Question about Sharp Viewcam VL-A10U Camcorder
The "DEW" indicator is illuminated on my Viewcam, what do I do to turn it off?
  • HARABELLE16 Jan 21, 2009
    I have a same problem with my viewcam ,i did this solution but the DEW indicator is still illuminated and the viewcam turnoff
    Master:
  • 425 Answers
This means there is moisture inside the Viewcam. Try taking the tape out, leaving the cassette compartment open for 2 hours to allow any condensation to evaporate. If the DEW indicator is still illuminated call a Sharp authorized servicer.
Posted on Sep 07, 2005
    Problem Solver:
  • 5 Answers
Override this sensor malfunction by resetting the viewcam first remove tape and close compartment. then remove batteries and let sit for 3 minutes re insert batteries and power up cam.. this usually quick fixes this problem....BUT if this isnt working there is something else wrong with your dv cam and I also suggest calling in the support team
Posted on Jan 25, 2007
SOURCE:
My digital camera wont work and it keep saying DEW. what does that mean? it is a sharp vl-z5 digital camera
I HAVE A VIEWCAM VL-Z7, I STARTED TO CHARGE MY BATERRY TO THIS JUNKY UNIVERSAL CHARGER AND FOR SOME REASON IT TURNED ON BUT 1 MINUTE LATER IT TURNED OFF AND NEVER TURNED ON AGAIN
Dec 11, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Bypassing of DEW sensor
there is no way to bypass it, but simple modification is available to correct this problem. contact any sharp authorized repair center.
Sep 13, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
What doe DEW mean? The "DEW" sign keeps coming on and then shutting off..
DEW sign indicates high humidity level inside the camcorder. What you experiencing has nothing to do with humidity, It is a faulty connector on a junction board. Sharp has fix for it.
Jul 12, 2009 | Sharp Viewcam VL-Z3U Mini DV Digital...
Dew warning message
Dew sensor is defective and you need to replace it to fix the problem.
Jul 25, 2008 | Sharp Viewcam VL-Z5H Mini DV Digital...
Flashing "DEW" Indicator shutting down the viewcam
I don't know if this will help, but when I leave the camera open with no tape in it for a day or so, "dew" goes away. Now I just store it open without a tape in it and have never had this problem again.
Hope this helps.
Feb 26, 2008 | Sharp Viewcam VL-Z7U Mini DV Digital...
Sharp Viewcam z
either it has moisture in it (let it dry), or the dew sensor is bad and needs to be replaced.
Nov 29, 2007 | Sharp Viewcam VL-Z3U Mini DV Digital...
DEW indicator / battery
In your owners manual on page 52 you will find a list of authorized service centers. Give the one in your area a call. Give them the brand name and model number of the camcorder. Tell them you are having a problem with the dew warning coming on while using the camera with the battery. They should be able to help find a answer to this problem.You can also call the panasonic customer support telephone number at 1-800-211-7262 between the hours of 9am-7pm EST. Give them the brand name and model number of the camcorder and ask them for help with the problem of dew indicator coming on while in use with the battery. I hope this information helps you with your camcorder problem.
Nov 20, 2007 | Quasar VM-L450 Camcorder
Dew indicator
look inside the camera to the front.wou will see 2 solder bloba,run a line of solder between them to by pass the dew,it works
Nov 04, 2007 | Sharp Viewcam VL-Z3U Mini DV Digital...
I get the DEW indication and cam shuts off
try to dry up your camera using electric hair blower drier, dew is present inside your camera, but dont overheat the unit, place your hand between drier and cam to make sure you are not overheating it. if the trouble is still there, the sensor is defective and you need pro fix.
Sep 28, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
E007 and DEW indicator
Few restarts fixed this for me but I know this is going to come back again soon.
Mar 30, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp Viewcam VL-A10U Camcorder Logo
318 people viewed this question
Top Sharp Video Cameras Experts
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
