Question about Sylvania 6632LG 32 in. LCD HDTV
Help This 32" lcd tv has sound and a clear raster. Please help. edluck@bellsouth.net Thanks Ed
    Guru:
  • 1,894 Answers
Are you able to get video using a dvd input??
please check if its a signal fault of video boards fault
Posted on Aug 27, 2008
  • dewan nafees ahmed Aug 27, 2008
    instead of giving a input from the cable give the input of the DVD player and check if you can see both audio and video.
I have an 32" lcd
if your TV unit is totally went black or even a raster doesn't appear on the screen, the problem maybe the power inverter board for the back light or the back light itself must be the reason of no picture. you will need to open the back cover then look for the inverter board where the lamp is connected, check bad components like shorted FET transistor and mostly electrolytic capacitors which blow up to its casing and it becomes leak causes a low voltage and can not give enough supply to the lamp. and then next you need to consider is faulty or busted back light which the main source to illuminate light to make the screen visible. if you need parts replacement click this www.lcdparts.net/CCFLA13D.aspx you can find here replacement part.good day and good luck hope it can help you.
May 07, 2011 | Televison & Video
No picture, no sound, nothing but snowy screen. Have turned TV off and then back on, same problem.
well snowy screen is good. It usually means that your antenna is dosconnected check coax and alls connections
please rate my help++++Thanks for using FIXYA
May 19, 2010 | RCA L32WD22 32 in. LCD HDTV
Need owner manuel for koss KS5190 digital home theatre system
me too help bzaggy@bellsouth.net Do u need remote to set speakers along with other setting problems including, back speakers not working, tv not on surround sound, can play dvd and tuner still no back speakers, no remote. Do u need remote to set, please help!!!! email bzaggy@bellsouth.net
May 11, 2010 | Koss Audio Players & Recorders
Sony lcd kp60xbr800 no raster in tuner all voltages ok. in tuner power ok, menu ok, but no raster please help sergioaguirre0182@hotmail.com thanks
You have a lamp driver error that can be and most likely is faulty and has to be replaced,Also i would not recommend you putting a bigger lamp unless the part numbers are the same to the lamp you are replacing.Moreover most of sony's error codes are the same from crt to lamp tv set like your lcd model tv set, the same concept was used to built your lcd tv set just with different features.
Sep 08, 2009 | Televison & Video
No power indication,no rasters,and no sound. Only click sound.
Go to the Anantek website and search for your TV or similar TV's to see if anyone has posted repair hints. I've fixed several TV's and other electronic equipment from their website.
Jan 29, 2009 | Televison & Video
I have just acquired an INSIGNIA 32"lcd tv W/dvd and need the # code to program my Brighthouse remote to control this unit. rogerc3@bellsouth.net
10-1-08
I solved the problem by useing the brighthouse remote procedure to locate the code # appropriate for the Insignia 32" tv, the unit is currently functioning as it should, thanks for responding.
I donot care to signup for your services for future use.
Sep 30, 2008 | Televison & Video
When I try to send an email with an attachment, I get and error mesage that begins "The host 'mail.consolidated.net' could not be found (etc)". I contacted AT&T who advised I contact you and...
well..this is NOT bellsouth, I can assure you, and this issue is clearly NOT a printer one. So, contact Bellsouth for this information about how to work your email program.
OR..
Aug 19, 2008 | Lexmark X2500 All-In-One Printer
Sylvania 6632LG 32 in. LCD HDTV Logo
177 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
