Question about Sharp Viewcam VL-A10U Camcorder
Can I record from my Viewcam onto a VHS cassette?
    Master:
  • 425 Answers
Yes you can! The most important step when dubbing from 8 millimeter to VHS, is setting the VCR that the unit is being hooked to, to the Auxiliary Mode. We suggest consulting the operator manual for your VCR for the instructions on how to set that.
Posted on Sep 07, 2005
I have a grundig gr1000(b) vhs/DVD combo. Is it possible to record from video cassette onto DVD? It doesn't seem to be mentioned in the instruction manual. Thanks for your help.
Yes! You can select to copy from VHS to DVD or DVD to VHS, set the VHS tape ready to play and press pause, then put a blank recordable DVD disk in and then select copy, the options for VHS to DVD or DVD to VHS can be selected and then it will copy, when the tape gets to the end it will turn off itself, if you want to stop earlier you will have to stop it! Hope this helps.
Nov 02, 2014 | Televison & Video
VL-H86 PROTECT TAB IS ON AND ALL THERE IS ON THE TOP OF THE TAPE IS ERASE. HOW DO I GET IT OFF SO I CAN RECORD?
Let me reach back into the past here!
Well, protection tabs are on the cassettes. Video8 & Hi8 used a built in re-usable tab (unlike VHS, Beta etc which used a once only break-it-off tab, a method originating near 50 years ago with audio cassettes)
In reverse of the that method, when the tab is out (or slid over) recordings can be made on 8mm's including D8's and not when the tab shows.
they are located on the back edge of the cassette usually with indicator icons in the plastc of the case to help.
Sep 26, 2011 | Sharp Viewcam VL-AH151U Camcorder
DVDR/VCR Combo_ZV450MW8a. When I insert the VHS cassette...
Had the same problem. took cover off, cleaned the recording heads. Also look on the left and right of casett chassie.You'll see to thin green strips sticking up with a black elctronic device. Chech to see if it is aimed at the clear plastic pin near the little black plastic gear in the middle. mine was out of alignment on the left one. Works know. Good luck
Jan 24, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Vhs tapes recorded to DVD+R's
try forwarding the tape to the end and then rewind to the start again, this can help to seat the tape correctly on the spindle . the audio track part of the tape is in a specific region on the tape so misalignment may be the issue with those cassettes.
also try to press the tracking up and down when playing the video
May 12, 2017 | Televison & Video
SHARP Viewcam z vl-Z500H-S Camcorder
To transfer video you need to use firewire, not usb. If you use firewire to connect, set the camera to the 'play' icon and then open up a capture program (ie, movie maker) you should be able to just record/capture from there. Good luck!
Jun 17, 2008 | Sharp VL-Z500H Mini DV Digital Camcorder
Record onto DVD
No. This machine only plays DVDs. You would have to obtain an entirely different machine. One that is a DVD Recorder. This one is a DVD Player + Video Cassette Recorder
Apr 28, 2008 | Zenith XBV243 DVD Player/VCR
Converting VHS to DVD
All you have to do is buy a vhs to dvd recorder. They sell those everywhere, like costco, walmart, etc. They keep getting cheaper and cheaper...
They will come with a manual with model specific instructions, but usually its pretty easy. The cassette plays and the device records the video onto the dvd.
They also play vhs and dvds too XD.
Here's a good website:
http://hometheater.about.com/od/dvdhardwareandsoftware/tp/dvdvcrrecorders.htm
Jan 06, 2008 | Emerson EWD2203 DVD Player/VCR
Can an adaptor be used to play my 8mm tape in my VHS VCR?
With the Sharp Viewcam ®, there's no need to use an adaptor to play 8 mm tape. Simply connect the Viewcam ® to the TV or VCR for playback. You can even use your VCR to make a copy onto VHS tape.
Sep 07, 2005 | Sharp Viewcam VL-A10U Camcorder
Noise block doring playback of D-VHS tapes
* Do not record program in DVHS mode on an S-VHS cassette. Use of S-VHS cassettes will not allow for maximum performance and may result in head clogging. Use only D-VHS cassettes as recommended in the instruction manual on page 27. * Make sure that the DIGITAL 3-DNR lamp is ON when playing back a cassette recorded in D-VHS mode. If not press DIGITAL 3-DNR so that the DIGITAL 3-DNR indicator illuminates. * When block noise appears on the TV screen, clean the video heads with the DFC-2 D-VHS Head Cleaning Cassette (continue up to 3 minutes total). Please refrain from using any other head cleaning cassettes as drum damage may result.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Sharp Viewcam VL-A10U Camcorder Logo
124 people viewed this question
Top Sharp Video Cameras Experts
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
