Question about Nokia N81 Smartphone
My navigation wheel not working
I turned on my navigation wheel but its not working
  • shadyhany Nov 27, 2008
    I went to the warranty service but they tried to tell me that it's normal for it to do that and that it was a temporary feature. I made them change the whole face anyway and it still doesn't work.
  • 25 Answers
I would suggest that the navigation wheel have worn out probably due to constant use.take the phone to a qualified tech for service.
Posted on Aug 27, 2008
My samsung juke phone won't work. If I take out the battery and charge it, the screen will flash. The second I press the prongs together, it stops working.
You may need to reset the phone, but it will delete everything on the phone. You may follow the steps below:
  1. From the main screen, press the center of the navigation wheel to choose Menu.
  2. Select Settings & Tools then press the center of the navigation wheel to choose OK.
  3. Select Phone Settings then press the center of the navigation wheel to choose OK.
  4. Select Security then press the center of the navigation wheel to choose OK.
  5. Enter the lock code then press the center of the navigation wheel to choose OK.
    The default lock code is the last 4-digits of the mobile number.
  6. Select Restore Phone then press the center of the navigation wheel to choose OK.
  7. Select Yes to confirm then press the center of the navigation wheel to choose OK.
Jul 26, 2016 | Samsung Cell Phones
Can i drive my lincoln navigator with the air ride suspension switched off?
As long as the system does not leak down, and the body stays up off the wheels, yes you can.
Feb 17, 2013 | 2004 Lincoln Navigator
Key will not turn over
Check to make sure gear shift is in Park. Rock the steering wheel hard without the key in. Try the key...you may have to hold the steering wheel all the way in one direction and try or the other direction and try. Good luck. Sometimes the steering wheel lock does not line up when you removed the key.
Oct 22, 2017 | 2000 Lincoln Navigator
My sansa e260's navigation wheel lights up but the screen is blank. what do I do . It may be the battery is completely dead. Bob L.
Your battery is not dead because if it was, then navigation wheel would not be lighting up. Your screen is blank because when you touch the navigation wheel, you probably decrease the brightness of the screen. Turn the wheel counterclockwise, as this will brighten up the screen display. Press the center button when done. Reply back if this solution does not help.
Mar 04, 2011 | SanDisk Sansa e260 MP3 Player
2007 Honda Civic Navigation Screen went black
Had same problem with 2008 Honda Civic.
Note: you will need anti-theft code so get it first!
Solution:
1. Turn ignition off.
2. Look for fuse box under steering wheel.
3. Remove fuse #35 which is for the Navi-audio unit.
4. Then re-insert the fuse. This will reset the system.
5. Turn ignition on and the Navi-audio on. Buttons WILL be working now.
6. The unit will request for the anti-theft code for Navi-audio system. Enter the 4 digit code....Yippee!
However, I lost all my radio preset stations. Thankfully my saved destinations in navigation system were intact.
Apr 02, 2009 | BoxWave Corporation 2007 Honda Civic...
Forgot password
  1. From the main screen, press the centre of the navigation wheel to choose Menu.
  2. Select Settings & Tools then press the centre of the navigation wheel to choose OK.
  3. Select Phone Settings then press the centre of the navigation wheel to choose OK.
  4. Select Security then press the centre of the navigation wheel to choose OK.
  5. Enter the lock code then press the centre of the navigation wheel to choose OK.
  6. Select Restore Phone then press the centre of the navigation wheel to choose OK.
  7. Select Yes to confirm then press the centre of the navigation wheel to choose OK.
Aug 09, 2017 | Samsung SCH-U470 Juke Cellular Phone
When turning my 1998 Lincolon Navagator i here a grinding sound.A
if you feel it in steering wheel it could be your front axels. jack up the front end of your vehicle and turn the steering wheel to which ever way you hear it most, roll the wheel with your hand and see if you hear any noise maxwellgarland@bellsouth.net
Dec 10, 2008 | 1998 Lincoln Navigator
Tire pressure sensor fault
you need to remove the sensors in you factory wheels or buy new sensors to install in your new wheels. there is no way to turn this option off.
Oct 17, 2008 | 2004 Lincoln Navigator
Xm2go
Could you be more specific? Are you trying to navigate using the wheel on the right-side of the unit? Is the wheel turning but nothing happens?
It could be you're trying to navigate via the keypad, which doesn't work. I know, I've tried it. It's not exactly intuitive to only have the wheel work, but that's how my unit works, in any case.
Feb 22, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Nokia N81 Smartphone Logo
47 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
