Laptop Accessories
Problem for Laptop Accessories
Generic problem for all Laptop Accessories
Please help me...!
By valeriu62 on Aug 27, 2008
I have a computer and I have instal windows xp. For my e-mail I have outlook expres. I buy another computer whit windows vista instaled and I want to copy my e-mails from outlook expres to second computer in windows mail.Can I do this? Can I do this if both computers is in local network?
thanks verry mutch!
Solution #1
posted on Aug 27, 2008
Not Rated)
Hollyecho
Rank: Wiz
Rating: 83%, 216 votes
Outlook Express First, you need to start Windows XP and launch Outlook Express. If you have a dual-boot configuration (Windows XP and Windows Vista) you should export everything to a location that is accessible from both operating systems. If you have Windows XP installed and you plan to erase it and upgrade to Windows Vista, we recommend that you save everything to a back-up disk and import from it later, after you install Windows Vista.
Exporting the Address Book
Go to the File menu, select Export and click on Address Book.
The Address Book Export Tool will be launched. Select the second option - Text File (Comma Separated Values) - and click on the Export button
You will be asked to select the path where you want to export your Address Book. Click on Browse, go to the folder where you want to save your Address Book, type the name of the file in which it will be saved and click the Save button.
The CSV Export window will open. Here you will have to select which contact details you want to export. Select the ones you want or, for more safety, select all the fields and then press the Finish button.
The Address Book has now been exported to the chosen location.
Exporting E-mail Accounts Settings
In Outlook Express, go to the Tools menu and then select Accounts.
A window with all your internet accounts will be opened. Go to the Mail tab and from the list of e-mail accounts select the first you want to export. Click on it and then press Export. You will choose the folder and the file name where your settings will be exported. After that, click on Save.
Repeat this procedure for all the e-mail accounts you want to export to Windows Mail.
Exporting E-mail Messages
Go to Tools and then select Options.
Go to the Maintenance tab and click on the Store Folder button.
A small window will open and you will see the location where Outlook Express stores all your e-mail messages. Copy that location, close Outlook Express, open that location in Windows Explorer and then copy all the content to a different location.
If you have a lot of messages, the process will take quite some time to finish.
Windows Mail
After you have finished the export process, reboot and start or install Windows Vista. When you are ready to import all your e-mail accounts, messages and address book to Windows Mail, go to the Start Menu - All Programs and launch its shortcut.
IMPORTANT: during the importing process we recommend that you run Windows Mail as an administrator. If you do not run it as an administrator the import process might fail.
Importing the Address Book
In Windows Mail, go to the File menu, select Import and then Windows Contacts.
In the Import to Windows Contacts window, select the first option - CSV (Comma Separated Values) - and press the Import button.
Now you have to Browse to the file where you exported the Address Book from Outlook Express and then press Open. When you are done press Next.
In the CSV Import window choose the fields you want to import. If you are not sure which fields to select, select all of them and press the Finish button.
Now the Address Book has been moved from Outlook Express to Windows Mail.
Importing E-mail Accounts Settings
First, go to Tools -> Accounts. In the Internet Accounts window, press the Import button.
Now you have to browse to the location where you exported your e-mail accounts settings and select the file containing those settings.
Repeat this procedure for all your e-mail accounts. All the restored accounts settings will be listed in the Internet Accounts window.
Importing E-mail Messages
Go to the File menu, select Import and then click on Messages.
In the Windows Mail Import window, you need to select the third option - Microsoft Outlook Express 6 - and click on Next.
Select Import mail from an OE6 store directory and press the OK button.
Now you have to browse to the folder where you exported all your e-mail messages, click the Select folder button which takes you to the next screen at which point you then press Next.
Select the message folders you want to import and press Next.
After the import is finished, the wizard will show a Import Complete message. Press the Finish button.
Now all your e-mail messages from Outlook Express will be available in Windows Mail. By default, all your imported messages will be placed in the Imported Folder. You can move them to any other folder using the drag and drop procedure.
Was this helpful?
Yes
No
Popular Solutions for Laptop Accessories
Questions and Unsolved Problems for Laptop Accessories
Answer
my modems is locks request to all of you any one send me unlock software of... (More)
Answer
250gb egem 2.5 arrived with disc but directions only deal with taking screws out and inserting... (More)
Answer
I have a laptop and A BTvoyager1060 adapter. when I try and get on the net it says server not found... (More)
Answer
plugged in us sony docking station to 240 volts power and unit stopped working,is it possible to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Laptop Accessories:
Top Laptop Accessory Experts
Rank: Guru Guru
Solutions: 14848
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Laptop Accessory Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
