikon refuse to acknowledge or accept liability to rectify -since self-repaired better than OEM, Nikon policy on firmware support is complete abandonment of product within an unacceptably short service window. ie: a deliberate poilicy of enforced obsolescence.
Suggested Problem Remedy: Do buy a new camera supporting SD Cards of current capacities. Don't buy anything branded Nikon.
May 24, 2009 | Nikon Coolpix 2100 Digital Camera
I have a 2GB SD Memory card thats won't format and says its full
per manual... camera supports UP TO 256MB... your camera can't recognize a 2gb card.
Mar 08, 2009 | Vivitar ViviCam 3705 Digital Camera
SanDisk 2gb Micro SD stopped working
some card readers have a max memory size spec - iRock IR-5300 is 2GB - mine did the same thing when I put a 4GB card into it.
The other issue is that there is no drive letter assigned to the card reader - but that will show up as the "Removeable Drive" not even appearing in WE. For that u have to go to the computer manager and find the device and assign a drive letter to it.
Dec 03, 2008 | SanDisk 2GB microSD Memory Card
PNY 2GB memory card
I have the same camera and bought a 4GB PNY SD card and it wouldn't work, so I read the manual :) The manual says, "SD Memory Cards having the following storage capacity can be used on your camera (Toshiba PDR-3330):
8MB, 16MB, 32MB, 64MB, 128MB, and 256MB"
Hope this helps! -Kim
Jul 15, 2008 | Toshiba PDR-3330 Digital Camera
256mb Card
Maximum card size supported for C5050 is 2GB (CF/Microdrive slot) and 512mb (XD card slot)
Jul 05, 2008 | Olympus Camedia C-5050 Zoom Digital Camera
SD card
wahoo!just been rummaging the internet and i have found that these cameras will only take up to a 1gb memory card!so just get a smaller size card
The camera has 16 MB of internal memory. Memory capacity can be expanded with 16MB, 32MB, 64MB, 128MB, 256MB, 512MB up to a maximum of 1 GB SD or MMC cards.
Hope it helps!!!
Jun 23, 2008 | Kodak EasyShare C330 Digital Camera
Olympus Stylus 410 / ? 410 Digital Camera Logo
85 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
